So this means I preferred the wire over the SET (?).My results.
For preference, I preferred the non-rolled off ones.
YesSo this means I preferred the wire over the SET (?).
Yes! Picking the 300B set all the time isn’t bad. It’s more that @JSmith could hear *a* difference consistently. @JSmith might not prefer it with real speakers or with other music, etc.I reckon @JSmith may be a hero for getting it on earbuds.
It means you preferred not clearly rolled off treble and low distortion over higher distortion and rolled off treble.So this means I preferred the wire over the SET (?).
Probably so. I am not sure what the lesson is in the end. Just testing my JND levels? By principle, I don't like sources, preamps or amps that drops in the 10-20 kHz range (which can be seen quite often). Even if each separately would be inaudible against wire, they could well add up to audible degradation when combined.It means you preferred not clearly rolled off treble and low distortion over higher distortion and rolled off treble.
What you heard is not 'typical' SET sound as that is generally more speaker dependent but instead to measurably and even audible degraded sound.
When does it start to roll off? I hear up to around 14 kHz. There is perhaps a graph in the thread that shows how the FR looks regarding Group B. Alternatives 2 and 5 that is.Interesting, as for me it was the exact opposite.
I had no problems hearing the treble roll-off in 2-5 and had harder time with the other 2 (wrt to roll-off). In those I heard poorer sound quality (grittier/rougher sound) but not so much the rolled-off treble, yet not in 2-5. There the sibilance was the give away. Perhaps I am more sensitive than others in that sibilance frequency range.
I decided to listen using speakers, as that is my preferred way of listening. I picked the Topping for the first and second, but the SET for the third. I really tried to pick based on preference for the track I was listening to rather than by listening for any particular tell. I honestly could barely tell a difference for preference and I wouldn’t say I heard hum in either.Thanks again for setting up!
Now that I can elaborate without spoiling the fun, some of it depended on familiarity. I don't listen to prog rock or mainstream jazz so found the third pair hardest (the first pair had a tell) and the second pair easiest (I do listen to spoken word stuff, like Laurie Anderson or La Dispute). The opposite of the group as a whole, where most differentiated the third (jazz) pair and fewest differentiated the second (spoken word).
I used two pairs of (non-cheap) headphones (wireless Air Pods Max and wired Sony Z1R) to hear everything. The Sonys gave the bass definition and AirPods the treble (for the first and second listening choices respectively) to hear the relevant distortion. The AirPods were best to hear the noise (both choices). For the third pair I found both noise and distortion were masked so differentiated via treble roll-off. So while I already knew the answers and couldn't do it blind again I don't think I would have differentiated the third pair with the treble-adjusted files that I listened to later.
I reckon @JSmith may be a hero for getting it on earbuds. Also, I did get why some would prefer the tube sound especially on the second pair (where it had more 'warmth and character' but less 'clarity'). For those of you with high SINAD gear who didn't differentiate (as opposed to preference) at least the first two—wasn't the hum unmistakable?
And finally, yes a taste of 300B SET sound but not the whole picture. Hopefully someone can do that next.
I should have heard that deviation. Weird. Maybe I concentrated too much on the bass lines, or I'm bad at detecting differences. If it's the latter, it has its advantages. Then I don't have to spend any money on HiFi because it is then wasted money, heh heh.orange trace (measurement GXAlan):
As you can see the FR changes to a tilt in the treble when he connected his speakers.
Verified by pkane:
Then I don't have to spend any money on HiFi because it is then wasted money, heh heh.![]()
I also have limit around 15 kHz and at age 55 I guess that is quite good. The thing is that music is another thing from pure tones due to masking so it is always harder. For the frequency corrected files made by @solderdude I could no longer hear anything in the treble. It was rather the bass tones that had a different timbre.When does it start to roll off? I hear up to around 14 kHz. There is perhaps a graph in the thread that shows how the FR looks regarding Group B. Alternatives 2 and 5 that is.
Tinnitus, actually maybe. Sometimes I hear a persistent beeping, but at a low level. But it comes and goes. Mostly no beeping sound at all. I will talk to my doctor about it.I did not perceive A and C as clearly rolled off in the treble but rather heard 'less smooth' sound.
In B the give away was sibilance level. This is in the 6-8kHz range and sharpness of sound (8-12kHz) range. Whether or not one has tinnitus in that part of the frequency range can even mean a difference in sensitivity.
Might also have to do with the used transducers and how that reacts with the room/ears whether or not that 'stands out'.
Taste can also play a role.
I listened with low distortion gear and headphones that have no peaking and low distortion at 'active levels' and while being 'relaxed' and with about 30 years of 'critical listening' experience (looking out for distortion and FR anomalies and hate it when not close to perfection).
Sometimes I am baffled by what others hear and I don't or vice versa.
About wasting money..
One should spend on audio what one can afford and likes (in all aspects). In those cases I never see it as wasting money. Placebo or not does not really matter. It does matter from a value or reality/science standpoint though and dislike 'obvious snake oil' but.... if a buyer gets more enjoyment then it might be worth it to them. People should be warned for 'wasting' money but in the end have to weigh for themselves if something is worth the money to them.
I think the one really useful aspect of this is that it explodes the 300B myth. There is so much rubbish talked about tubes and the 300B in particular that I’m sure some have been hoodwinked into spending lots of money on an expensive 300B amp to hear what the fuss is about. Anything that can prevent such a waste is a social good. ...
