D
Deleted member 72219
Guest
Can't seem to find a single thing on this MX7 or MX7s. Does it even exist?I hope one day they make a new strong allinone amp like the MX3s.
Topping MX7s
-Ed
Topping MX7s
-Ed
This is exactly how rumors start...I hope one day they make a new strong allinone amp like the MX3s.
Topping MX7s
And a month later they've made itThis is exactly how rumors start...
Next, an influencer asks Topping for an MX7s test sample![]()
@ you three distortion and noise adding experts (nice discussion btw.): If the power supply would have had less distortion at 60 Hz, 120 Hz, and 180 Hz - would the SINAD of the B100 be even better than 120 dB? I know, it’s only academically, because everything over 116 dB is fully transparent anyway, but if the power supply would have had the LA 90 48 Volt Power Supply-Qualities of minus 145 dB at 60 Hz:
the B100 would have killed the LA90 discrete by even more than 0.5 dB margin?
No. The spikes are at -140 dB which is not an impact on SINAD of 120 dB. Broadband noise is some 30 dB higher than what FFT shows which would swamp those spikes.@ you three distortion and noise adding experts (nice discussion btw.): If the power supply would have had less distortion at 60 Hz, 120 Hz, and 180 Hz - would the SINAD of the B100 be even better than 120 dB?
You can see what Topping post in the product page.Power amplifier test is vulnerable to interferences such as radiation the power supply.With all things put in the right place to minimize interferences,it will achieve near 123dB SINAD just like a HPamp from topping because of the same low noise and distortion.@ you three distortion and noise adding experts (nice discussion btw.): If the power supply would have had less distortion at 60 Hz, 120 Hz, and 180 Hz - would the SINAD of the B100 be even better than 120 dB? I know, it’s only academically, because everything over 116 dB is fully transparent anyway, but if the power supply would have had the LA 90 48 Volt Power Supply-Qualities of minus 145 dB at 60 Hz:
There will be MX7 first then the s.I hope one day they make a new strong allinone amp like the MX3s.
Topping MX7s
Unless I am wrong (I could be, but I don't think so), depending on what sources are being used (e,g., DAC, phono stage, etc.), I think the bigger issue with this amplifier will be the noise from the input sources. It is amplified by the amplifier, the amount of amplification depending on the gain of the amplifier.I think I've gotten this mostly right, but anyone feel free to jump in and correct it, if they think my numbers are way off the mark here.
Then what explains SNR being where it is? If medium gain SNR is 128.5db, mgSINAD can only be at 119.52 if mgTHD is -120.1. The three are all mathematically related and solve for one another. You got me unless one of the measurements hit an instrumentation limit.No. The spikes are at -140 dB which is not an impact on SINAD of 120 dB. Broadband noise is some 30 dB higher than what FFT shows which would swamp those spikes.
Noise level/dynamic range won't change as speakers are totally silent when not driven.Put any speaker into the calculation and see the number drop drastically.
No. The Topping Datasheed shows A-weighted data. @amirm is a little stricter about it!You can see what Topping post in the product page.Power amplifier test is vulnerable to interferences such as radiation the power supply.With all things put in the right place to minimize interferences,it will achieve near 123dB SINAD just like a HPamp from topping because of the same low noise and distortion.
I don't get that calculator. It asks for SNR of noisiest component. But then it wants to force including 25dB amplifier gain. But usually the power amplifier is the noisiest component. Well I can do it in my head anyway. And I don't care about listening position, I want to know if I can hear it when I walk by one of my speakers. Easy rule of thumb is if your amplifier SNR at 2.83V is about the same or better than your speaker sensitivity you won't hear anything in a normal room. In my case I don't hear any noise with my ears within a couple inches of 85dB speakers, even though my amplifier SNR at 2.83V is only about 82dB.Use Benchmark's calculator which is pretty accurate: https://benchmarkmedia.com/blogs/calculators/thd-n-absolute-inaudibility-calculator.
That is calculated from the amplifier power you entered a few lines above - somewhere round 300W would give that.But then it wants to force including 25dB amplifier gain.
So then for entering THD+N (I prefer using just SNR) use the value at full power? When I do that, use single speaker, and use 0.1 meters distance I get SPL in the 20s so seems reasonable. Sorry for my misunderstanding!That is calculated from the amplifier power you entered a few lines above - somewhere round 300W would give that.
This is called PRE DISTORTION where you add in an inverse distortion signal to make the output better. It's been used in Tube TV transmitters for just about FOREVER! I published an article about it six years ago: https://www.radioworld.com/tech-and-gear/put-synergies-to-work-at-your-stationOK, I found some information on this. Perhaps the best explanation is this one from Keysight support:
_________________________________
A feedforward amplifier is a type of power amplifier that utilizes a feedforward technique to improve linearity.
Here is a step-by-step explanation of how a feedforward amplifier works:
1. The input signal is split into two paths: the main path and the error path.
2. The main path signal is amplified by the power amplifier.
3. The error path signal is delayed to match the propagation delay of the main path signal.
4. The delayed error path signal is then amplified by a separate amplifier called the error amplifier.
5. The amplified error path signal is subtracted from the main path signal.
6. The resulting difference signal, known as the error signal, represents the distortion introduced by the power amplifier.
7. The error signal is then fed back to the input of the power amplifier.
8. By subtracting the error signal from the input signal, the power amplifier is forced to follow the input signal more closely, reducing distortion.
9. The combination of the power amplifier and the error amplifier effectively cancels out the distortion introduced by the power amplifier, resulting in improved linearity.
It is important to note that feedforward amplifiers require precise component manufacturing and knowledge of the signal path to achieve optimal performance. Additionally, the loop in a feedforward amplifier is not self-stabilizing, so careful monitoring is necessary to maintain stability. Feedforward amplifiers are typically used in high-frequency (HF) and lower very high frequency (VHF) applications due to the requirement of small delays for stability.
It looks like Topping have used their experience with radio frequency design concepts to apply them to an audio amplifier. That's very interesting stuff. I can see how -- if implemented successfully -- a feed-forward network could be used to remove the crossover notch from a class B output stage. But this is the kicker...
"...feedforward amplifiers require precise component manufacturing and knowledge of the signal path to achieve optimal performance. Additionally, the loop in a feedforward amplifier is not self-stabilizing, so careful monitoring is necessary to maintain stability."
Is this Topping amplifier unconditionally stable, under all conditions of operation? Yes, it appears to be so with sine waves applied to its input, but what about a 10kHz square wave, or other more difficult tests? Is the 'monitoring' constant enough for the desired results at low frequencies such as those in the audio band?
It could be that this amplifier accomplishes all the goals, including stability under all signal conditions. That would make it a true breakthrough product. The smallish power output is probably a product of the complexity of this kind of design compared to the usual class AB or class D designs.
I wonder how this amp sounds in operation, driving today's relatively difficult speakers with very wavy impedance curves dipping down to under 4 ohms with steep phase reversal angles, etc.
