There are 2 on the spinorama.org site. Pierre has done a amazing job compiling data on a large number of speakers!Did anyone provide an EQ based on Erin's data?
Anechoic EQ for loudspeakers
Scroll down to the A130
Can’t do objective but for me Infinity Primus 150 > Pioneer B22.Hi guys
What’s the best choice:
- JBL stage A 130
- pioneer sp bs22 (a guy here in my country have an old stock with 2 pairs in a box)
Musical style: jazz / acoustic guitars / vocal / country / soft rock / 80’s and 90’s pop
Thank you so much for point me the best option
Forgot about price: JBL is cheaper ( ~50 dollars)
Tks guys.
I meant to imply a family resemblance between the Harman speakers. Check out the Stereophile review of the Infinity and the JBL review here for objective information.Long time ago…. infinity Primus was my first speakers.
But today in my country I have to focus on the 2 speakers I wrote.
I do have the JBL Stage A130's collecting dust. I thought they would be good sounding per original ASR review. They lasted 4 months, as were too neutral for my ears, listening to DD movies and more so for internet MP3 music. I also have the older Polk E-15 and were nice, right out of the box.Long time ago…. infinity Primus was my first speakers.
I have an option to buy a Polk Es 15 or Q Acoustic 3010i too.
But pioneer and jbl are cheaper.
Tks !!!I do have the JBL Stage A130's collecting dust. I thought they would be good sounding per original ASR review. They lasted 4 months, as were too neutral for my ears, listening to DD movies and more so for internet MP3 music. I also have the older Polk E-15 and were nice, right out of the box.
With the 2 speakers you have mentioned, I would lean towards the ES-15, for out of the box performance. Good luck with your decision.
Tks.Looking at mfg specs on both Polks, ES being the newer, there isn't much difference, IMO. I'd go with the S15, as hardly worth going to the ES for a small difference. The crossover might be a little better on the ES.
It's still being sold by various sources in Singapore, albeit mostly on discountI've noticed Amazon, Crutchfield, and JBL, etc. all are out of stock on the JBL Stage A130 speakers and do not expect a restock. Is this speaker being discontinued or is the model being updated or something? I ended up ordering one from Japan from eBay today so I wouldn't have to buy used.
I took mine apart and had a look. Everything seemed to be wired correctly. Is this an issue where the tweeter is out of phase with the woofer? If so, how would switching the wires at the terminal fix this? I'm always looking to improve my system. Especially when it's this easy.... and at zero cost. I'm not writing off what you've said, just trying to understand.the last review on Crutchfield says, "Yes, they are an engineering marvel with an architecture that is spot on at any price. Yes, they are an advanced phase dependent design. Yes, JBL sold thousands of these babies out of phase because they overachieved, and not by a smidgen either. The difference depending on phase is absurd. You've just gotta swap "polarity" at the terminals to find out. You may be rewarded with improvement that is total.....coloration eliminated (and I mean COMPLETELY), jaw dropping texture across the entire spectrum, bass accuracy, imaging, vocal presence. It's all there."
It was likely poster #997 of this thread after making his claim, CardiganB was asked for the source of his information and replied on Feb 15, 2024:the last review on Crutchfield says, "Yes, they are an engineering marvel with an architecture that is spot on at any price. Yes, they are an advanced phase dependent design. Yes, JBL sold thousands of these babies out of phase because they overachieved, and not by a smidgen either. The difference depending on phase is absurd. You've just gotta swap "polarity" at the terminals to find out. You may be rewarded with improvement that is total.....coloration eliminated (and I mean COMPLETELY), jaw dropping texture across the entire spectrum, bass accuracy, imaging, vocal presence. It's all there."
That was it, he may even be the Crutchfield reviewer, which was written February 27, 2024,The source is right here in my bedroom. Polarity swapped, never to return to its former sad state. Two hundred dollar speakers that could be sold for two grand and nobody would be the wiser. There's some sorcery going on with these things. Here's the list of improvements once alignment is corrected: 1. vocal presence restored
2. mid-bass boom eliminated
3. Accuracy, resolution, texture are elevated to mind blowing.
4. Imaging is vast
5. less excursion for a given output
They were originally measured with the grills off, I do not know if there is an actual audible difference either way.very confused about leaving the grills on
