X-SABRE3 performs equally or better than X-SABRE Pro MQA
No chance that performs better, even the official spec is the same.
I hope Amir will measure x sabre 3 in the future.
I used a PI solution with display combined with a Topping D90 but maintaining the PI was too onerous: regular failures that required re-imaging, complex setup, etc. I moved to the X-Sabre 3 and strongly prefer the simplicity/reliability (and to be clear, I installed Linux on laptops in the early/mid 90s, so not shy in these matters). The integrated streamer/DAC approach is worth the price for me insofar as it stays bulletproof.Hello, curently I own
I find the sound superb although this is just my impression - I do not have any measurements like AMIR to prove my point.
- a Raspbeery PI '(around 130 € these days, if you can find one) with RoopieeeXL (free of charge) as a streamer (RopieeeXL which is fed by HQPlayer which by it self is fed by Roon and Spotify)
- a RMI ADI DAC 2FS (around 1200 € -as far as I can see)
- a Topping A90D as my headphone amplifier (600 €)
Nevertheless, I consider this a really serious rig for less than 2000€. As with many other contributors to this forum, I do have the impression that Matrix seem to be overplaying their hand - pricewise.
It's a HDMI out, being a 4K media player... not in with ARC like the Matrix Element X2 under review;hdmi
thanks for this!I have a new test where I show the distortion level at various levels by adjusting the volume control (instead of input digital levels in the past):
Are you sure you're not reading too much into Amir's graph? It shows the X2 having 103.7dB SINAD at -30dB.
For reference, the D90SE using regular old digital attenuation will have 102.8dB SINAD at the same -30dB (you can extrapolate that from the DR measurement).
Is that +0.9dB SINAD boost really of any value? It's certainly not a game-changer.
No. From the Dynamic Range test we know the D90SE has 72.85dB SINAD at -60dB input (132.85-60)I don't understand your calculation for the D90SE as it has a SINAD of 124.68 dB at 5.114 V, so at -30 dB the SINAD should be 124.68-30=94.68?
The .9db is literally meaningless,what is the game changer from my perspective is the peace of mind that no digital glitch will present the full output to an amp.Is that +0.9dB SINAD boost really of any value? It's certainly not a game-changer.
The problem with Raspberry Pi is that 7 or 8 years from now, It will likely be fully obsolete and not compatible with the updates from the various streaming services. Dedicated hardware platform don't normally suffer that if the manufacturer is serious.Topping / SMSL would probably make serious money if they could integrate a raspberry pi 4 in their DACs. People could put a streamer software of their choice on it or use it as Roon endpoint. Sell that bundled with a matching headphone amp and XLR cables.
Should be possible for 1000 USD to get a seriously good stack with a small footprint.
With the money that's left over you could buy a pair of Kef LS50II and a iPad Pro! As display
(Ridiculous really how much this thing costs)
I see it the other way around. If a software solution is built it would run on all pi forever!The problem with Raspberry Pi is that 7 or 8 years from now, It will likely be fully obsolete and not compatible with the updates from the various streaming services. Dedicated hardware platform don't normally suffer that if the manufacturer is serious.
Can you install volumio and such on a Pi model B from 2012? does it takes all updates from Tidal and such? I highly doubt it. My Bluesound streamer is from 2007, and it still receive firmware updates and all apps updates. In the end a PI is a computer. All of them becomes obsolete.I see it the other way around. If a software solution is built it would run on all pi forever!
There is software from the first Pi's running on the latest ones like a decade later.
Actual difference. Not that it would matter. No music comes this close in SINAD and certainly no headphone does.A question regarding the slight difference in SINAD between this and the X model -
Is that 2dB variation more likely attributable to unit-to-unit variation, to a margin of error of the tests, or to an actual difference in the devices?
