- Thread Starter
- #121
Most important question how does it sound are you happy with the result do you notice a difference when using the bypass knob. ?If you look at my curve, it looks quite good, or even very good ;-)
Thats the spirit i'm 64 so probably same sort of ageSnarfie: I have been through dozens of hi-fi systems, some also high-end over the last more than 50 years, and happy with the sound most of the time. Now, my room is small, but dedicated to music listening, so quite comprehensive room treatments has been done, absorbers and diffusers. In my entire hi-fi hobby I have strived for better resolution and neutrality. A couple of years ago I started to use DSP, and don't look back! Most important result is the much better resolution and neutrality in the low end, and I'm convinced that those who disregard DSP, and even acoustic room treatment also, and claim they have high-end sound have not heard high-end sound with acoustic instruments. The difference is huge. So, yes, I'm very happy with the sound. However, as always, can it be better I try to go for it. And I thought, that DSP above 400Hz would probably not be optimum, so I raised the objective to avoid that here, but without loosing neutrality.
.I will be remeasuring and re-running RoomEQ soon.
Thanks. What does the colour of the dot indicate?Watch out for »Room EQ gain«, too. The dot with it should be green instead of red![]()
documentation
Doh. Not sure how I missed that tbh...
Hello Sokel, I just discovered MathAudio so I'm really a noobie.Ok,let's follow the right way now.
First read this:
https://www.audiosciencereview.com/...s-your-favorite-house-curve.2382/post-1476897
Second,any line above the measured response (the one with the hills and the valleys) does not amplify anything,it just leave it as is.
A nice correction is what @HDavidson proposes as I did earlier,that will correct lows and leave the rest as is.
Again,there's no amplification in Mathaudio,all it does is reducing,any line above the measurement simply does nothing.
What a pityMathAudio doesn’t support externally generated WAV impulse file. U need to use MathAudio to sweep/measure.
Did you try the exclusive mode?Did manage with my limited knowledge to install Mathaudio room EQ on Linux Ubuntu.
It's acceptable also i did clean up some sound artifact by making the buffer wider an not using other programs or visualizations. Major problem when running under wasapi or default driver my topping D10 still using 48 khz instead of a higer frequency corresponding the high resolution file no matter what. Did make a short video displaying system monitor an sound
Any luck by other members running Mathaudio Room EQ under Linux Ubuntu.
System used 15 year old laptop with intel 6100 processor 4gb internal memory 120 SSD running on Linux Ubuntu
Oeps exclusive mode is not aloud. So no sound.Did you try the exclusive mode?
If it's like in windows the only way you can have automatic sampling rate change is through WASAPI exclusive or ASIO.Oeps exclusive mode is not aloud. So no sound.
Yes it probably is. i also can't choose for event or push wasapi setting. By the way listning to 48 khz cant hear any differents between my Windows higher settings.If it's like in windows the only way you can have automatic sampling rate change is through WASAPI exclusive or ASIO.
If only one sampling rate at a time is allowed,I would stick to the original,more common 44.1Khz,or whatever the file is.Yes it probably is. i also can't choose for event or push wasapi setting. By the way listning to 48 khz cant hear any differents between my Windows higher settings.
It is quite acceptable.
