No. If I go mono, I go real mono.Are you a dual mono purist? Right down to the paired AC power cords?
The M33 is as much a computer as it is a 'audio' device.
And Bruno and friends are no slouches in amp design.
Are we really missing much*?
*okay, the M33 phono stage might suck, depending on if they implemented it in DSP or analog
Nor did I.It looks like all analog inputs including phono is converted to digital according to the manual. The manual also says the signal is then sent to digital output but I don't see any digital out.
ADC Sample Rate (applies to Analog Sources only)
An analog audio input is converted to digital signal by making use of
M33’s superb circuitry called analog-to-digital converter (ADC).
Using this ADC Rate feature, the sampling rate of the resulting digital audio
signal (available at the digital output ports) can be converted into three
levels - 48K, 96K and 192K. Make sure that the associated equipment will be
able to handle the applicable digital audio signal level.
11 Analog Gain (applies to Analog Sources only)
Gain adjustment allows all sources to play back at the same volume
level so you don’t need to adjust the volume every time a new source
is selected. It is generally preferable to reduce the level of the loudest
source rather than making louder the softer sources.
12 Phono Type (applies to Phono Sources only)
Select either MM (moving magnet) or MC (moving coil) depending
upon the connected turntable’s phono cartridge.
Which sounds potentially promising, as I like DSP-based RIAA, but I have a lot of questions:
1. Is the phono gain done in the digital or analog domain?
2. What are the cartridge loading options?
3. Are other legacy EQ curves beyond RIAA available?
4. Why is the MM cartridge input resistance listed as 56k ohms instead of the industry standard 47k?
I agree completely that Bruno et al are no slouches. Neither are the engineers at ESS, AKM, TI (Burr Brown), XMOS etc. To state the very obvious, the problem is that you cannot just throw these well engineered bits together in a box like Lego building bricks and just hope it’s going to work. Just imagine a mobile phone made this way (clarification: they most certainly aren’t!).The M33 is as much a computer as it is a 'audio' device.
Not really what they feel but what the resource constraints were during the development phase of the project. Amir’s review of the C658 DAC streamer back in May suggests that if the M33 is to be reasonable, let alone good, they will have needed to up their game in the arena of digital audio. A steep learning curve? I leave you to decide.Do you think the NAD engineers feel differently?
On the whole their audio amplification has been reasonable in the past and if they have carefully implemented Bruno’s Purifi amplifier should be OK. It must be emphasised that a class D amplifier PCB layout needs more care and consideration than the layout of a class AB and Bruno’s work is very carefully optimised so any slight PCB changes would possibly require other optimisations to get back to Bruno’s superb performance.
The C658 isn’t the only underperformer here. Check out Amir’s review of the M17 last September. If Amir (or Paul Miller over in HiFi News) give the M33 the thumbs up then I’m impressed.
A computer, usually the DACs and streamer/DAC/amps have USB inputs using type B connector.What would you hook up to it?
I guess the only option for local playback is to use its streamer through network, or a DDC converting to one of its digital inputs (RCA coax, AES-EBU, Toslink).
I use my setup over the network too but I know a few friends who have a macmini or a dedicated PC connected directly to streamer/dac/amps by USB.Why not hook up the computer over the network?
In my current set up, my Roon computer and NAS connect to my living room rig entirely over the network.
