Right, but how would these affect actual measurements?
John most likely, just like me, has seen many eye-patterns while adjusting the focus, tracking, laser power of CDP's
The true test discs (I still have some Technics test discs that were lightly scratched) have excellent (exemplary even) eyepatterns.
These test discs can have deliberate 'optical errors' that can be used to check tracking/focussing.
Such discs must have an excellent eye pattern which is important when adjusting/repairing a transport.
They will not have test signals an analyzer uses but usually only some basic frequencies, sweeps, test music excerpts and some other test signals.
Once you've seen what eye-pattern comes out of a CDR(W) disc it is amazing some older CDP's could actually get something meaningful out of those discs.
It also explains why older CDP's will not play CDR let alone CDRW.
One would not believe how poor some pressed CD's are (eye-pattern) as well, even when pristine looking.
This is a decent one, test CD's usually look less 'fuzzy'. Any CDP should have no troubles reading such a disc.
That said, laser pickups, electronics and mechanics have improved over the years and so most transports these days have no problems reading CDR's.
So... when such a transport is used with a home burnt sweep or test signals the results will, very likely, be just as good.
For a repair guy such discs are unusable as CDR are no reference for the optical part. Some CDPs are very lenient to 'disc quality' others less so.
The very lenient ones will play test signals just fine as long as the readout part is in decent shape.
So from an engineer/service p.o.v. CDR's are worthless (unless it is to check if a repaired player can actually play such optical horrors) and real test CD are essential.
In your case the test signals are, given your test results, more than good enough and original discs, if they even had the needed test signals, would not give better results.
