Power Cord For Amp - do volts matter?
dman777
I want to replace my power cord on my Luxman 595 class A amp with a upgraded one. The voltage currently stamped on the cord is 300v. I only want to spend about $100.00, but the ones I have found so far have not gone up to 300v. There was one I liked but it was 125v. Is that going to be a issue? What does that mean exactly? Also, I live in the USA. Should I care about the amps rating on the cord?
fpitas
Northern Virginia, USA
Upgraded? In what way?
D
dman777
I mean replace the power cord.... I want to get one that is thicker gauge and more high quality than the one that came with.
fpitas
Ok...why? Luxman appears to know what they're doing.
pablolie
bay area, ca
The word "upgrade" when it comes to a power cord kinda raises my eyebrows, honestly. Is it because you need an extension? No power cord ever will ever make the slightest difference in any way - be it sound or current quality or safety. It may actually degrade any of those if it claims to do anything fancy and special. It's a bit like thinking an upgraded remote will make equipment sound better...
Purité Audio
Industry Insider
Barrowmaster
London
fpitas
fpitas
If it's any help, when Nelson Pass is asked that same question he says he knows of nothing better than his supplied Belden cord.
D
dman777
Ok, here is the story.... I have 2 amps and I got my power cords mixed up shuffling my amps around. One cord is 14 gauge and the other is 16 gauge. I can't remember which one goes to which amp.
So, I called the official Luxman service department in the USA. The guy told me he recommends at least a 12 gauge thickness no matter what was sent with the amp.
If you could please help me understand the power cord voltages and why it would matter rather than heckling me for buying a new power cord amp.
DVDdoug
I'm sure you know there is 120VAC at your outlet. The voltage is always there (assuming the outlet is not switched). Current (Amps) only flows when you plug something in and turn it on. If you plug-in two toasters or two hair dryers you'll get excess current, blow the circuit breaker, and the voltage will go to zero until you reset it.
And you might have some 240V outlets (with different sockets) for a clothes dryer, or electric range, etc.
If the voltage is too high you'll get arcing ("sparking") through the insulation between the conductors, or out to your body if you were touching it, etc. In reality, you probably wouldn't get that with 1000V, but the regulatory/rating agencies & standards are "careful" & "conservative".
In theory, you could have excess current through the cable. In that case it would overheat (usually at the plugs/contacts where the resistance is the highest) and it can start melting or burning and once the insulation melts it can short which would "pull" more current and blow the breaker. By that time it's too late. :p But, any detachable power cord will be rated for the full 15A of a standard wall outlet so the power cord is not the weak link.
The gauge does affect current carrying capacity, but again, any cable will as much current as the socket can put-out without blowing the breaker.
The resistance in the cable is directly related to the gauge (wire diameter) and length. When current flows through resistance you get a voltage drop. A 100W light bulb at the end of a 100 ft, 16AWG, extension cord will probably get (nearly) full voltage. But if you add a toaster or hair dryer at the far-end, the voltage will probably drop enough to see the bulb dim slightly.
Since most amplifiers have regulated power supplies, the internal DC voltage usually remains constant over a wide range of input voltages. There are a lot of amplifiers (and other equipment) with "universal world-wide" power supplies designed to operate between 85 and 300V (or something like that).
Practically speaking, it doesn't matter. But the amplifiers should be marked on the back with the voltage and the current and/or wattage. (This is not the same as the output power to the speakers because no amp 100% efficient and as you probably know, class-A is the least efficient.)
You can use the lower gauge (thicker conductors) on the amp with the highest power or current requirements. Power (Watts) is calculated as Voltage x Current if they are marked different from each other.
MaxwellsEq
In general wire gauge does not have a relationship with the voltage, so much with the current. Higher gauges can handle more current. The insulation needs to be able to handle the voltage. Anything that has passed a safety test will be fine.
voodooless
Netherlands
12 gauge should be good for 2200W, I’m sure the Luxman will not draw that much. Your house wiring is probably not more than 14 AWG, so there is no point in using more than that for the cable.
Just use what you have, it will be just fine.
Killingbeans
Bjerringbro, Denmark.
From the amp specs:
Rated output: 30W+30W(8Ω), 60W+60W(4Ω).
Power consumption: 310W, 230W(no signal), 0.4W(standby).
So... at worst case 310W. At 120v that's only ~2.6A. A walk in the park for any standard power cable. No need for anything beefy.
D
Deleted member 21219
Guest
Was his name "Danny"? :p
Jim
fpitas
If the cable is UL listed and has American plugs you are good to go.
That's your best bet. Get 12AWG if you like. Belden is a safe bet if you need a brand.
ban25
I'll just say this: if it's not UL-listed, it could burn your house down and kill your family.
fpitas
And uh...UL sonically tests every cord before it gets approval.
/Work with me here, guys
Speedskater
Cleveland, Ohio USA
I hope you don't need an amplifier serviced by him!
Lets see. a power cord may be 6 feet long. And that cord and the cables back to the big power company transformer might be 600 feet long.
It's a series circuit, so making 1 % of that circuit heaver won't accomplish much..
