You mean this one. You may choose basicly all column loudspeakers same size aproxmal 1 meter high. Measured around 3 of them different brands more ore less same response. Depended a bit bass Port for ore behind. Current measurment done at a phase coherent Vandersteen model 1 by design. If you hear any loudspeaker without correction the result is horrible thanx to the room acoustics.Which loudspeakers are above where almost the whole the region below 300 Hz is approximately 10 dB lower?
Seems your room and placement is then very bass reducing, usually a different placement is better option than EQ but I know that this often not possible in living spaces (one of my current listening rooms and placement is also unfortunately bass shy although not this much)
) the result is amazing. Never heard in 50 years such difference an balanced sound.Yes i did 4 absorption pannels. Behind the picture there is an textile Ikea couch a singel guest bed on the floor a tick carpet. Because of the ought shape of the attic a bookshelf is not possible. On the other hand reverb time is not that bad. Despite the bad acoustics Mathaudio did the job better than expected. If a recording is from a good quality Imaging is second to none speakers disappear.Maybe room furnishings like bookshelves with stuff and thick curtains may help tame the mids-highs a little.
I would draw the line here or even higher if I was you:Thanks for your input. Here is the chart before the new adjustments:
Then I managed to make the correction only below 400Hz, by sliding the line above 400Hz as I understod it should be done - I then got this:
So, I thought the plug-in only made corrections below 400Hz, but thats not the case. The sound is as if I made increase by an equalizer above 400Hz by app. 15dB.
I can change the green line above 400Hz as I want by placing the curcer on the line and draw it in any direction. But what's the point in that compare to let the plugin work out adjustments on the entine frequency range above 400Hz?
Do I do something wrong?
Your first chart is overcorrected beyond any possible meaning,even with the straight curve I would draw it in the -12db area and no lower.My first chart shows a pretty linear response curve, slightly damping at higher frequencies (on purpose), where your suggestion leads to emphasis on the treble region. I prefer a natural balance, why do you prefer to increase the overtones?
Thank you for your comment and advice - I really appreciate it.Your first chart is overcorrected beyond any possible meaning,even with the straight curve I would draw it in the -12db area and no lower.
The example of my (red) curve will follow a gentle decline starting with the lows at +3db (relative to the 15db line who lets call reference) and ending at 400Hz while leaving the rest at it's natural.
Try it.
(it doesn't matter if you have some small nulls,is better than overcorrecting,also try to have a look at the higher resolution)
Edit:the draw line higher than the chart does nothing,do not think that it will elevate that area.That's the whole purpose.
Google Translate ;-) Merci pour le commentaire. Vous suggérez donc d'utiliser la haute résolution ? Jusqu'à présent, j'ai eu du mal à entendre la différence en utilisant une résolution élevée ou normale, mais je vais réessayer.essayez cette option (level -12db / -13db) de correction. Les basses fréquences doivent être corrigées en fonction de la haute résolution.
Ok,let's follow the right way now.Thank you for your comment and advice - I really appreciate it.
As I see it, your curve make less adjustment below 400Hz than mine, and increase in level above 400Hz - I tried your suggestion and I can hear that as equalization where the overtones are just amplified and therefore the sound is not natural. To me it seems, that my goal (to compensate only below 400Hz) is not achieved. If your red curve is the target curve, it sounds like it looks.
What do you mean by "Overcorrected"? My very first chart shows correction over the entire frequency response, and compensate the output to reach my target curve. Do you mean that correction -12 dB average is better than 18dB? Provided there still are sufficient output to feed the amplifier, I dont think there are problems. In digital signals any correction are requirering the same processor power from the PC, or have I got it wrong?
You're right about that.@Sokel: Thanks again. I did not explain myself correctly. If the target curve is placed above the measured curve, Math Audio plugin dos not do anything, so if the target curve above 400 Hz is placed higher than the level below 400Hz, only the level below 400Hz is reduced by what has been chosen. But wheather you reduce level below 400Hz, or amplify above 400Hz, the end result is the same regarding balance, and sound the same. I'm aware that the Math Audio does not amplify, but makes only decrease in level, to reduce peaks, and if you reduce a lot, no peaks is shown. And that is easy to hear! That's the hole point.
