Yes, just cones without any idea of how to get a good coupling with the speaker cabinet is just snake oil. It is similar to grounding in electronics. Which by the way is another area where snake oil flows in abundance.Spikes are nothing else than snake oil, IMO.
Seems like my gut was pretty accurate - i.e. if it's sitting on a poorly coupled shelf in an empty, non-braced entertainment center with brass hardware... decoupling provides some nominal insurance against additional resonances... while doing exactly nothing in regards to the speaker enclosure itself. On the other hand with floor-standers out in the room, spikes don't cause enough harm to justify an exotic seismic solution which likely costs more than my speakers themselves - while somewhat preventing accidental damage. Although I should probably make/buy some cheap outriggers for more stability in that regard.
Also don't listen to music while experiencing an R4+ earthquake... wait until it finishes.
Well my problem stems from the speakers being tall, narrow, and slightly top heavy - but with tiny little feet. So on my thickly padded carpeting, they aren't stable without spikes - so they're a structural solution without a significantly deleterious effect on the sound. That's why I'm considering better outriggers. Then they wouldn't be nearly as "tippy" in my room and I could just use them without spiking.
Fantastic idea!Is that so? My speakers have 17kg each and even when driving them with full power and put a glass of water on their top the surface stays calm. I suggest you try this simple experiment before making statements like this.
Fantastic idea!
While on this topic of decoupling, and isolation, do magnetic floaters/isolators work well in this regard ?
Never tried one, but their physical behaviour may be comparable to springs. Both don´t seem to be as common as elastic matter with higher velocity damping characteristics...
I see where you're coming from as that would be the absolute ultimate in isolation as the speaker would literally be floating in the air.
But...
You would then need some sort of bracing to hold the speaker in place as the magnets would be continually opposing/repelling each other which in itself would cause stability issues.
Also, if a speaker is floating freely in the air, the movement of the drivers would cause the cabinet to move as the drivers are physically attatched to the cabinet.
Every action has an equal and opposite reaction.
The cabinet MUST be secured in some way for it to work.
Imagine a speaker floating in a weightless environment and you start playing music through it, it would be rotating on its axis like crazy with the sound pressure waves coming from the driver and the air being emitted through the reflex port.....
Of course, if it was a weightless environment like space for example where there is no atmosphere, the the drivers won't play as there is no air to create the pressure in the first place.....
God that's a rabbit hole I didn't think I would be going down this morning...
Just my thoughts on that...
But...
From a physics standpoint, using magnetic floaters, its possible to isolate the vibration transmission to just 1 plane of motion.
From what I have seen of floaters, they are usually encased in cylinder sliders, thus when loaded, the only physical continuous contact between the ground and the speakers / casing is the vertical side sliders lining the cylindrical encasement. Thus any physical force transmission is restricted to only the horizontal plane.
They are not quite the same as springs as springs do provide a physical vertical path of transmission for vibration / force to the ground if these vibrations are small enough in magnitude not to deform the springs any further than their deformed state.
That's just my understanding based on physics. How well that works in reality is not something I have tried, hence my question here.
Isn't the problem with magnetic suspension that it doesn't dissipate the energy in any way as there is no friction?
True but that's what the bass reflex port is for.. The heat and air that flows out of mine is crazy...
