I received my Stargate 2 yesterday and immediately tried it on my pc. It's an older pc, so I had to use a USB C to USB A adapter a cable connected it to my headphone amp/preamp and then an Aiyima a07.
First result, just a blast of loud static. I suspected a poor connection, so I unplugged it from the pc and plugged it into a powered USB hub after checking the connection of the adapter, which fixed the problem.
It worked as expected so I tried to check out the EQ but my older Iphone only has a Lightning port and I didn't have any special OTG adapter for USB C to Lightning. I then tried the pragmatic website with my Edge browser. I was able to get it to connect but most other stuff didn't work. I then tried with a Google Chrome browser and I was able to connect and push/pull data. The only problem left is I can't set the preamp to -4 as required by my EQ. With Edge, one I imported showed it but I couldn't set it. I tried pulling from the tanchjim which then displayed my correct EQ, so I exported the EQ to my pc as a txt file and then opened it in an editor. The EQ was there, correctly, but the preamp was 0 in the file. I tried editing the file to add the correct preamp setting and then imported it and pushed it to the Tanchjim, but when I pulled it back from the Tanchjim and exported it to my pc, the preamp was 0 again.
So, it works but setting the preamp level of the EQ still doesn't work. I'm using a -4db setting in windows 10 until I can figure out a way of doing it correctly. If I had a new Iphone or an Android phone, I'm sure this wouldn't be a problem. I'm not sure if I will waste money on an "Apple usb to lightning camera adapter" or just wait until the website is updated. The actual device appears to be fine, so it's just a matter of time.
). so I need a dongle-dac with PEQ, like that Stargate.
