it could have been R3 Meta vs Reference 1 Meta, but search from erin's youtube channelReally? Where can I find this. I find various Kef reviews but not this one.
Yes that’s it!it could have been R3 Meta vs Reference 1 Meta, but search from erin's youtube channel
I don’t think anyone has done that yet!Thanks. I would like to see Reference 1 non-meta vs R3 meta though!
probably too specific as well, you could compare Erin's non-meta specs/video with R3 MetaThanks. I would like to see Reference 1 non-meta vs R3 meta though!
I have a Denon x3800h on order and I was considering these, along with LS50 Meta and R3 (non meta).
Given the 4 ohms impedance, how well would the receiver be able to drive them? Not sure if makes any difference, I plan to add one or two SVS SB 1000 or 2000 subwoofers.
Any thoughts on the matter would be appreciated.
Add a power amp absolutely for the subwoofer it's fine honestly I would pick the Svs 2000 and in the future add another one,the kef ls50 and R3 are both power hungry and they have a low impedance if I remember till 3 ohm or somethingI have a Denon x3800h on order and I was considering these, along with LS50 Meta and R3 (non meta).
At all of the 3 frequency regions where the impedance drops below 4ohms, phase has a very steep angle. I doubt that they will sound their best with AVR juice. 2 of these frequencies are above 100Hz and adding a sub may not completely solve the problem.I have a Denon x3800h on order and I was considering these, along with LS50 Meta and R3 (non meta).
Black or white non Meta R3's $1399 on KEF website. That's a steal.I have a Denon x3800h on order and I was considering these, along with LS50 Meta and R3 (non meta).
In your opinion R3 Meta or R6 Meta as a center channel if one already has a pair of R3 for L&R
It all depends on how loud you go, and at what distance.I have a Denon x3800h on order and I was considering these, along with LS50 Meta and R3 (non meta).
R6 Meta.In your opinion R3 Meta or R6 Meta as a center channel if one already has a pair of R3 for L&R
Thanks. I got a decent deal for a returned pair of R3 non-meta. Will listen at a bit more over 10 feet and will use a SVS SB-3000 subwoofer. I suspect it will be fine.It all depends on how loud you go, and at what distance.
Near field at reasonable volumes, should be no problem.
If you seat far away and like to crank it up, the impedance dips will give AVRs trouble.
Which port was used for that ref 1 measurement?I have a serious question about entire bookshelf/standmount KEF speakers from LS50 till now (except Reference 1 for some reason).
What the [kef] is happening in mid/low bass range?
BUT THEN
So basically you either buy British-made top-of-the-line product or a subwoofer in order to get proper bass, is that a point?
Or this is a cool feature of all cheaper speaker to compensate some additional bass - why Ref 1 doesn't have it then?
P.S. FR graph of Q350 (and others but less so) look suspiciously similar to speaker box calculator simulated response. In case you're doing it wrong. Uneven volume is first what comes to mind.
But this is KEF, world #1 of CAD speaker designers (saying this almost seriously). Any thoughts?
Okay, well, let's keep it in mind and check graphs again.They discuss the porting in the white papers, they are worth reading. There isn't a one size fits all low end response, I think they assume the majority of the lower priced speakers will be used near a wall, and the expensive ones will be used further out
As Erin wrote:BUT THEN
The speaker can be configured with (2) port configurations: “long” and “short”. I have provided the SPINORAMA and Estimated In-Room response for both (please note each graphic’s title). Harmonic distortion and compression/linearity testing were done using the “long” port.
