Ralph_Cramden
- Joined
- Dec 6, 2020
- Messages
- 3,518
- Likes
- 5,205
Renderings of the Ultra. (Touch) Display and (probably) headphone jack.
WiiM wants to cover as many target groups as possible.Curious about the phono input. While I get that someone may want to hook a turntable up to this I'd also imagine that person already has a phono pre or a turntable with a built in phono pre
I wouldn’t assume that person even has a turntable yet, let alone a phono pre-amp. If you look at for example Reddit you’ll see a regular stream of advice requests from people putting together systems with a vinyl component from scratch. Given the current popularity, I think it’s a smart move on Wiim’s part — though would’ve been neat if there was a switch to select phono or line input (perhaps there is? I haven’t read up on it) for that set of RCAs.Curious about the phono input. While I get that someone may want to hook a turntable up to this I'd also imagine that person already has a phono pre or a turntable with a built in phono pre
No improvements whatsoever. Regardless of whether you're using a separate DAC or the built-in one.What do tou think of adding linear powee supply, Topping P50, for example? Can I expect any improvements if using as a streamer with separate dac?
And if he still want to test after your answer then I would try to by a used LPSU that he can sell for the same money. Sure he have wasted some time but that can be considered a hobbyNo improvements whatsoever. Regardless of whether you're using a separate DAC or the built-in one.
???Is this really necessary considering that Amir's test indicate that the DAC of the Wiim Pro Plus is "transparent" for the end user?
Actually, these are mine.Amir's measurements (Page 1 of this threaad)
Thanks for pointing this out, @antcollinet. This time I forgot to mention this disclaimer.Whatever you think you are achieving with your mods - it is not going to improve the sound quality in any audible way.
Sorry, you're right, I'm also indebted to you as I purchased my Wiim Pro Plus after reading your review.Actually, these are mine.![]()
I'm actually a bit annoyed that, whenever topics are discussed "just for the sake of engineering" (i.e. not audible), the same stereotypical phrases, "transparent" and "not audible," pop up and try to put an end to such discussions. Even adding the disclaimer "certainly not audible" doesn't help (this time I forgot to mention it — it was just too obvious to me).Is this really necessary considering that Amir's test indicate that the DAC of the Wiim Pro Plus is "transparent" for the end user?
My sincere apologies - corrected.Actually, these are mine.![]()
