Alice of Old Vincennes
- Joined
- Apr 5, 2019
- Messages
- 1,696
- Likes
- 1,124
Why buy MTM? Everyone knows inherent problems. Upright, sideways or corkscrewed to a dart board.
I assume you're equating restricted vertical dispersion (when oriented vertically) as a "problem." And it is if you're standing next to the speakers. But at a normal listening position, many would consider that "problem" as a virtue or as benign. I don't think this is a settled issue, but I also don't think you should be so dismissive of the MTM design, as least not when the speaker is mounted vertically.Why buy MTM? Everyone knows inherent problems. Upright, sideways or corkscrewed to a dart board.
I remain dismissive. Just don't like the design.I assume you're equating restricted vertical dispersion (when oriented vertically) as a "problem." And it is if you're standing next to the speakers. But at a normal listening position, many would consider that "problem" as a virtue or as benign. I don't think this is a settled issue, but I also don't think you should be so dismissive of the MTM design, as least not when the speaker is mounted vertically.
Here we go again…. This is an Arendal review thread, not X speaker is better because the spec sheet says it so.See this.
Facts are Adrenal has been sending out review units left and right to any and everyone on social media so it's not shocking there is a lot of hype built up. Like I said before, I don't fault them as a business for doing such at all.
I've only been pointing out speakers that cost much less that have better specs on paper. If we want to compare apples to apples, the PSA MTM-210 certainly would clown on the 1723 Monitor and there's two models of it with various finishes, and both cost less.
Perhaps there are good use cases for the 1723 THX, but clearly it's marketed for HT and falls short of what THX is suppose to represent.
How many times does it need to be said, you are comparing random spec sheets with Klippel NFS measurements. Absolutely pointless and offers nothing to the discussion besides ‘X speaker is cheaper and it’s spec sheet says it handles more power so it must be better value for money’. I’ll repeat it again for you, powerhandling specs need to be combined with distortion and or compression tests for them to be useful.Again, if people are going to proclaim a speaker has good value, it's reasonable various speakers can be contrasted. You have another agenda if you find fault in that.
And of course we all value different things. I never slandered these speakers and in fact previously posted that I think they are a good value for what they are; nice looking speakers with good measurements, return policy, etc. But, I do think they fall short on the ability to play at THX reference levels and they aren't unicorns.
Brilliant, share some links of compression/distortion tests for the rest of the speakers you are linking.I shared a link with testing that found 1723 Monitors compressing near 90 dB...
See this.
That's fine to not like but not perhaps not ask 'why' when design advantages are well documented. All designs have pro/cons.I remain dismissive. Just don't like the design.
You are making assertions with no data to support. It's ok to express feelings but not as facts as you assert. This is Audio Science Review after all.Again, if people are going to proclaim a speaker has good value, it's reasonable various speakers can be contrasted. You have another agenda if you find fault in that.
Depends, what are your FL and FR?This or (1723 s) vs revel m106 for a center channel? I would have to use the arendal horizontally until I have a dedicated space and then I would run it vertically.
Hi, what kind of Triad speakers do you have? Triad Gold LCR? I am trying to decide this speakers or Triad Gold LRC in-room ?That is one of the contenders to replace my Triads.
Right now I have Polk r200s as my mains. But I want to upgrade those to either the revels or arendal depending on which I get for the center channel. It’s so hard to decide because I’ve heard so many good things and reviews for both brands.Depends, what are your FL and FR?
I have the Triad InRoom LCR Gold's, 2 LCR's their Gold center on Triad pedestal's and 4 OnWall Gold surroundsHi, what kind of Triad speakers do you have? Triad Gold LCR? I am trying to decide this speakers or Triad Gold LRC in-room ?
note: I can get triad at dealer costs via wify.
are those thx requirements applied for one single speaker or for a whole 5.1 system?I suppose there are not too many speakers that capable of passable distortion results at THX criteria, so you'd only need to run the eg 106dB sweep if 96dB was acceptable/good and/or it was rated for high output like you mentioned....so I'm imagining most reviews by definition wouldn't include the 106dB test. (Previously I had thought 96dB for 1m would be insanely loud in most situations, but given that I listen at nearly 4m I worked out earlier that my JBL 308p Mkii speakers are likely outputting a max of around 94dB at 1m at my rarely used absolute maximum listening levels (if I use 12dB to convert from 4m to 1m), and I don't listen that loud in the scheme of things, so it just seemed a reality check for me of putting the fact the distortion measurements are only at a very close 1m).
All 1723 and 1723s speakers are. The subs are not, there has always been a question on the subs since they seem to meet THX specks that the company just did not want to pay for the certification. (But then why pay for the others). Bottom line is they are great speakers that perform as great on music as they do on HT.are those thx requirements applied for one single speaker or for a whole 5.1 system?
