Sabaj D5 - Owners' Thread
renaudrenaud
Tianjin
If you totally switch it off, how could you switch it on again? Reset?
Maybe it is time to create a wishlist for a future firware update:
- more than 40 steps for volume
- switch off totally, switch on when receiving remote command
Mr. Olinad
Guarulhos - SP
I received my update tool today (two by the way).
Updated from 1.2 to 1.4.
Even though I never had a problem with my unit, like those mentioned by @jruser at post #7, it's good to be updated.
By the way, did anyone had access to the improvements that were made for each version?
renaudrenaud
Tianjin
You mean a changelog. I suppose they have it for the company but it is not public.
NTomokawa
Does the volume control work for the XLR outputs?
Malis
Yesterday I got the D5. I want to thank this forum for the good reviews and now I have my first DAC to use my Hifiman 4XX with.
My Firmware version is 1.4 out of the box.
For now I can not seem to have the ASIO running with the original drivers but I hope I will figure it out somehow.
Very good first impressions and it seems that it has a slightly better sound than the Cambridge DAC Magic that a friend of mine lent me for a few days.
renaudrenaud
Tianjin
I understand the driver for Windows is an ASIO driver.
Uzst3DhDITX63_G-Q2iFIXRvtqLoMs4p0zSICo-AsBMAvXTZp1IovN9dn5LhYeTDs0J6K8KIecfWrXMqoxQTpJ4bjcdeNCxTGjmDkmlxh7Bsn8GdPAo2=w1280
DAoydjqOyCWzcN4wViO4KIZOpvsgIykebg26SmSTAUGZgAapTcecPa0fION7vy4D5zEbp3wU-4D5r2XMeLWKA7g1VxrQqOEH_dF-nJ-Ugnrdk-meMw=w1280
Raducub
Hello guys. I have just bought a D5 and I need to confirm two things:
1. Does every unit have sound leakage? I have output set on headphones (SE) and i can hear what is playing in the speakers (connected via RCA line out).
2. I have micro stutter when input is Optical and signal is coming from TV.
Cany any of you do similar tests?
renaudrenaud
Tianjin
1. Yes
2. Not sure the clock or everything else is ok from your TV. Nothing wrong with the optical input and my phono ADC to Sabaj.
Raducub
1. Yes
Thank you for the reply. I will do some more testing, maybe try a different cable. The stuttering is incosistent. When audio is sent from PC via HDMI ARC, TV audio set to optical out, no problem. Only regular TV signal seems to have the issue.
soicjensen
Hi guys,
I am about to buy D5, but I am curious about its topology.
As usually, there's a 24MHz XO or something like that for XMOS DSP; and 24/22.XXX MHz for CPLD. These are quite within expectation and very typical.
What I am curious is that where the 100MHz for ES9038 is?
From teardown photo we can see there's a ES9311 LDO for ES9038, but no 100MHz oscillator.
Is this crucial oscillator located at the bottom side? or the Sabaj D5 use some other tech so that this XO is not needed?
Also, still $46X USD on the Amazon, I saw somebody get this for just ~367 USD, that 100USD saved! Waiting for sale!
eziitis
according Sabaj :"Ultra-low phase noise NDK Japan crystal oscillator and high-speed CPLD is used for clock processing"
so ir seems the XIN is generated by Altera.
eziitis
actually I wonder whether D5 utilizes all 4 dif outputs in parallel per a stereo channel? and does it run in asynchronous or sync master mode?
soicjensen
Thank you, that reasonable.
However, I also wonder which way is better, a synchronized frequency or a high-grade XO like CCH-957 and NZ2520SDA?
Why do Sabaj use Altera? For lower jitter or lower cost?
soicjensen
Can owners of the Sabaj D5 tell us, which NDK do they use?
Is it NZ2520SD or NZ2520SD"A"? As we know, SDA is better than SD, and CCHD-957 at all frequency range.
gto88
US
I have Sabaj D5, and it is good, and I did some comparison with other ES9038Q2M dac, D5 is apparently better.
