I would prefer a software solution regarding AV processing. You'd just need a PC and a multichannel DAC and be done for a long time:
- need more channels: buy more DACs
- need support of newer decoders: update the processing software
- somehow the CPU gets too slow with modern decoders: get a new motherboard
I know this will not happen in the near futute, but just let me dream a little bit, OK?
For this reason I started the following experiment.
I use a win10 laptop in tablet mode with
Jriver MC (
WDM driver in
5.1 channel mode) and an Oppo UDP-203 via HDMI IN for exactly this (
oktoresearch DAC-8 would also be a great option for better SQ and USB in might be more stable than HDMI though I don't experience many problems with the Oppo). In Jriver MC I do the
Room Correction with parametric eq filters created with
REW and a
U-MIK1
I used PEQ's because they don't introduce so much latency as convolution filters do in Jriver MC.
I have Jriver MC auto start at Windows Logon. The Oppo I have set to start up with the last input being HDMI IN BYPASS (Bypass because of lower latency with mouse control). Mostly we watch netflix and I have used the surround tests in there to verify that the different channels are connected correctly, one must use the netflix app for 5.1 channel audio though. Anything else we watch via Firefox ;-)
To control the laptop I have a
pepper jobs airmouse which has a small keyboard, programmable IR transmitter which can copy commands from an existing remote as well as media and windows buttons which makes it easy to switch between apps. I also use it to control some functions of the Oppo like volume, input if necessary and on/off
Disadvantages were that I had to store DVD's and Blu-Rays on a Hard disk or connect a DVD/Blu-ray drive with
additional software to my PC so Jriver can process the audio.
Advantages most of this solution is software based so a new codec can be added to Jriver any time.
What would also improve user friendliness is geting active speakers with room correction built in or a seperate DSP like:
the t.racks DSP's or Minidsp
10x10HD or
DDRC 88A. Than you can connect any good multi channel dac you want to it or if the speakers have digital in just a thing like the minidsp DIO-8. Than you won't need Jriver for room correction and you can also play blu-rays directly on the oppo 203 without having to store them.
Hope you get some inspiration from this on how this can already be done. And maybe some time in the future we get a better software based solution to do this with a PC. Also I was wondering if there is other software which is also good for sytem wide EQing and multichannel processing such as Jriver MC does?
