TANCHJIM Space Portable Headphone Adapter Review
Rate this DAC & HP Amp
    Votes: 3 0.9%
    Votes: 5 1.6%
    Votes: 40 12.5%
    Votes: 271 85.0%
I got the Tanchjim Space yesterday and .....wow. In my listening room I have a fully active 4-Way Hornsystem with DBA (22 subs in the bass) and I like listening to music quite loud.
I have the 7s Zero:2 inears and this is more than enough power. Very clean and precise sound at all levels.
Now I am looking for a splitting cable to take 5V power from a power bank and not from the cellphone battery. Does anybody know if such a cable exists or have I to solder one?
rsqt
rsqt
Android or Apple?
Some Android will work with this https://www.aliexpress.com/item/100....order_list.order_list_main.62.21ef18024sHPJK (including every Pixel I have had and is my go to)
(charges phone at same time as sending audio and power to DAC)
Others will work with this kind of thing which I think is more what you are after but Ive never had much success with https://www.aliexpress.com/item/1005003097221593.html
Apple is (I think still) a whole different ballgame
Is there a really good media player with PEQ or PEQ App usable for/while streaming Qobuz? I would like to eq the 7Hz Zero 2 as Amirm did.
I read the Neutron Media Player sounds best but does not work with streaming.
But even without eq-ing for the last % Tanchjim and Zero:2 iem is a "killer combination".....for less than 120€.
USB Audio Player Pro?
+- the same behavior with Moondrop Dawn Pro(CT7601+CS43131), it cuts the first part of anything above 96000Hz.
16/24/32 bit up to 96000Hz works, anything above does not.
Thanks for this information. I returned my SPACE immediately because of that issue. Since it also occurs with the Moondrop Dawn Pro, I suspect even more that the reason for this behavior is the ComTrue CT7601 USB bridge, whether silicon or firmware. Therefore I will not buy a product based on that chip.
By the way, do you happen to own the Fosi DS2 2024 that Amir just measured?
You are welcome, but if there is already a sound playing in the background then the cut does not happen.
Yes, better buy something else.
The Moondrop Dawn Pro with the older firmware, the ASIO driver did not work well, with the new firmware
it does not work at all and it also does not have a Windows APP.
With the new firmware I am able to change the filter by pressing the 2 buttons
https://www.audiosciencereview.com/...one-adapter-review.46231/page-20#post-1908891
but not change the gain.
https://www.audiosciencereview.com/...one-adapter-review.46231/page-20#post-1909183
Tested the balanced cable with 7Hz Zero:2 and it is a little bit louder, but not much. Sound does not change.
Unbalanced full power is ok, balanced the last notch brings distortion. The Tanchjim as a dac for Sabaj A20h sounds really nice and power without end that you feel the pressure in the ear. Didn t expect this.
Tanchjim Luna now released - 130 usd.
Does it look wrong on the manufacturer's block diagram that each CS chip outputs to a corresponding jack?
Shouldn't it be that a balanced 4.4mm jack has each chip supplying one corresponding output channel?
I can't find that picture on Tanchjim site, where instead they specify this:
that confirms your right guessing.
Four channel decoding :facepalm:
I think these companies should hire webmasters and user manual/software writers who speak native English. This will greatly increase their profits and give some confidence to consumers.
Yeah, marketing department did not get the drawing right. No worries.
Im not sure they view their own websites as store windows in quite the same way as some western companies do. If I want to know whats going on in the chinese personal audio market Im looking at Linsoul/ Shenzhenaudio and the review sites/ youtube. I would hazard a guess most visitors to these manufs websites are looking for support/ manuals/ drivers rather than "shopping".
In other words - not much merit in using specialist translators etc from their perspective.
I got my Tanchjim Space a couple weeks ago now, and I've used its 3.5mm jack to power 250 ohm cans.
For its EXTREMELY SMALL size and EXTREMELY LOW power consumption (to output ratio), it's an excellent value. Regarding sound quality, I'd put it on par with the Topping DX1 (see bottom, updated after re-listening) The DX1 is the same price, but it also weighs 18 times more (258g vs 14g..) This isn't a knock on the DX1 at all - it's meant to be a desktop DAC. In fact, they probably tried to make it heavier using thicker-than-necessary aluminum for the chassis, which is nice. It's just not the best for portability or sticking in your pocket, which the Tanchjim is. And my primary focus here is the Tanchjim Space (obviously lol)
If you like to listen to your music really loud and your headphones aren't very efficient, or you need to compete with background environmental sounds (train etc.), the port you're going to need to use is the 4.4mm "balanced" output. Not all headphones are compatible with this, so if you need more than 11mW for your 300 ohm cans, or more than about 125mW for your 32-60 ohm cans, and your headphones don't support balanced operation, the Tanchjim Space is not for you! When you use its 4.4mm balanced output to drive your headphones, each DAC runs one of its channels completely out of phase with the other, and those two channels, out of phase, are then used to power one driver, the voltage is doubled. Into the same impedance, doubling the voltage doubles the current as well, and since power is voltage multiplied by current, you get FOUR times the power output (provided the current is able to be provided at these elevated voltages). With the 3.5mm jack, bridged mode is impossible. Oh, and I think you're only using one of the DACs in the dongle (or maybe half of each DAC).
So yeah, the Tanchjim Space 3.5mm output power is just 11mW into 300 ohms, while the DX1 is 51mW.
But when you use the 4.4mm output with balanced-compatible headphones, the Space is pretty much on par.
Buying a new 4.4mm cable for your headphones can sometimes cost $50+. I'd say, if you need to buy a new cable to use the Space, and it's going to cost you more than about $20, you should find something else to buy. (11mW is often more than enough for use at home)
The soundstage is wide, the bass is full and controlled, vocals sound quite natural but can come across thin in some circumstances. Frequency response comes across as very flat and extended. The listening experience isn't entirely non-fatiguing though - and I find the fatiguing nature of this specific device isn't due to brightness (as I said, frequency response sounds flat), it's how things like cymbal crashes and speech sounds like "s" "f" "th" etc. are rendered.
They will do headphones in the $120 to $200 range justice.
Phone Alone ("Phone") @~3.67V
lowest two of twenty measurements taken every 30 seconds:
500mA
501mA
501mA
3.67V average voltage over these readings:
Phone 1.83
Space @~3.65V
647mA
653mA
650mA
3.65V average voltage over these readings:
2.37W = Phone + Space
(Phone + Space) - Phone = 2.37 -1.83
Space = 0.54W
DX1 @~3.61V
861mA
865mA
863mA
3.61V average voltage over these readings:
3.11W phone + DX1
(Phone + DX1) - Phone = 3.11 - 1.83
DX1 = 1.28W
So the Space takes about 3/8 the power of the DX1. Pretty good! Not a bad thing for the DX1, it has three op-amps that the Space doesn't, and it isn't especially designed for portable use...
My phone has a 3,590mAh battery, 3.88 nominal Voltage. This makes it 13.92, or basically 14 watt-hours.
A phone charged to 100% and not touched, just running background apps, receiving e-mails and texts, should last 48 hours or so. If that's playing music from cell data, halve that:
3,590mA / 24 hours = 150mA,
150mA * 3.88V = 0.58W
So it's 0.58W to run the phone, and 0.54W + approx. double the audio power emitted from the DAC/HP amp combo "Space". Let's be really conservative and say we're using low impedance cans to maximize power draw - average music power is about 1/10 of an amplifier's rated "RMS" level before the peaks of the music start clipping. To illustrate, if you're playing ZZ Top - Sharp Dressed Man, and you turn up the volume so that the loudest peak in the song is 0.01V below clipping on a 100W amplifier, the average music power would be about 8 watts, with the louder (busiest, most instruments simultaneously+singing) parts being 10-12 watts. Back to Space - 280mW down to 28mW * 2 + generous = 100mW, or 0.1W
So now it's 0.58W and 0.64W = 1.22W. We don't have to be that extreme, so let's call it 1.2W
14/1.2W = just under 12 hours music playback from the phone instead
If you remember the text like this at the beginning, I had to change what I wrote there because when I busted out my DX1 for this, I listened to it, and, turns out: the Space sounds like I remember the DX1 sounding! Unfortunately my memory is wrong... I remember the DX1 sounding better than it does now... So the Space is elevated in relation to the DX1. Yes, the DX1 does have line level RCA outputs, but if they sound like the HP outputs, cheap nickel/gold plated 1/8" to RCA adaptors are available!
Wow that's longer than I thought it'd be. Took some time as well!
Anyone have any specific questions about this thing, for someone who has one?
I don't want to nitpick and the forgotten (h)our is probably only an oversight, but many people do not know this trick: calculations can (have to) be simply applied on the units, too.
I wish I had learned that in school: because if you have forgotten a formula, but you know the units of the result, then you know, when the formula is correct, or how the formula must should look like:
3590 mAh / 24 h = 150 mAh/h = 150 mA.
Checking the units is very helpful in everyday life, even for low skilled labour, for example, if you have to make a quick calculation with physical things per lenght, over time, in a volume, moving with a certain speed and calculating when the job will be finished, ...
Know the units, write them down, and you know, what numbers in the calculation must be multiplied or divided with what.
