Extreme_Boky
- Joined
- Jun 9, 2020
- Messages
- 106
- Likes
- 72
Uninitiated can choose to continue with their sarcasm... it is serving as entertainment.
Remember this paragraph fellas... should read first.
"The USB cable will play an infinitely more important task, if you choose a DAC with its USB card (module) that is galvanically isolated from the DAC These DACs are usually much more expensive than the one you used for testing, and the USB cables in question would sound vastly different. Would they measure differently? They SHOULD, in this case... ESPECIALLY at 1024DSD / 1.536MHz rates.
If they don't (measure differently) => the measuring equipment test jig is not used in the appropriate user case/scenario, AND the test-sets are of insufficient ability to capture what we humans can hear."
