Nord's implementation is Bad! Quoting my buddy Mike from Mivera audio :
I can't believe he's using cheap Chinese unshielded what appears to be 18-20g AC mains wire. But that's not the worst part. He's running the hot (brown wire) not only through 10-15x the amount of cable as the neutral, also through a very high loss, low current capable push button switch on the front panel. Those tiny low current contact in that switch are not designed for this kind of current. Then you can see that cheap IDE ribbon cable that was designed for old school hard drives, CD drives and floppy drives carries the super noisy aux power from the Hypex supply to his buffer board. The Sparko opamps (which were the worst sounding 990/2520 format discrete opamps I ever tested) are installed in his buffer.
And the Sparko regulators share the duty of powering them and the modulator board that is sticking up on the side of the Purifi module. On the Puribuffers that board gets its own dedicated dual supply. Same with my gain stage. Speaker wire looks like Neotech copper which is good. But nowhere in the league of the OCC silver. And at 10x less cost it should be expected. Speaker binding posts are Chinese brass, with tin ringlets tightened on with brass nuts.
But guess what, not a single person besides me would ever notice any of those things. And the worst part is the
Purifi modules themselves, are going to be judged based on implementations like this or worse.
