TANCHJIM Luna Portable HP Amp & DAC Review
Rate this portable DAC & HP Amp:
    Votes: 0 0.0%
    Votes: 0 0.0%
    Votes: 26 13.6%
    Votes: 165 86.4%
This is a review, detailed measurements and listening tests of TANCHJIM Luna portable headphone amplifier and DAC. It was sent to me by the company and costs US $139.99 with anime engraving or $129.99 without:
The look and feel of the adapter is excellent. The controls for volume have different shapes, aiding in adjustment without looking, with great tactile feedback:
TANCHJIM Luna Portable USB DAC AMP Headphone Balanced usb-c volume control Review.jpg
As you see, we have both 3.5mm and 4.4 mm balanced output. Dual CS43198 combo DAC and headphone amps are used. Let's see how it performs.
TANCHJIM luna Measurements
As usual, with this class of device I can't run all of my tests. Let's start with the dashboard using balanced output at full volume:
We are getting (nice) desktop class DAC performance, landing at essential tie with the best tested in this category:
Unbalanced performance is also excellent:
Dynamic range is stunningly good in general, let alone in portable category:
That carries on even when the output is sharply reduced:
TANCHJIM Luna Portable USB DAC AMP Headphone Balanced 50 mv DNR Measurement.png
Jitter performance is just as good:
TANCHJIM Luna Portable USB DAC AMP Headphone Balanced Jitter Measurement.png
As is Multitone:
TANCHJIM Luna Portable USB DAC AMP Headphone Balanced Multitone Measurement.png
Filter response is typical but with excellent attenuation at higher frequencies:
TANCHJIM Luna Portable USB DAC AMP Headphone Balanced Filter Measurement.png
Please ignore the noise level in the following power tests (the height of the graph). Just pay attention to max power and clipping:
TANCHJIM Luna Portable USB DAC AMP Headphone Balanced Power 300 Measurement.png
TANCHJIM Luna Portable USB DAC AMP Headphone Balanced Power 32 Measurement.png
As you see, we have one powerful portable adapter here. I am especially impressed with ability to drive low impedance loads with nearly 1/3 of a watt!
TANCHJIM Luna Listening Tests
I have loaned out my Sennheiser HD650 so started the testing with Hifiman HE400i. The fidelity and ability to drive this headphone was just insane. There was plenty of volume and superb detail and dynamics. Switching to Dan Clark E3 which is less efficient, still produced excellent results but needing to go almost to max volume. On one track, it clipped but on others, it sounded superb.
Objective measurements of Luna adapter shows best in class execution, being tied with just one other implementation of similar architecture. It costs more but it brings a very nicely executed enclosure and controls. Sound quality as predicted by the measurements is superb with ability to drive most headphones out there while being quiet enough for sensitive IEMs. There is simply no negatives here.
I am happy to recommend the TANCHJIM Luna portable headphone and DAC. We have arrived at a new era in portable products, achieving near top-end desktop class performance.
Reserved for @AdamG to kindly post the specs.
Manufacturer Specifications:
Thanks for this review !
When I tried to measure the Tanchjim Space, I was limited to 16 bits.
Is this something similar happening here ?
Obviously, the SINAD values require 24 bits.
But where is this limitation coming from ?
No, it is an issue with AP software. It only supports ASIO. I use ASIO4ALL and for some reasons it corrupts the bits for this entire class of audio.
Wow! Dongle chart busting territory, excellent! Thanks for the review @amirm. I would like to see how the Moondrop offerings getting measured :)
Seriously, though: I wonder if any listener could hear the difference between the Fossi DS2 and this Tanchum which costs more than twice as much. (Is the anime engraving worth a 237% increase in price over the unadorned Fossi, I wonder?)
The Tanchjm produces 1.86 dB more power into 33 ohms, a difference which some listeners could hear on careful A/B listening - just barely.
The Fossi has a a SINAD of about 117 dB, whereas the Tanchjm offers a 116 dB SINAD. I doubt anyone could hear that difference - but if we are judging these devices by SINAD then the Fossi is superior according to Amirm's testing.
I suppose that sometimes it just comes down to price. Price and anime....
Some of my iems have an impedance of 15ohm’s is it possible to include testing for this category?
The Tanchjim Space is already excellent but still they managed to squeeze a little better numbers on the Luna. Impressive!
Also nice to have both options, with our without waifu stuff. I would definitely choose without.
Owning a Space I see no reason to upgrade though. It is still slightly cheaper and smaller.
Luna is a lot more powerful on 32 ohms (263 x 142 mW at the knee), but that is only useful for full sized headphones, IEMs don't use that much power.
If anyone's curious, TANCHJIM Space would sit next to Luna in the SINAD graph (115 vs 116).
EDIT: And there's additional comment from Amir: "In another measurement I saw, it hadn't clipped so SINAD was improved. I will have to follow up with the company and understand what is going on" but I don't know if there was any outcome.
SINAD graph is on full 4V output. Maybe on headphones but for IEMs it is pointless: the 50mV DR graph is a lot more meaningful then.
Out of curiosity: are you using the latest version of ASIO4ALL? It's 2.16 released on June 26.
In the change log the developer writes:
• Fixed regression that would sometimes constrain bit depth to 16 bits only.
Maybe this explains the 15dB jump in your THD+N vs. power sweeps.
I have upgraded many times to no avail. But don't know if I up to that version. I will check.
An astonishingly good device.
Thanks a lot @amirm for this highly appreciated review!
As is Multitone:
Please forgive my stupid question, but the SINAD and FR you obtained is for the DAC and amp together, not just for the DAC? Impressive indeed!
What about output impedance? After being burned by my RME audio interface having a 30 Ohm (headphone) output impedance, causing the frequency response of multi-driver IEMs to be all over the place, I personally consider output impedance to be one of the most important criteria in such a device. Much more important than the imperceptible difference of 120dB vs 100dB vs 80dB SINAD, a 10dB frequency response error (which is about what happened with the ZERO:RED on my 1000€ interface) is an absolute dealbreaker.
I couldn't find this stat anywhere... 32Ohm performence gives an indication that it's low, but not knowing it is like buying a cat in the bag.
I use FlexASIO all the time and it works like a charm for me, much better than the endless struggle ASIO4ALL put me through.
The only time FlexASIO let me down/produced unpredictable results was when I was trying to embed a Dante device over DVS.
