Steve Dallas
- Thread Starter
- #121
Now hold it. I paid you $1 per word the last time. I'm out of cash.
Eh. If that were true, this pair would have cost me -$630,774.59. Methinks I have been ripped off!!!
Personally, I like the looks of my high gloss BMR walnut cabinets with white woofer better. It looks classy to me. But if you close your eyes they both sound the same!
Although I agree, I guess the white can be a little distracting for HT unless you use the grills.Personally, I like the looks of my high gloss BMR walnut cabinets with white woofer better. It looks classy to me. But if you close your eyes they both sound the same!
Home Theater Subjective Review
I had planned to take a lot of measurements of the BMRs in the home theater application, but I simply ran out of time. What I did manage to accomplish is dropping the BMRs into a menagerie of unmatched speakers to see how they would perform. This is somewhat interesting, because there is no matching center channel available. One could perhaps talk Dennis into selling a single Mini Monitor to be run standing up and get something near a match. Perhaps.
The BMRs excelled there as well, because of course they would.
THE END
BMR vs Acend Sierra TowerHere's a puzzle for you. Which speaker is on the left and which speaker model is on the right? The only image you have as a clue is the tweeter of each one shown below. ;-)
Speaking of the woofer - this is a 6" woofer while the f206 uses a similar but not identical 5.25 for mid and 2x6.5 for bass. How then does the BMR go lower? Is it all about the port tuning? It's not like the cabinet is bigger for the BMR.
Subjective Listening Results - Media Room
Now, I will channel Zeos and stop cleaning my house, err... I mean play This-OR-That (ignoring cost):
- BMRs or Revel F206s - F206s
- BMRs or Revel M106s - BMRs
- BMRs or KEF R3s - BMRs in wide directivity applications, R3s in narrower directivity applications
- BMRs or JBL 580s - BMRs
- BMRs or B&W N805s - BMRs
- BMRs or B&W N804s - BMRs
- BMRs or Dynaudio X18s - Hahahahahahahahaha! Be serious.
I'm currently debating M106 vs BMR. Can you please provide any details on comparing these two directly? Do you currently own the M106's, or are you comparing from memory? Thanks!
I have one sub, but it's low quality so I'm not expecting much from it. I'd like to not use it unless needed or for an occasional rock/electronic session. I will be using these for near field listening (primarily music listening). My main speaker requirements are 1) no EQ required, sound great out of the box (though EQ may help), 2) no sub required (for most music), 3) sound great near filed (at least good elsewhere should I decide to move it later), 4) $2k budget, 5) not bright or fatiguing (neutral preference, slightly warm ok). These will be powered by a Purifi amp.Do you have subs? There's a pretty substantial difference in low end extension in favor of the BMR. Because I have two subs I ended up going for a used pair of the M106 .
Yeah, I would not last a single minute with that crooked tweeter. Allthethings must be plumb and level around here!
Speaking of things around here, things are happening around here...
You want measurements? And words? You will get many of both!
Near-field I would go with the Revel over a 3-way using a vertical ribbon.I have one sub, but it's low quality so I'm not expecting much from it. I'd like to not use it unless needed or for an occasional rock/electronic session. I will be using these for near field listening (primarily music listening). My main speaker requirements are 1) no EQ required, sound great out of the box (though EQ may help), 2) no sub required (for most music), 3) sound great near filed (at least good elsewhere should I decide to move it later), 4) $2k budget, 5) not bright or fatiguing (neutral preference, slightly warm ok). These will be powered by a Purifi amp.
@Jmudrick @Steve Dallas @Dennis Murphy Thoughts? I see the spin data at Erin's BMR and compare to @amirm M106 data, but the current BMR is now improved so direct comparisons are not exact. I've heard neither in person so I can't comment. I'm coming from a pair of HSU Research HB-1 MK2 and a Dual 10" car sub.
i'm anxiously awaiting your opinion of the bmr's/revel's in your media room, when you actually move the new bmr's to where the revel's are, and move the revels to where you had the roadshow bmr's. after sufficient break-in, of course.
doug s.
I hope you are not holding your breath... Break-in could take YEARS! And I haven't even started swapping cables yet!
Why would there be any difference?
i'm ok w/100 hrs break-in. no need for anything more complex than what you did w/the roadshow pair. i only wish you'd done the speaker position swap w/the roadshow pair - curious if there would have been any differences.
doug s.
