Noah Katz
While I am (was) ok with 5 remotes (or more) on the table - it alienated my wife from the TV room and system.
Harmony Elite.
To (also) piggy back onto nuport's question above on Nov 29th and the following responses: Ok
Re - Noted in context to nuport's question about would you have an audible improvement if you had a dedicated 2 channel DAC. Based on these handful of responses the consensus is adding even a very good DAC would not an audible improvement.
Next and a factor on HTP1 vs others is ease of use and glitches - Im also looking for an AVP that you turn on and it works. While I am (was) ok with 5 remotes (or more) on the table - it alienated my wife from the TV room and system. Now we are rebuilding (retaining amps and speakers). I want very good audio (2 channel. She wants sit down grab remote and turn on - all done except select program. Im not certain anything works this seamlessly? My Anthem D2V did not......
Any feedback - as always appreciated - including on nuports questions......
To watch a 4k Blu Ray, I have set up a button for that too, but you have to start from OFF if you want that "ONE BUTTON SIMPLICITY"
I'm not exactly fluent in Harmony, but I thought that when you switch Activities, any components not used in the new one will be powered off.
I was happily proceeding like that until the Harmony system asked If I wanted to update the software (or firmware). It never finished, and now I own an expensive re-chargeable brick.I have a Harmony remote. My A/V system is rather complicated, with tri-amped front left and right front speakers using a DEQX that I can use just for 2 channel audio but which also forms the Front Right and Front Left for TV using my Emotiva pre/pro. So turning everything on and configured to "JUST WATCH TV" is a fairly involved process of turning on amps and processors and the TV and sources and setting signal paths...
Using my Harmony remote I easily configured a button on it's little touchscreen that says WATCH TV. Hit that button and everything fires up and is set to let you watch TV off the cable box. VOLUME and CHANNEL as well as GUIDE are physical buttons on the Harmony remote that easily control these functions for watching cable. WATCH TV also fires up center and rear channel equipment which is not needed for stereo music listening. (LISTEN TO STEREO is another button I have set on the remote...)
You can also turn it all off by just pressing the OFF button on the remote.
I have all the controls for all my AV gear in the Harmony so you can go through menus and choices and do whatever you want like watch Netflix or Prime etc, but I do not have "ONE BUTTON NETFLIX" etc set up, although I could program that easily enough.
I think you can set it to go either way.
I can't imagine having a system more complicated than an integrated-everything plus speakers without a Harmony remote. I wish they would update to allow more IP control, and allow pairing with Logitech bluetooth keyboards so that they're seamlessly usable with all connected devices.
Thank you. Out of curiosity are you still planning an HTP1? I have my remnant speakers amps and subs. Still on the fence between upcoming Anthems and HTP1......
what’s swaying your moving to the HTP1? I ask not to poke at this very appealing pre/pro - rather to hear your thoughts.
Honestly, if it weren't for wanting a newer ARC/DSP system than the first release of AudysseyXT32... I'd probably just keep using my 8801 for another 5 years and see if better solutions appear eventually.
(Quote Although I haven't purchased an HTP-1 yet (plan to in the near future however), I would hope it is at least as feature rich as a 7 year old AVP with less of almost everything else. YMMV but other than a couple of "refresher" calls the first day I set everything up - my better half is pleased and uses it daily. The projector and unswitched amps in the media room is another matter entirely, but I admit I made that intentionally obtuse to some extent. My playroom, my rules.
I was originally considering the upcoming Anthems until I realized they did not have Auro3D upmixing support, which I find to be the fallback alternative with most bad Atmos mixes. Many movies, despite being "Atmos", are not properly mixed to take advantage of this surround format, and this is when Auro3D comes in to play.[/QUOTE]Thank you. Out of curiosity are you still planning an HTP1? I have my remnant speakers amps and subs. Still on the fence between upcoming Anthems and HTP1......
thank you!,,
At the moment. But it will be added.One limitation that is a deal breaker for me would be it only has a global lip sync deal. Can't set lip sync on a per input basis.
Thanks. Will keep my eye on it. I'm not really looking to switch right now, but Dirac with Bass management is intriguing for sure.At the moment. But it will be added.
