Topping B100 Amplifier Review
Rate this amplifier:
    Votes: 30 6.6%
    Votes: 27 5.9%
    Votes: 82 17.9%
    Votes: 318 69.6%
THX standard suggests that the gain should at 23db for balanced or 29db for unbalanced.
Wouldn't be better to have the standard gain instead of 20 and 23db?
For example, if your AVR preouts are a bit low in voltage, a bit more gain could be handy.
I feel Topping wants impressive SINAD numbers so they bring the gain down...
It depends a lot on the rest of your system. In home cinema it makes sense, at least if you're sticking to THX approved components throughout. If you've got very sensitive horns, like some who have posted to this thread, 29dB of gain will be WAY too much. Another argument would be that sensitivity should be standardised so that amps reach full output at 2V unbalanced or 4V balanced input, the de facto standard(ish) output for DACs. Pick an amp with more or less the power you need for your preferred maximum volume. But there will be counterarguments to that one too.
This is called PRE DISTORTION where you add in an inverse distortion signal to make the output better. It's been used in Tube TV transmitters for just about FOREVER! I published an article about it six years ago: https://www.radioworld.com/tech-and-gear/put-synergies-to-work-at-your-station
That's a similar concept to THX/Benchmark feed-forward error correction, except in Benchmark's case, the input signal is not altered, but the inverted error signal amplified by a low-power amplifier is summed with the primary signal amplifier's output.
Reactions: EJ3
Yes, they are summing in a correction signal. This is valid too.
tl;dr: The power amp gain does not matter all that much, unless you use it to make the amp smaller and reduce output.
What is most important is to match gains for the typical volume position on the pre-amp. Let's pick a few pre-amps. I'm going to have to link Stereophile reviews for this since older ASR reviews often don't include SINAD vs output voltage chart for line outs, and it was just taking too long to find two good illustrative products. So, we'll go with this. First, Eversolo DMP-A8: https://www.stereophile.com/images/0724-ES-A8fig03-600.jpg. Next, Topping Pre90: https://www.stereophile.com/images/122Top90fig03.jpg. The Eversolo is effectively completely quiet from 1V to a whopping 15V. .0002% or -114dB in the whole range. The Pre90 doesn't appear to approach that until a huge 5V out, where it quiets to -108, or .004%. At 2V, it's .0025, or -92dB. Notably, this is worse than the best AV receivers, which are ~110dB at this point. (Note: I don't know that something didn't go wrong with the Pre90 here, it's MUCH quieter in the ASR measurements, but that's not relevant for this example. I just needed some charts with appropriate curves.) Let's just call those SNR measurements, since they mostly are since the curve is still sloping down.
If I need 100W and my amplifier is -95dB at 100W, and it reaches full output with 2V (which is maybe 25 or 26dB gain), I have hit full quiet (-95dB less a trifle) with the Eversolo and a typical AVR. But here's where it starts to get fun. With the -110dB AVR the overall noise is -9593. With the Eversolo? -94.95, maybe. I didn't get much extra. With the Topping? -90. Now let's say I have a "low gain mode" on the amp, and it requires a 10V input to max it out, and allows the amp to pull another 4dB to get to -99dB. Obviously, I can't use it in this mode with the AVR. It's probably out of the game. But I can with the Topping and the Eversolo. And it does get me something. With Eversolo, I now get -98.8dB. With Topping, I get -98.5. So, I've picked up something, at least, but not all that much. And I had to spend a bunch of extra money to get there, and can no longer use my AVR preouts.
To stay on topic, the B100 will at least hypothetically always allow me to lower overall system SNR by blowing more voltage out of the preamp (as long as the preamp doesn't start distorting). The "problem" though is that it does nothing for me. Even in high gain, I already get -135dB noise at full power. What speaker can take advantage of that even at 6 feet from the speaker? Almost none. By 2V (on ASR measurements) Pre90 has hit -116. Total system noise is -115.95. I need 99dB horns just to take advantage of that from only 6 feet away. At 9 feet, 104dB sensitive horns. Even the receiver is guaranteed inaudible at 2V for 98dB horns at 2 volts!
Once you've got the high gain mode quiet enough, keeping going just doesn't do much for any real-world use case. The limitations are always upstream, and even then they're almost always just fine in high gain too! You'll almost never need the gain control to put more than 2V into the unit. The only place you conceivably might use it is to "size down" the amplifier even more, so that 2V gets you 10W output (with very sensitive speakers), and allows you more range on the volume knob and to maximize pre-amp SNR at 2V. Essentially you're then turning it into a 10W amp and readjusting your gain staging so that the amp continues to put out the desired output with a 2V input.
Impressive, but I can't help wondering if the B200 might take the top spot if given a chance.
Any performance differences between the B100 and B200 apart from power output are likely to be academic, of course.
Cost difference.
-Ed
No difference at all.
What will be a meaningful addition will only be a specified below 4 Ohm amp.
All the existing ones are specified either by 4 or above Ohm or 4-8 Ohm.
It's of little interest that they maybe can go down to 3-2-1 Ohm if it's not officially specified.
I think performance is absolutely identical for LA90 / B100 / B200. Not only little (academic) differences (because fully transparent), but no measurable differences at all.
First I assumed that the B200 is cleaner than the LA90 (about 3 dB), but then I saw: the topping guys are using a-weighted measurements, so it is 3dB or so better than @amirm ˋs measurements.
It’s only the power (8 Ohm) that differs:
LA90: 40 Watts
B100: 50 Watts
B200: 140 Watts
LA90 bridged: 270 Watts (but on 4 Ohms)
What scares me most, is the LA 90 poll: exactly half of the users have had problems with their devices!
That is not much better than the PA 5.
If all three „Top of the Pops“ Topping amps are practically engineered in the same fashion,
I am afraid the issues will appear in the same fashion.
There is something very very nice with the Benchmark AHB-2: it sounds AND works. Day by day by day in many recording studios. VW Beetle-like.
LA90: 40 Watts
M100: 50 Watts
M200: 140 Watts
The B100’s Class-B topology is not the same as PA5’s Class-D topology at all. B200, if I’m not mistaken, is also different, as I believe they’ve stated that it is Class-AB. The only other amplifier in Topping’s line-up using the same topology as B100 is the A70 Pro headphone amplifier.
All of this being of what Topping has said is true about all of these amps’ topologies.
-Ed
-Ed
B100 Class B - typo of @amirm (at least I think so)
B100 and B200 same layout.
PA5 - Class D but comparable in reliability! There was a LA90D Poll also!
(LA90D is also class AB, like the B100 and the B200)
Topping initially told me Class-AB when I first asked, and then they came back after the fact and corrected themselves to say B100 is Class-B.
-Ed
-Ed
Most important thing is, that you will inform this community if issues occur.
Btw: I tested my need of power
I heared yesterday the complete jazz at the pawnshop with my Fosi v3
Low was 38.2 dB Peak was 93.2 dB - 55.0 dB Dynamik range!
6.5 food away from my 85 dB /Watt speakers.
It was very very loud.
So I need 13.5 Watt Peak at 8 Ohm.
Adding 6 dB extra reserve:
54 Watt need.
So the B100 will fit also for me perfectly.
Best amp on the planet. At least on paper. Hopefully it’s reliable!
54 Watt need.
So far mostly well. I have them set to Medium Gain. Not sure if it’s an impedance incompatibility or too high input voltage, but High Gain is not an option because it is audibly distorted if I try to use High Gain. If I use Low Gain, it is a little short on volume for quieter tracks (like All-Star Percussion Ensemble). Using the Topping L70 for preamp helps as it has +6dB Gain for balanced input on Low Gain. I need not bother with High Gain from my preamp.
I have had my right channel B100 safety kick in twice now, both times while playing Medium Gain with my preamp maxed out (volume -0.0dB). It had to have been cranked because I measured almost 90dB peak from my listening position 3 meters away before it cut out, and for me it was playing uncomfortably loud, but I wanted to push the limits to see where it would give up. Having pegged it enough for safety to cut in twice, I know how loud it needs to be pushed before safety kicks in and at least for me personally both times it was playing louder than I like, so at least for me, it provides more than enough power with the KEF LS50 Metas.
The safety is ultra-conservative. There was zero clipping or distortion both times safety kicked off.
-Ed
I have had my right channel B100 safety kick in twice now, both times while playing Medium Gain with my preamp maxed out (volume -0.0dB). It had to have been cranked because I measured over 85dB peak from my listening position 3 meters away before it cut out, and for me it was playing uncomfortably loud, but I wanted to push the limits to see where it would give up. Having pegged it enough for safety to cut in twice, I know how loud it needs to be pushed before safety kicks in and at least for me personally both times it was playing louder than I like, so at least for me, it provides more than enough power with the KEF LS50 Metas.
-Ed
You are OK with those problems?
I don’t plan to use High Gain (was just testing it) and I don’t listen nearly that loudly to set off the safety (again, just testing), so it’s fine. In normal use I’ve had zero problems.
I’m not going to pass up on a car because it can’t do 135mph when I don’t normally even go 100, right?
-Ed
OK. Thanks for reporting the experience for others looking at this.
Absolutely. One has to be realistic. I wouldn’t, for example, tell my dad to get these. His Magnepan speakers would choke these amps. The V3 Monos that I gave him definitely make more sense.
-Ed
Not sure if thre is an easy way to standardize this unless it is a well defined system like a THX certified home cinema. For example audio interfaces tend to operate at +4dBu (1.2V) with 22dB headroom, and output up to 12Vrms. Then we have 105dB/m Klipschs and 85dB/m KEF speakers...
LA90: 40 Watts
B100: 50 Watts
B200: 140 Watts
Your 'LA90 bridged' figure is into a 4Ω and not 8Ω load. I suspect it'd be ~120 Watts into 8Ω, as Amir states power (at the knee and not at 1%).
Also, I think it's useful to differentiate between the original chip-based LA90 and the newer (still current) discrete LA90D, especially when talking about reliability. My understanding is that very few original LA90s failed, and that most of the failed LA90Ds were from earlier batches.
FWIW, in total, I have 3x LA90, 2x LA90D, and 2x PA7+ (the joys of going active!). My first LA90 I bought back in June 2022 to use as a single stereo amp to drive my K1000 headphones. All these amps I've used just a few hours per week at most. Apart from the 2x PA7+ (which drive subs), none are being stressed particularly hard, all being connected directly to a single speaker driver (no passive crossovers). But nevertheless, they've all performed perfectly in the time I've had them.
Mani.
