Roland68
As said, it is an easy to check possibility of the error cause. Of course it doesn't have to be because of that.This is misinformation and messing around with replacing perfectly good capacitors is not going to solve anything.
The capacitors will not be the problem and capacitors do not fail after 2000-3000hrs at 85 degrees celscius.
see here:
Home
www.nichicon.co.jp
After 30 years of experience with such problems in industry and high-availability IT technology, I can assure you that exactly such problems occur, especially when companies are not familiar with such problems.
Is Nichicon's data wrong?
Of course, the following must still be taken into account:
- Smaller capacitances have a shorter service life at high temperatures
- The low load on these capacitors (only in the signal path, very low voltage) further reduces the service life at high temperatures, since the chemical process in the electrolyte is not sufficiently activated. In addition, there is at least 80-90% idle time without any load on the capacitor at a possibly high temperature.
This is also not conducive to the service life.
All the points listed above together could reduce the service life significantly, even at lower temperatures.
And again, it doesn't have to be because of that, but if...
My first intention was the D-01 Black Box. Does anyone know if the circuit is just encapsulated or encapsulated?
