Small follow-up: Both Reference 3 Meta speakers have been cleared for warranty repair by KEF and the service center is just waiting for spare parts. Big kudos from my part to KEF.
Time for Show & Tell:
Listening to these R11 Metas (9' apart and 4' pulled into the room) with two KF92 Subs (crossed at 50Hz) + NAD M23 + Topping Pre90 + VMV D1SE + Zen Stream with the 15V Elite PSU (I know, let's not talk about this) + HQPlayer upsampling and Roon + EQ/Room Correction via HouseCurve app on iPad with my preferred Target Curve...too much processing, I know but worth it. All above equipment passes ASR standards, obviously!
Damn good speakers, I can tell y'all...
Surprisingly, putting a blanket over in the middle 77" screen improves the imaging and depth somehow?!
See in basement room setup response with correction filters below
Did I do good? Comments and suggestions welcome
The direct sound from the speakers is probably tonally quite similar in both speaker placements. However, when the speakers aren’t pointed directly at you, the early reflections in the room become slightly more pronounced and potentially a little more tonally accurate, which can contribute to a wider soundstage and better perceived overall tonality.I am still super confused as to why, especially for KEF/coaxial speakers, a toe in of a few 10-20 degrees sounds noticable more pleasant than straight on-axis-sound. Is that the on-axis turbulence coaxials have on the exact 0° axis? Or is it just the clean radiation pattern MAKES it sounds good in the room?
Still, I can't really get used to seeing speakers to exactly aimed at me. Must be a virus of my studio focus time.
In my experience it is a combination of both.I am still super confused as to why, especially for KEF/coaxial speakers, a toe in of a few 10-20 degrees sounds noticable more pleasant than straight on-axis-sound. Is that the on-axis turbulence coaxials have on the exact 0° axis? Or is it just the clean radiation pattern MAKES it sounds good in the room?
Why is The Panther not showed with this review? Seem like The Panther is also missing with other reviews. I’m sure there is an explanation But I am new to this (faboulus I might add) site. Oh, and could we get a COMPLETE list of The various Panther modes?This is a review, listening tests, EQ and detailed measurements of the KEF R11 Meta floorstanding speaker. It was sent to me by the company and costs US $3250 each.
The R11 Meta is gorgeous looking with high gloss finish and cabinet that has been shrunk as much as possible to basically hug the drivers. The coax center driver is the star of the show carrying most of the audible band from 200 Hz up (see measurement below). I was impressed with the engineering that went into binding terminal of all things:
With a turn of a knob, you connect the bass to the coaxial and vice versa! No jumpers here. Even the cardboard that the speaker came in has clever features like plastic that you pinch and it releases the sides of the box so you can get it out easier. First class execution all around.
KEF R11 Meta Speaker Measurements
As usual we start with our Klippel NFS robotic measurements of frequency response with acoustic center set to center of coaxial driver and grill left out (as well as port plug):
I sent out the measurement to KEF and correlation was excellent with their measurements. Their response was a bit smoother than mine but otherwise showed the same dip around 1.2 kHz and dip in bass response. Company explained that the former is diffraction related and goes away off axis and bass shelving was doing was done to accommodate room gain. I will check for this in listening tests later. For now, we can admire the nice directivity which is highlighted in off-axis response that is smooth and sloping down as we want to see it:
Very nice. Simulating room response we get:
The dip is not as pronounced now which is good.
I forgot to measure the port response but here is one of the woofers and coaxial driver:
Even in good speakers I am used to seeing woofer break up/resonances but here, that is so suppressed. Credit goes to the coaxial driver which goes so low, allowing earlier roll off of the woofer response.
Coaxial driver brings uniform directivity and that is precisely what we see:
View attachment 359177View attachment 359178
While competing waveguide solutions manage similar behavior horizontally, vertically they are usually a mess. Not so here. Vertical response of the R11 Meta is almost as good as horizontal -- a nice bonus!
Those quad woofers work to bring ease of bass and SPL handling:
It sounded clean even during sweeps. So I decided to push it to 102 dBSPL:
This is why you buy a high-performance tower speaker folks instead of bookshelf. Same amount of floor space but far better handling of music at elevated levels.
Some of you worry about the misnamed speaker "compression" so here are the three responses adjusted to land on top of each other, with proper vertical scale:
There is just no audible consequence as a result of going from 86 dBSPL all the way up to 102 dBSPL.
Impedance minimum falls at higher frequencies making it easier to handle as music is not as loud there:
There are some resonances as is the case with just about every speaker I measure:
And here is the step function for fans of that:
KEF R11 Meta Listening Tests and Equalization
Due to heaviness of the speaker, I tested the R11 Meta in our living room as you see in the review picture. This is a massive open floor space with ceiling at some 25 feet. Speaker was away from the rear wall to the tune of 5 to 6 feet (about 2 meters). Stock sound seemed "accurate" for the lack of a better term. I was curious what effect EQ would have on the two things that were visible in on-axis response: dip at 1.2 kHz and bass shelving:
I started with the 1.2 KHz (Band 2). This gave female voices more brilliance and pulled them out in front of the speaker a bit. Depending on the clip I played, I could see how someone would prefer it without EQ, while others would want it with that small correction. It was a trade off between sounding a bit bright (with EQ) vs a bit recessed (stock).
I then dialed in the bass response with that boost. I was prepared for some distortion but nothing remotely was audible in that front. Instead, I was greeted with glorious, deep bass that was substantially more rewarding than stock response. What's more it helped to balance the overall tonality with the 1.2 kHz filter, no longer having that tad brightness effect.
I cranked up my amplifier to 0dB reference and started to play track after track. Every piece of music was glorious. Deep, deep bass that was clean as a whistle. Upper range response was delightful while not being accentuated at all. With my wife and dogs around, my testing especially at these playback levels is usually limited but I was enjoying the speaker so much I kept going. Next thing I know, our female dog is worried, running to my wife to hold her. And the male dog coming to me giving me that look of: "what are these loud sounds???" After they did this three times I decided to sadly quit.
Let me summarize it for you: the stock tuning is designed to not remotely offend. The shelving in bass will mean even if there are significant room modes, speaker will not get boomy as I routinely hear from flat response speakers. And the small dip at 1.2 kHz means it will never sound sharp either even if the recording is such. In that regard, I would call the R11 Meta tuning "conservative." There may indeed by something to this tuning as starting point. Since we must measure the response and EQ in bass anyway, we can make the correction I did. But for those who don't, they will get a better response. So the choices here seem wise even though I like very much preferred the filtering I applied (especially in bass).
We expect excellence, objectively optimized response from KEF speakers and we have that in R11 Meta. My experience with budget coaxial designs is that they give up power handling which to me is a poor trade off. Not here. The R11 Meta has excellent bass handling with very low distortion allowing me to EQ it with no degradation as far as distortion of playback ability. There is a bit of room left here in there for enthusiasts who want the optimal performance to get there with EQ. Result was that even in our living room with many hard surfaces and large space to boot, a single R11 Meta roared to action, delivering optimal and super enjoyable response on every reference track I threw at it. Science and excellent engineering works!
I am happy to recommend the KEF R11 Meta speaker. Not only does it perform well, it is well priced as well.
Often doesn't fit in shot with speakers .Why is The Panther not showed with this review? Seem like The Panther is also missing with other reviews. I’m sure there is an explanation But I am new to this (faboulus I might add) site. Oh, and could we get a COMPLETE list of The various Panther modes?
Thank you very much, jimbob54. What about The postman Panther then?Often doesn't fit in shot with speakers .
Sometimes Amir forgets.
Pretty comprehensive list : https://www.audiosciencereview.com/forum/index.php?threads/asr-panthers.11541/
I expected worse than this when you cover the UNIQ. You are basically introducing another cheap plastic ring over the carefully designed plastic ring(shadow flare) which is a critical design element for the sound of the UNIQ.Please have a look at the measurement image below. Purple and teal are WITHOUT COVERS, using my KEF Reference 3 Meta "naked". Red and blue are WITH COVERS. I am surprised by this 2 dB drop in the HF range since these covers are pretty expensive and KEF advertises them as "crystal clear without altering the sound".
I just need an opinion here. Is this reasonable and in the range of "can't be done better" for magnetic cloth covers or should I really expect linearity even with covers?
Edit: Oh, purple and red are at 0,5m pretty much on axis. Teal and blue are 30° and about 1m distance.
