HTD Level THREE Review (Bookshelf Speaker)
KxDx
Tidewater Virginia
Brutal.
A few years ago I was seriously considering the towers. The only reason I didn’t was because the free returns didn’t apply to those. I’m now thankful that’s how it worked out.
maverickronin
Midwest, USA
A preference score of just .2, wow a new high in lows. A headless panther isn't enough for this. Let's get one that was run over by an F-150. thank you @amirm for knocking another fairy tale into the weeds.
CRAP!! This must be the lowest "Preference Rating" scored speaker ever measured at ASR!! A total train wreck!!!
That's likely the Lowest low , a "record" low :D
Everyone's forgotten the 3 negative scores we've had so far?
-0.1
-0.25
-0.6
OFC, the score isn't really trained on dipoles or omnis, but there's one monkey coffin in there...
enricoclaudio
Houston, TX - USA
-0.1
-0.25
-0.6
Yep, but this one even with a sub only scored 2.2 :eek:
HiFidFan
U.S.A
We need a panther thats broken into a few dozen pieces, to match the speaker's response.
What a disaster.
theyellowspecial
Does HTD have lower models in their lineup? Maybe we can hit a negative preference score.
Beershaun
Blumlein 88
But it provides bi-wiring terminals lmao. This speaker looks to me like they weren't sure about what target group to choose. Allthough it looks like this is a design to tick as much boxes as possible. Ceramic woofer... bi wiring terminal... ribbon tweeter....
Bi-wiring is useful in this case. You can disconnect the tweeter and add your own duct-taped to the box and likely have an improved speaker. No need to do any testing just grab any dome tweeter and level match by ear.
Longshan
This is the company’s description FYI:
First heard about them from Zeos:
I own an older gen model of the L3 (soft dome tweeter with no waveguide) and it and it’s matching center were my mains for my living room for years, they sounded fine with room correction. I now run I finish R263 & RC263 and if I had to guess I’d say dialogue is a better more intelligible, but the center was a regular MTM, so that’s be expected (I sit off-axis).
Ah, this guy. . .
Maiky76
French, living in China
This is a review and detailed measurements of the HTD Level 3 bookshelf speaker. I got talked into buying it by members due to its popularity in home theater forum. For you all's sake, it better perform! :D I don't remember what it cost me but the current price in black is US $429 from the company direct.
I must say, I am very pleased with the way they look:
I guess I have a soft spot for white woofers. I also like the rather serious look of that tweeter.
Back panel shows a couple of screws which should make it much easier to hang this from walls for your side and rear channels:
Screw binding posts are too close together making it a pain to tighten or loosen them.
Measurements that you are about to see were performed using the Klippel Near-field Scanner (NFS). This is a robotic measurement system that analyzes the speaker all around and is able (using advanced mathematics and dual scan) to subtract room reflections (so where I measure it doesn't matter). It also measures the speaker at close distance ("near-field") which sharply reduces the impact of room noise. Using computational acoustics, far-field response is computed and that is what I present. Both of these factors enable testing in ordinary rooms yet results that can be more accurate than an anechoic chamber.
I performed over 1000 measurement which resulted in error rate of about 1%. Clean high frequency response is responsible for ease of measurement in this regard.
Reference axis is approximately the center of the tweeter. Grill was not used.
HTD Level Three Measurements
Acoustic measurements can be grouped in a way that can be perceptually analyzed to determine how good a speaker is and how it can be used in a room. This so called spinorama shows us just about everything we need to know about the speaker with respect to tonality and some flaws:
The only word that comes to my mind is "wow" as is "wow, that is bad!" There are so many problems here. First and foremost is the peaking tweeter response as frequencies climb. The overall response is so jagged and we have some sudden anomalies. Sensitivity is also quite low as evidenced by me having to turn up the gain to measure the speaker by some 4 to 5 dB above average speaker. For some clues as to why the response is so bad, I disconnected the rear binding posts from upper and lower halves and measured the tweeter and woofer independently:
We clearly see some of the issues behind our frequency response errors. The port is letting out some nasty resonances and the tweeter response is anything but smooth and flat.
Even the impedance measurement shows us something seriously is wrong:
One can say that getting proper frequency response is difficult for smaller companies but impedance measurements are dead simple. Whatever is going on around 260 Hz should have been found and dealt with. While on this graph, unlike many speakers, the minimum impedance is ht around 2 khz to the tune of 3.6 ohm. For bass frequencies it is above 6 ohm which is good.
Back to our "spin" information, let's look at the early and strongest reflections in a typical room:
We see many of the same problems here. As noted, if you put an absorber behind your seating position (your back wall, speaker's "front wall"), it may help with the extra brightness.
Predicted in-room response smooths out some of the problems but leaves a lot:
There is some good news in the form of very good directivity control of the tweeter in the horizontal dimension:
Vertically is a mess but so are many 2-way speakers:
Getting proper distortion measurements is hard because the frequency response is so wild. I adjusted it for mid-range levels and got these:
These are some of the worst distortion measurements on record but note that many of the issues are narrow peaks so audibility will not be as bad it may look.
HTD Level 3 Listening Tests
The immediate reaction was the extreme shrillness of the highs. It is over the top unless you have lost all of your high frequency hearing in which case, it sounds fine. :) This "showroom sound" can sound appealing -- for a bit at least -- so please don't write that you don't think it sounds bright. Measurements say so as do my ears. But the overall feeling of clarity that such overboosted highs present is hard to deny.
There is some cleverness in the bass response in that this speaker can play very loud without bottoming out. It simply filters out deep bass that it can't play so fits its intended usage of home theater sound with subs and such.
At times, I enjoyed listening to them despite all the flaws there. This may be due to controlled horizontal directivity.
I did not bother to develop an EQ. There are just too many issues here to deal with. Best to get a better speaker that doesn't require so many fixes.
Objectively the HTD Level 3 is a disaster. Clearly no measurements were performed to verify efficacy of the design. That said, while some aspects like high frequency boost are clearly audible and annoying, the rest of the response hurt the eye more than the ear. Bass tuning is clever to keep the speaker from distorting and hence allowing it to play quite loud. And there is something to that wide and controlled horizontal directivity that I can't quantify but I think contributed to sound that is not nearly as bad as measurements show.
We could look at this speaker as a puzzle given the huge number of flaws in its design but yet, not so horrible sound and try to figure out what is going on. Me? I just rather get a good speaker that doesn't make me spend this kind of effort on it. :) The designer should do more than is delivered here so my work is touch up and no more.
I can't recommend the HTD Level Three and curse all of you who made me buy it. :)
Hi,
Here is my take on the EQ.
These EQ are anechoic EQ to get the speaker right before room integration. If you able to implement these EQs you must add EQ at LF for room integration, that usually not optional… see hints there: https://www.audiosciencereview.com/...helf-speaker-review.11144/page-26#post-800725
The raw data with corrected ER and PIR:
Score no EQ: 0.1
With Sub: 2.2
Note: the Canon and speakers have low scores indeed but the model is probably not adequate to score them because of their directivity
Spinorama with no EQ:
  • Resonances!!
  • Too many better speakers to end up with this one
Directivity:
1kHz mess!
Better stay at tweeter height
Horizontally, better toe-in the speakers by 10/20deg and have the axis crossing in front of the listening location, might help dosing the upper range.
EQ design:
I have generated two EQs. The APO config files are attached.
  • The first one, labelled, LW is targeted at making the LW flat
  • The second, labelled Score, starts with the first one and adds the score as an optimization variable.
  • The EQs are designed in the context of regular stereo use i.e. domestic environment, no warranty is provided for a near field use in a studio environment although the LW might be better suited for this purpose.
Score EQ LW: 2.5
with sub: 4.6
Score EQ Score: 3.1
with sub: 5.2
Code:
HTD Level 3 APO EQ LW 96000Hz
September132021-110743
Preamp: -2.2 dB
Filter 1: ON HPQ Fc 30.94,    0.00,    0.55
Filter 2: ON PK Fc 268.73,    -1.39,    5.98
Filter 3: ON PK Fc 354.73,    -3.39,    5.98
Filter 4: ON PK Fc 412.01,    2.99,    3.70
Filter 5: ON PK Fc 702.43,    -4.26,    5.76
Filter 6: ON PK Fc 967.52,    2.85,    2.06
Filter 7: ON PK Fc 2232.74,    -1.04,    0.69
Filter 8: ON PK Fc 7391.51,    -2.00,    4.71
Filter 9: ON PK Fc 9472.64,    -3.47,    5.13
Filter 10: ON PK Fc 15125.03,    -8.98,    1.22
HTD Level 3 APO EQ Score 96000Hz
September132021-110652
Preamp: -2 dB
Filter 1: ON HPQ Fc 34.91,    0.00,    0.70
Filter 2: ON PK Fc 281.82,    -0.98,    5.98
Filter 3: ON PK Fc 354.64,    -3.39,    5.98
Filter 4: ON PK Fc 397.23,    2.99,    4.90
Filter 5: ON PK Fc 700.43,    -4.26,    5.76
Filter 6: ON PK Fc 915.87,    2.85,    1.81
Filter 7: ON PK Fc 2281.26,    -1.53,    0.69
Filter 8: ON PK Fc 7223.31,    -3.00,    5.95
Filter 9: ON PK Fc 9555.98,    -4.98,    5.80
Filter 10: ON PK Fc 14501.36,    -9.70,    1.22
Spinorama EQ LW
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal
Radar no EQ vs EQ score
Large improvements but still KO...
The rest of the plots is attached.
  • HTD Level 3 APO EQ LW 96000Hz.txt
  • HTD Level 3 APO EQ Score 96000Hz.txt
spacevector
Bayrea
@amirm, please humor me and try a couple EQ filters to see if these can be salvaged. Seems you enjoyed some bits of it and directivity is quite good for EQ. Thanks for another great review.
GimeDsp
Earth
Your request is one in a very long line of people asking the same thing.
$450 is a lot of money for broken.
USER
I don't understand this sentiment. These are exceedingly popular on various forums as a recommendation for better value than the big brands. We need the data to validate or invalidate such recommendations.
Oh, of course they should have been reviewed, but Amir shouldn't have had to buy them. They aren't cheap. Precisely because they are popular they should have been sent in by someone, especially as there was confidence expressed.
Sancus
Oh, they should have been reviewed, but Amir shouldn't have had to buy them. They aren't cheap. Precisely because they are popular they should have been sent in by someone.
What's funny is now he has to find someone who hasn't read the review to sell them off at a price that would recover any of his money ;)
Doodski
One wonders if destroying piles of it at year's end would be better than cataloguing it and carrying a inventory. :D Can have the bean counters over for a good old fashioned tractor drive over the stuff in a parking lot.
To be clear, I have no regrets in buying it. I was just teasing. When something is popular and no one else has one to loan, then this is an available option to get access to the product.
FYI two members helped with the purchase cost which I very much appreciated.
