Why did you do that?Alright, did never ending fine-tuning and tweaking through the past weeks. Did some heavy manual tuning to the »frequency response« curves lately, with the current result as shown below:
Yes,but as it seems you have eliminated lows.My listening room is kind of complicated, which may be the reason why I was never satisfied with MathAudio’s »reference line« correction too long. Especially a heavy »balance shift« to the right speaker nearly drove me nuts.
Eventually I began to try to correct that heavy right speaker tendency by manually shifting the curve of the left channel up. This is, because I mistrust MathAudio’s Stereo balance slider.
Anyway, this made me a fan of manually editing the »frequency response« curves after a while
The curves you see now are results of some change/check cycles I did with the help of »Equalizer APO« and »foobar2000«.
EQ APO on top of Mathaudio will mess things up.
If you use ASIO output that is correct,at least with foobar (measured and confirmed)Yes, I was worrying about that a bit. But I am pretty sure now that my player app (Audirvana) »grabs« the sound data before Equalizer APO would.
I'm using WASAPI (Event) on mine, and it bypasses EQ APO as well.I'm not sure but I think WASAPI exclusive also overrides EQ APO.
Not strange given that you have different settings in each channel.My assumption is that a well EQ-ed system should produce a clearly centered and »concentrated« sound spot just in the middle between the two speakers when playing back a mono tune – regardless of what that mono tune may feature actually (e-bass, vocal, sharp hi-hat, strings orchestra, male or female choir, what ever). Which wasn’t the case with my system at all ...
So I will continue my system EQ optimizing by focusing on that »mono task«.
You can find a lot of imaging tests here,very useful in every aspect:My assumption is that a well EQ-ed system should produce a clearly centered and »concentrated« sound spot just in the middle between the two speakers when playing back a mono tune – regardless of what that mono tune may feature actually (e-bass, vocal, sharp hi-hat, strings orchestra, male or female choir, what ever). Which wasn’t the case with my system at all ...
Not entirely,as it's not only FR or level into account but also phase,time,etc.But aren’t different settings for left/right an obvious consequence of not having a totally symmetric listening room situation? At least this was my believe up to now.
www.audiosciencereview.com
Correct whatever you want below 400Hz.Hi, I'm new to the forum. I have been using math Audio for a couple of years in my foobar200 player, and can't and willl not listen without it!
I have asked Math Audio about how I can use the correction on frequencies under 400 Hz only, with the band above that frequency without any correction, even the curve does not look nice. The purpose is to only correct in the lower frequencies and bass region.
I got this answer:
"If I understand you correctly you wish to correct the frequency band 20-400 Hz and you don't wish to correct the frequency band 400-20000 Hz.
1. Move down the vertical slider to properly correct the frequency band 20-400 Hz.
2. Move the mouse cursor to the upper edge of the 'left' plot near the frequency of 400 Hz, press and hold the left mouse button and move the cursor horizontally to the right edge of the plot, then release the mouse button. The target curve will look like _________----------------
The frequency band 20-400 Hz will be corrected and the frequency band 400-20000 Hz will be left "as is".
If you wish to suppress the frequency band above 400 Hz, you can draw the target curve like -----------_______________ where the right part of the target curve lies near the bottom of the plot."
I have tried to follow that procedure, and it is probably easy to do, but I'm not getting it right. I have done step 1, but it is step 2 where I don't get it. Can someone explain for dummy as me, how I set the curser? On the curve, or on top of the chart or?
Interesting i correct full 20 to 20khzHi, I'm new to the forum. I have been using math Audio for a couple of years in my foobar200 player, and can't and willl not listen without it!
I got this answer:
) sound by far the best an not only for me audiophiles musicians that heard the difference in my room all had the same conclusion the flat target curve did the job sounding the most balanced. yes i know that the theory ( also here on ASR) that it only make sense to correct till 400hz. Could have to do with my attic acoustics with saddle roof. Still!
