NAD C298 Stereo Amplifier Review
Rate this amplifier:
    Votes: 3 1.0%
    Votes: 32 10.7%
    Votes: 140 46.8%
    Votes: 124 41.5%
Hacsak nem akarja kicserélni az egységet, akkor úgy tűnik, hogy vagy kifizeti a szolgáltatási költséget, vagy csak az RCA bemenetet használja, és él vele. Azt hiszem, megpróbálhatsz egy passzív monó (vagy fél sztereó) hangerőszabályzót az RCA vagy XLR útvonalra helyezni, és beállítani, hogy kijavítsd a NAD egyensúlyhiányát a kettő között.
If I set the balance on the source, it does the same. It is rather a question of whether the faulty channel causes this other deterioration in quality
If I switch the left and right channels of the source, the left channel is also quieter
Which channel was quieter before switching? Could still be the cable (at the XLR end).
Melyik csatorna volt halkabb a váltás előtt? Még mindig lehet a kábel (az XLR végén).
I swapped the left cable with the right one, and now the right channel is quieter! So the cable seems to have resistance!
Thanks everyone for your help!!
if it's no secret, how much did you pay for a used one and how old is it?
Which of these Amplifiers would be best matched with a pair of dali rubicon 2s, nad c298 or roksan blank? Want to hear clarity and bass control, have a nad c700 at the moment.
Cheers.
Cheers.
I wouldn't swear to audible differences?
I any case, only having the measurements of the Roksan Attessa here to look at. It failed pretty badly on the bench showing some weaknesses in technical design. Without having a Blak on hand to see it things have gotten better, I'd put my money on the NAD.
Cheers.
Consider ordering a hypex or purify power amp online.The NAD C298 is great but costs more than your speakers.
Have considered, those not sure of the quality of them compared to a real audio company, also speakers were comparable price around £1600 - £2000 new depending where you buy.
The sound of the dalis is great, i could listen to them all day, hidden gem in my opinion
Excellent thought!
Jedi77, if your in the US I would definetly consider something like Buckeye Purify for half the cash!
The Purify boards are genuine factory boards, etc.
Very nice stuff, not too fancy a case.
Amir took a look at a 3ch version here
Unfortunately I'm in the UK, we have nord over here, I can pickup an ex demo c298 slightly cheaper than the nord.
My suggestion was the buckeye as well, unfortunate you do not know someone in the US. Also unaware if they offer 240v support.
Have you seen the audiophonics amp that was reviewed. That amp did phenomenal and probably falls in line with Buckeye and you can try it and return it if you do not like the sound. They are located in France and ship worldwide.
This is closest to the NAD. There’s also DA-S250-NC, but personally I would go with the S400
