Raindog123
As far as I understand, the first one is a spectrum of the whole one minute and the second one is an instantaneous (or whatever time window the program is using) spectrum at some point.
Thanks!
Can we all please stop "MQA = DRM meme? It's honestly ridiculous.
Simple proof: Listen to the attached files.
Suppose we are downsampling a file to 12kHz sample rate, then the file should be filtered in a way that there is no content >= 6kHz before decimation. Due to the low 12kHz sample rate, everyone must be able to hear a faint tone in the attached "impulse long linear.wav" and "impulse long minimum.wav", but not in "impulse short linear legal.wav" and "impulse short linear illegal.wav".
"impulse short linear illegal.wav" is named as such because the stopband is >= 6kHz before decimation. After decimated, aliasing will occur down to about 5kHz. I aware that some people tend to use imaging and aliasing interchangeably, it can cause confusion, so here is an explanation:
https://www.audiosciencereview.com/...u-m4-audio-interface-review.15757/post-504008
However, 44.1kHz sample rate is the lowest norm for music distribution, so people needed to be able hear the same effect at around 22kHz, and the audio content itself also need to contain strong signal at this frequency region. Also, the "long" files can only happen on something like a chord DAC, for typical DAC chips, the "short" files are the norm.
Therefore it is all about frequency domain.
In the case that anyone interested in trying these things out with real music rather than an impulse, @KSTR provided an interesting listening test here:
https://www.audiosciencereview.com/...ike-if-we-were-bats-listening-examples.23776/
MQA content is distributed with no copy protection. I see no reason for the labels to bring any kind of DMCA claim against you or even want to be involved. The business end of this will be patent and copyright infringement of the code, not the content.
"Appears" is the key word here. A bunch of guessing on Archimigo's part with incorrect assumptions. I just analyzed the spectrum of this 88 kHz. Here is the scan of the first minute or so of this track:
I went to look for the original master and nothing beyond 44.1 kHz/24-bit is available. This support the notion then that the roll off is correct around 22 kHz and what is after is noise shaping.
I don't know what specific tradeoffs the GP was referring to in the following:The steeper the FIR filter the more taps you need, the longer your impulse response is..
You need proof for that?
but to me, optimal time domain response is not a "slow" filter. Optimal time domain response gives the fastest rise and fall times possible while still guaranteeing no overshoot or undershoot. This optimal time domain response is realized by a Gaussian filter which is usually implemented as an FIR. As with other types of FIR, the quality of the approximation increases with the number of taps and corresponding increase in impulse response length.And slow filters absolutely trade of frequency for time.
Archimago's source file was 44.1kHz, MQA-encoded. He wrote that clearly here https://audiophilestyle.com/ca/reviews/mqa-a-review-of-controversies-concerns-and-cautions-r701/.
That recording, regarded at 44.1kHz, rolls off at 21kHz and that's it. You claim to have investigated an 88.2kHz version and found the same roll-off. Fine. That just shows that your 88.2k version is an upsample of the 44.1, i.e. fake hi-res, an upsample done outside any MQA regime.
That's probably not correct re. public domain decoder. This is strictly MQA patent issue.
And in case of the current public domain decoder developed by @mansr , they chose not to legally pursue this matter.
It may help you to read it: "You may come across digital works that contain copyright controls, such as digital rights management (DRM) technology or a software copy protection system. "This will help you to understand that access controls and copy protection are not exactly the same thing.
https://www.dmlp.org/legal-guide/circumventing-copyright-controls
You are the lay person, not me. I spent a lifetime meeting with record label executives and their lawyers as they attempted to force operating systems/players to limit playback of their content. Most of their execs come from licensing department so are lawyers as well. I have explained repeatedly how Steve Jobs convinced them to distribute their content without any copy protection. And how you can go to sites like HDTracks, and download millions of high-res audio tracks with zero content protection in your favorite (non-MQA) format.Note that I'm not asserting that the DMCA is applicable in the case of MQA. I make no such claims either way. Rather, that it takes someone who understands the case law to render any kind of useful opinion on this subject, not a layperson like you or me.
There is no digital copy protection issue for content here. There hasn't been one, there will not be one. As a lay person you can imagine anything you want but don't drag me into it. I know the reality, you don't.Meanwhile, your prediction of what the labels will and won't do is hardly comforting. Corporate intellectual property owners have a long history of asserting digital copyright violation and DMCA violations, even when a violation would probably not be determined in court. That is because individuals can't afford to spend $150K or more to defend their usage.
I wouldn't. Lessig went through a painful battle with the labels which he lost when labels cared about content protection and cared a ton. Since then Lessig has become enemy of anything related to copy protection. So if you want to read a one-sided argument, sure, go ahead and read it. But even he wouldn't tell you that you have a case here when the content itself lacks any form of copy control or protection.I recommend the EFF or the works of Lawrence Lessig as useful resources for learning more about that history.
I don't see my MQA DACs as crippled.Are you good with crippleware?
Are any or all MQA devices able to select an alternate reconstruction filters?
Are any platforms other than Roon allowed to apply PEQ/REQ?
- Rich
Some do have alternative filters for non-MQA playback (UDP-205, M2TECH, D90), others don't (Liberty).
Sure, there are many such things, Dolby for example. But we don't seem to have passionate discussions about that, only MQA.Unless you pay the royalty, the DAC playback MQA encoded titles are crippled, thus crippleware.
- Rich
It was really lateI know and he misspelled werner
Fine, but obviously many audiophiles feel that MQA adds value to them and are willing to pay $0-100 extra for it.Dolby adds value and does not restrict DSP and other post processing while increasing costs.
Multi-channel audio from music streaming is new and welcome.
MQA degrades quality and restricts while increasing costs.
There is nothing added by MQA.
Both have marketing, but MQA is blowing epic levels of smoke, well you know where.
- Rich
There is no need to save anyone . People will make their own, adult decisions.I am not sure the audiophile community is a bastion of rational behavior.
Since disk space and bandwidth are not a problem, there is no justification for MQA, unless you buy into leaky filters and increased THD/decreased SINAD.
- Rich
- Rich
