JCALLY JM20 MAX Headphone Dongle Review
Rate this portable DAC & HP Amp:
    Votes: 8 3.5%
    Votes: 1 0.4%
    Votes: 24 10.6%
    Votes: 194 85.5%
This is a review and detailed measurements of the JCALLY JM20MAX DAC and portable headphone amplifier. It was sent to me by Crinacle. Cost is anywhere from US $22 to $65 :eek:.
The dongle has a bit of style to it with that logo and such. Otherwise it is well, a dongle. :) Key thing is how it performs.
If you are not familiar with amplifier measurements, please watch my tutorial on it:
[And subscribe to the channel :) ]
JCALLY JM20 MAX Measurements
I dialed down the digital input to JM20 MAX to get the voltage to be nominal 2 volts:
This is excellent performance for any DAC, let alone a little dongle:
I should note however that the low frequency noise was changing fair bit, at times dropping SINAD by 10 dB. This *may* indicated more than usual susceptibility to host noise.
Best performance is a bit higher than measured above:
JCALLY JM20 MAX headphone dac portable phone adapter dongle THD vs output voltage measurement.png
Above wiggles indicates the varying noise I just mentioned.
Letting the dongle fly at max output produces excellent dynamic range:
JCALLY JM20MAX headphone dac portable phone adapter dongle DNR measurement.png
Shoot, I just realized i did not run the 50mv test. Will do that later.
Filter and frequency response are as they should be:
JCALLY JM20MAX headphone dac portable phone adapter dongle filter measurement.png
JCALLY JM20MAX headphone dac portable phone adapter dongle Frequency Response measurement.png
Multitone shows a bit of weakness in low frequencies relative to superb performance higher up so can easily be forgiven:
JCALLY JM20MAX headphone dac portable phone adapter dongle Multitone measurement.png
Linearity shows a bit of offset but I think we can also forgive that in this class:
JCALLY JM20MAX headphone dac portable phone adapter dongle Linearity measurement.png
EDIT: IMD vs Level:
JCALLY JM20MAX headphone dac portable phone adapter dongle IMD distortion measurement.png
Jitter is one of the best measured for dongles:
JCALLY JM20MAX headphone dac portable phone adapter dongle Jitter measurement.png
Wideband distortion showed very high levels:
JCALLY JM20MAX headphone dac portable phone adapter dongle THD vs Freq measurement.png
A spectrum analysis shows this is due to ultrasonic noise shaping and some high frequency interference:
JCALLY JM20MAX headphone dac portable phone adapter dongle FFT measurement.png
Otherwise, peak distortion is below threshold of hearing.
These are appetizers which are for the main meal of how much power the adapter is able to produce. At 300 ohm, it is very good:
At low impedance of 32/33 ohm, it is mind boggling:
This thing can product current! You can see it just as well in my impedance sweeps:
JCALLY JM20MAX headphone dac portable phone adapter dongle power vs impedance measurement.png
Just remarkable.
It is incredible how far these tiny dongles have come. They are now easily achieving performance of high performance DACs and power that is hard to fathom given their diminutive size. The JM20 MAX further showcases these advancements, producing performance that should be good enough for many people whether you use it for desktop or portable! This is especially so for low impedance headphones. We are in the midst of a great revolution with wonderful IEMs to pair with these dongles!
Reserved for @RickS to kindly post the specs.
JM20 MAX Features:
1.Model:JCALLY JM20MAX
2.P/N:JM20MAX CS43131 High Performance DAC Decoder Amplifier Adapter
3.DAC: CS43131
4.PCM: 32bits/384KHz
5.SNR/DNR: >126dB
6.Crosstalk: -140dB
7.DSD: DSD256 (1bits 11.2MHz
8.Output Load Adaptive: 16 - 600 Ω
9.FR: 20-20000kHz
10.Weight:6.5g±0.5g
11.Length: About 110mm±10
12.Type of wire core: 320 Coils 8 Cores Cable,
13.Color: JM20 MAX Silver
Remarkable indeed.
okay, if i want to ditch my bedside mac with roon and just use my recent ipad mini to output tidal, how do I get a digital output from the ipad mini to this dongle? I listen to truthear reds.
If it's a 6th or 7th gen iPad Mini, then you should be able to plug the JM20 Max straight into the USB-C charge port.
naw, 4th or 5th with lightning. but i have the adapter betwixt the two.
thanks.
thanks.
For Lightning devices, an ordinary adapter to USB-C won't do the trick.
You'll get a pop-up message stating that the connected USB accessory draws too much current.
The solution is an adapter with special MFi chip inside which tells the iPad to supply current to the dongle.
An example: https://www.ddhifi.com/en/product/tc28i-m2/
So, the linearity error does not show up as distortion when playing a fixed-volume sine wave, but shows up when changing the amplitude of the sine wave?
:oops:
EDIT: Found the answer in jkim's thread
Interesting review following the Astell & Kern Kann one: this JCally dongle is just what your phone needs to put many DAPs to shame. Then it’s a matter of preference / convenience—does it work for you?
Thanks Amir!
Coming Soon: One dongle functioning as both DAC and ADC (depending on source/load).
And yes: for $22 to $66!:cool:
Great DAC, mic support (ADC) and DSP (PEQ) dongle all for 38 USD here:
Great to see another sample of this excellent device tested by Amir. A nice confirmation of its unbelievable performance.
This review and mine complement each other nicely as they cover some tests not in common.
To avoid confusion, I added a prefix "(Unofficial)" to my review. :)
Just remarkable.
@amirm don't you have a checklist when you are measuring DACs?
Why no IMD vs level ?
I bought the JM20, really satisfied. This one has 23% more power. I am good still with mine, will look for sales on this one.
