MattHooper
- Joined
- Jan 27, 2019
- Messages
- 10,907
- Likes
- 19,348
I've always wanted to hear those speakers. Intriguing design!
AirCirc tweeter, Satori midwoofer, and Revelator 10".I've always wanted to hear those speakers. Intriguing design!
The up-tilted woofer makes sense since it would reduce the floor bass boost and you don't have to worry as much about it's off-axis behavior or beaming since it's a bass driver to begin with. I would how Amir would measure it since my understanding is that the in-room response graphs are an assumption based on how other speakers behave in a normal room (?). Edit- I suppose that graph uses the vertical radiation measurements from the Klippel to help predict the in-room response and so the behavior of that speaker would probably still be accurately predicted.I've always wanted to hear those speakers. Intriguing design!
yeah, good point, for very low frequencies (less than 100 Hz? 80 apparently looking at the THX cutoff?) the direction doesn't matter and we're only looking at sound energy and not directionality, but depending on where the crossover to that mid is there is probably still significant music content where directivity matters.But but but ... "you don't have to worry as much about it's off-axis behavior or beaming since it's a bass driver" implies that tilting it a little won't "reduce the floor bass boost", precisely because it's radiating almost omni.
Near-omni radiation is why speakers have historically had woofers (and ports) pointing every which way (sideways, up, down, ...).
It would be really nice if you included links to the product pages, or at least the make/model of the speakers:
A Triad Cinema Reference Series LCR 2, they apparently sold for around $15k each (!), but may have been discontinued due to a component availability issue. Specs make clear they are for home cinema applications, albeit very large rooms (max 127 dB output!):I can't remember if I posted this one, but I find this design intriguing:
The CS3.7 looks cool:
My opinion of the Thiel 3.7 was that they needed more PR surface area. The coax was nice.
I also heard the 2.4SE, and felt the bass range was better behaved, as well as really liking the mechanically crossovered 4" "quasi-coax" unit with it.
Shortly thereafter, they brought out the 2.7 hybrid, which is likely the best of both worlds. I have not heard those.
The completely different wood type, stain color, etc; between the top horn and bass cabinetI like the look of these B&C M12 mk2s a lot.
After falling in love with the JBL 250Ti because of the top end and astonishing mid bass thump I can only fall for these too. Dual 18 inchers = rock and roll de jour speaker.The completely different wood type, stain color, etc; between the top horn and bass cabinet
would drive me crazy?
I hope the picture is from a audio show hotel room, the drapes behind the speakers are unbelievably fugly.
I love these.
Yep, the Everest 67000s are awesome. Too bad they cost as much as my house.After falling in love with the JBL 250Ti because of the top end and astonishing mid bass thump I can only fall for these too. Dual 18 inchers = rock and roll de jour speaker.
