- Thread Starter
- #21
Rechecked.Also turn the subsonic filter ON. That will capacitively isolate the volume pot.
Subsonic ON/Off has no impact on the measurements. Louderness does.
This appears to be the juice you need. Make sure you get the little tube/hose thingy for it because you're reallly going to need that... It is essential.this is the shop I used for caps. no have no other options, either this or amazon.co.uk. Have a look, anything from here?
you must be joking but even as unskilled as I am, in cleaning I am not likely to confuse the pale ale and the Isopropyl AlcoholIf you don't mind immersing the entire amp in hot water to melt the dried out beer and then doing the controls clean and lub anyway fly at it...LoL.
haha... I'm enjoying today's chatter at ASR... So much going on and it's all very fast and good stuff.you must be joking but even as unskilled as I am, in cleaning I am not likely to confuse the pale ale and the Isopropyl Alcohol![]()
so, the very serious question is still open
Please refer to this post and follow the instruction..LoL.View attachment 357147
The wire circled in pink is the right volume out. Green is ground. Blue is left volume. Measure pink to green. Loudness OFF, subsonic ON. Measure blue to green for comparison.
R and L are not marked in the schematics, the channels are called a and b - so I might have left and right reversed. Turn the balance knob to check. If you turn it all the way to left, the green pin resistance should go down.
I did. Channel b is right channel. The wire marked blue is R, the one in pink is L.so I might have left and right reversed.
R and L are not marked in the schematics, the channels are called a and b - so I might have left and right reversed. Turn the balance knob to check. If you turn it all the way to left, the pink to green resistance should go down.
Resistance between | at Volume 0 | at Volume 20 | at Volume 40 |
Green (Ground) to Pink | 3 Ω | 8.72kΩ | 32kΩ |
Green (Ground) to Blue | 98 Ω | 9.11kΩ | 34kΩ |
4<--->3 (Green to Blue) | 2.2k | 15k | 37k |
Haha... You are too much! RFLMAO.. Well done for now... Make sure you get all that India Pale Ale out so it does not gunk up the works and use some proper control cleaner and lube to get everything spotless inside. Hahaha.. You're a classic.More often than not, my impatience plays bad jokes with me.
I thought this was the case now as well.
What I did: I quick googled that IPA, if not diluted with water, although not as efficient as DeoxIt, but may help. So I took a tiny straw like 1mm dia, immersed into a bottle with IPA and put a finger on, then released into the potentiometer and rotated for a while. It evaporates quickly from the surface, but I also helped evaporation with a fan on mild heat.
I thought, why not, in the worst case I will get a replacement from aliexpress for 5 euro
It's a different measurement now.
Resistance between at Volume 0 at Volume 20 at Volume 40 Green (Ground) to Pink 3 Ω 8.72kΩ 32kΩ Green (Ground) to Blue 98 Ω 9.11kΩ 34kΩ
And it works! There residual sound is nearly nearly gone (maybe not as new, but one would only hear it in complete silence 30cm from the speaker)
Congrats! That shoild do it - button it up and have a beer!More often than not, my impatience plays bad jokes with me.
I thought, why not, in the worst case I will get a replacement ponetciometer from aliexpress for 5 euroIt looks exactly the same as in 1980s Denon
compare with my measurements before IPA cleaning
4<--->3 (Green to Blue) 2.2k 15k 37k
I'm glad you can glean stuff from @Zapper's far out circuitry analysis because he often went over my head that's for sure...LoL.. Have fun!@Zapper to understand those explanations in posts #6 and #8 will be my homework for next days![]()
Guinness is delicious although I prefer a very dark (Like 6 fills me up goody goody.) caramelly Old English Porter that goes well with pickles and fudge cookies at the same time. Try it!@Doodski not IPA unfortunately, but Guinness is waiting![]()
I'm staying in my lane and expecting a fascinating technique of explaining the answer by @Zapper.BTW why at full volume we are not reading 100k resistance but just 32k/34k? the pot is indeed 100k with marking on it.
Feel free to ask questions.to understand those explanations in posts #6 and #8 will be my homework for next days![]()
Because the top of the resistor isn't open, or shorted. It's connected to the preamp via an active switch (IC3). When the amp isn't powered this will present an undetermined resistance. So what you are seeing is the resistance of the pot, in parallel with the undefined resistance presented by IC3. In addition there are NPNs TR4 and TR5 connected to the signal path. I haven't figured out exactly what they are for, but they appear to be part of bias circuit. You may see the measurements change while you are taking the reading, as the current from the DVM can build up charge in the circuit and turn things on and off.BTW why at full volume we are not reading 100k resistance but just 32k/34k? the pot is indeed 100k with marking on it.
TR4 and TR5 are used to mute the signals when switching inputs.In addition there are NPNs TR4 and TR5 connected to the signal path. I haven't figured out exactly what they are for, but they appear to be part of bias circuit.
There are two ways I see to take IC3 out of the picture. I've mentioned the first one already - turn on the subsonic filter. Second is to switch the input to either of the tape playback inputs. You can try those things and measure again.
With IC3 and TR4/TR5 in the circuit, the direction you connect the leads of your DVM may matter. Try reversing the connections and see if the results change.
Thanks again, more food for thoughtsTR4 and TR5 are used to mute the signals when switching inputs.
