All the Yamaha units made today have extremely sophisticated monitoring and protection systems. Even the stereo A-Sxx series amplifiers have A/D lines for three individual temperature sensors (L/R and TXF), DC, Over current sense, etc. The 16bit processor itself has 26 (yes) 10bit A/D converters for such inputs.
Previous protection events are stored for recall etc.
They are in a whole other league to traditional old-skool methods of protection. That being said, it is necessary because they are running these things on the ragged edge if you ask me. Output devices are not expensive and neither are press-fit fin aluminium heatsinks. I'd rather see more capable amplifier channels than ones that prematurely or catastrophically shutdown/fail.
Yeah, that's an interesting situation.
Still, I should point out that protection mechanisms are often a better solution than throwing lots of power transistors at the problem. MC2 amplifiers have relatively few output transistors for the power level (I think 5 pairs in the MC650, and 3 or 4 pairs in the MC450). By contrast, Crest amps (3301, 4801, etc) have
far more output silicon than the MC2 amps do, but in my experience are less reliable. Crown is somewhat notorious for this too - the Macro-Tech amplifiers were NOT overbuilt in their output stages - the 3600VZ has 6 pairs per channel, and it will do 1800 W 2 ohms. Both Crown and MC2 used pretty sophisticated protection schemes that work really well, and it shows. The Crest CA6, on the other hand, has a much less sophisticated (but still pretty good) protection scheme it in it. They're no more reliable than the Macro-Tech or the MC2.
Of course, you do still need enough silicon to cope with normal loads - some companies cut things a little too close. That said, the number of transistors required doesn't really scale linearly with output power, because increasing output power requires higher rail voltages, and unfortunately, power transistors can't dissipate their maximum power under all conditions - secondary breakdown ensures that above a certain V_CE, their power dissipation starts to fall off a cliff. This is a big part of why large power amps tend to be class H.
The point is, part of designing an amplifier is making sure it can survive in the real world. Tube amps can get away with little to no protection circuits, aside from something to protect against open speaker terminals. Transistors are delicate little flowers, and they need babysitters to stay alive.
