- Joined
- May 27, 2020
- Messages
- 552
- Likes
- 461
i would give cat litter box no longer would buy onkyo lousy hdmi in the past and there THX is plastic toy compared to the professional
What?
LolWhat?
Really? You can't use Dirac and also have an established crossover freq? I haven't received my RZ50 yet, but was planning on using 80hz for everything..I believe Dirac determines each speaker pairs capabilities, and then uses that accordingly - overriding the other XO settings
After you run Dirac, the AVR will have crossovers assigned through the standard interface. You can change them to an established crossover.Really? You can't use Dirac and also have an established crossover freq? I haven't received my RZ50 yet, but was planning on using 80hz for everything.
It does not:However I heard Onkyo is known for outputting 1v through pre out.
@amirm I just purchased this avr and I’m aware of this power limiting thing. I intend to use an external amp anyway (Rotel 1582 200w/c) for LR channels. However I heard Onkyo is known for outputting 1v through pre out. does this mean it limits Rotel’s full potential?
I contacted Onkyo support before AmirM tested the RZ50 here, and was told that the "design" peak V was 2V... which means an RMS of 1.4V or the standard "pro" level...Check out this thread i literally just started a few days ago.
It was about the sister avr to the Rz50. I have the Integra Drx 3.4
There is a link in this thread that talks about how 2 people contacted onkyo customer support about preout voltage. 1 person was told the pre outs voltage is 1V another person was told its 2V.
I am unsure what to believe because I do believe the rz50 and drx3.4 share the same power supply. I am trying to power a NC502MP D class amp
Hypex NC502MP NCore Amplifier 500Wx4 compatability with AVR
I am curious if my AVR preouts have enough amps/voltage to power my future amp. my AVR is the : Integra DRX 3.4 My amp would be the : VTV AMPLIFIER Four Channel Hypex NC502MP NCore Amplifier 500Wx4 Also, could I use this cable to connect my AVR and Amp ??www.audiosciencereview.com
What we actually know from the tests here, is that it has substantially more headroom than that! Yes, apparently the tech's were being conservative, what do you want to bet, that they had never tested it to see what it could actually do!?
Based on the ASR measurements - it well may be that 2V was design V RMS output... as the 3 and a bit volt would seem to reflect some headroom on top of a 2Vrms - which should be 2.8V peak... and the 3 and a bit V before clipping is then headroom...
Yeah would have been nice to talk to L2 or L3 engineers... but there is no obvious way of getting access to those!
Just realised - AmirM measure 3.5V RMS... so really the tech that responded had no idea!
That's the good thing about D+M's, it is easier to acquire their service manuals and then you will know which DAC, OPA and Volume Control ICs are used. For example, we know the volume control IC for the D+M's (at least from 2016 through 2020) is the NJU72343. In fact you don't even need the SM to know that because Denon.jp did mention it, if I remember right.
According to the datasheet, the NJU72343 indicates its typical maximum output is 4.2 V. You can also see Denon's own measurements, thanks to Gene who posted it when he reviewed the AVR-X3600H (a preview actually). That graphs show the knee point at 4.25 V, THD+N just a touch above 0.002% (94 dB SINAD) and at 1% it would be about 4.5 V.
With the new Onkyo's, someone would have to open it up to see which vol IC they are now using. I do know the older (2017?)RZ820 has the BD34704KS2. That one has comparable output specs to the NJU72343. So if Onkyo/Pioneer are using that same chip in their current models, Amir's measured 92 dB SINAD at >3 V is absolutely within the capability of the devices.
This is probably a silly question, but I am definitely not an electrician.
How could one know if they are fully utilizing an external amp ?
Meaning the NC502MP has 2.35V sensitivity to get 500W into 4 ohm speakers
Or it's 2.77V sensitivity to get 350W into 8 ohm speakers.
Is there any way I could determine:
A: How much wattage I am pushing to my speakers?
or
B: How many Volts my AVR is pushing to the amp?
I imagine I would probably need some specific equipment. But I am just curious.
At a simplistic level - you don't need to worry about it with the current Onkyo/Integra/Pioneer AVR's - as we already know from measurements that their output goes up to 3.5VThis is probably a silly question, but I am definitely not an electrician.
or
Due to the power limiting from this AVR, would an external amplifier be a good solution?
Does anyone think its even necessary?
For a less than 1500sq ft room with 10ft seating distance. Is an external amp necessary?
5 speakers with efficiency of 86db
If the speakers are relatively efficient and true 8ohm - then an external amp is unlikely to be needed.Yes, external amplifier is necessary for best performance. Lowest efficiency and impedance will likely be in the bass frequencies where DIRAC will have to compensate for room modes, so you'll need the extra oomph from your amp for best bass performance.
Agreed. In this case, the speakers are rated at 86db, which is probably their 1khz efficiency rating, and I'm sure they dip much lower at lower frequencies. If his speakers are anything like my Kef R series that dip down to about 80db efficiency and 3.2ohm at their worst point, they will require a beefy amp.If the speakers are relatively efficient and true 8ohm - then an external amp is unlikely to be needed.
The main constraint with this amp's design (power amps stages) - is that it is Current Limited.... so if the speaker impedance dips too low, the amp gets into trouble.
It is very very much speaker dependent.
