KEF R11 Meta Tower Speaker Review
Rate this speaker:
    Votes: 5 0.9%
    Votes: 9 1.6%
    Votes: 96 17.6%
    Votes: 437 79.9%
Regarding the need for full towers like the R11 when you have subwoofer(s)...
With Dirac ART, this dilemma changes once again. I am going to move my R3 to surround duty and buy R11 for the front. With my home theater being almost a perfect cube, this will likely improve some of the nulls which are defying passive treatment. I can hope at least. ;-)
Let us know about your eq readings once that happens! It should be interesting to see the results. :)
Certainly! First though, Dirac has to release ART for Denon AVRs. Last I heard, beta testing is done and perhaps we’re just waiting on Masimo to release it.
Interestingly, if ART can help tame nulls with full size bed layer speakers, that will significantly change the benefit of larger towers like the R11. I too am looking forward to seeing more real world results.
Even a simple REW graph of before and after can give us an idea of the changes without EQ. With ART, that can be helpful to other users as that can shed some light on what to expect.
What are you planning to use for surround rears? I'm planning a similar (but cheaper) system around the R series.
Our room has some placement challenges. I’d prefer another set of R3 Meta for the rear, but we have to use ceiling speakers. Atmos x4 and the rear surrounds will be KEF Ci250RRM-THX. Our seating position is in the center of the room, so rear elevation will be greater than recommended. There will be separation from the rear Atmos due to the length of the room. The rear surrounds will be close to the back of the room along a wall/window boundary. In prior systems, I’ve had good sound with some compromises to the rear surrounds so I think is worth going with a 7 channel setup.
I love the R Mera series except for the gloss finish. It's the only thing holding me back from purchasing.
I wish there were more cardioid speakers. Not everyone has the space to keep the speakers far enough from walls. That's why the D&D 8C are still my dream speakers.
Mesanovic makes a couple of great cardioids also.
Reactions: Koo
to be honest, this must sound very different than the previous R series without eq
R3 UNIQ:
Do i need these when I want to upgrade from my Polk R700? Are they significant better?
The shape of the bass roll off has me wondering what you would have subjectively thought if it closer to the wall behind it an no bass boost filter.
In my experience moving speakers closer to the wall behind them to enhance bass performance has a negative impact on midbass frequencies in the vocal range in almost every case.
Speakers should be close to the front wall to minimise their own cancelation , but you may have to take steps to treat any undesired room gain, which was impossible with ‘traditional’ systems.
Cut away of either the R11 (Meta?) or the Reference 5, not sure. from a facebook post. More likely the Reference 5 based on image matching and word "Reference" on stand below speaker, but there's no review thread for any of the Reference towers on ASR.
Actually, someone else shared what looks to be KEF's image of the interior of the R11 Meta as well:
Note the lack of any dynamat or other typical surface-adhered rubber or foam products anywhere on these speakers, consistent with the engineering feedback that those products don't work very well when applied to MDF inside a speaker cabinet. There is lots of stuffing everywhere, again consistent with engineering advice on that strategy.
That’s the Reference 5 (could be Meta, hard to tell from such an image), the black and copper colour way is not available for the R series.
The top image is a Reference 5 (non-meta) from the KEF factory/museum in Maidstone, Kent.
The bottom is the R11 Meta.
Hi, new to this forum and i don't know if this is proper etiquette to talk about other brand in this forumn.
There seemed to be alot of loyalty or many fans to this brand. I am looking to buy a new pair of towers( I have a emotiva t2) and I learned about this model through YouTube and I was getting excited about this speaker. However as I read more and more I find myself thinking is it worth spending almost 7k on this pair or should I spend alot less on a arendal 1723 or even a martin Logan xt100. Are there anyone here that have experienced with arendal 1723 and is there a real difference between this and the r11. R11 build quality seemed be a little inferior to the 1723 but the esthetics of the r11 and the martin Logan xt 100 is much better looking imo. Can anyone offer their 2 cent about this. Thanks
"R&D Engineer - KEF" - that's a dangerous sig to have around here- someone might ask you a question! :p (I have two in mind already)
If I remember correctly, AOR did quite a nice amount of work on the LS60 on the part of the DSP. Dr. Oclee Brown is also with us and does not shy away from answering questions.
Do not be ashamed to ask, they do answer. :)
hehe, well, it certainly doesn't hurt although I'm not holding them to it expecting an answer. Let's try a two-parter:
The LS50 and Blades use rounded front baffles, while the R and Reference series use flat baffles with sharp-ish edges. Given the papers and study on baffle edges, diffraction, and just general baffle shape, ala Olson, but mostly as it affects diffraction, is there a reason why the curve of the LS50 or that of the blade isn't always better than the R/Reference flat baffles and curved baffles are just that hard/expensive to make, or is the R/Reference flat baffle actually comparable in performance, and if so, why? And part two- if you could extend these baffles to something say 2-3 feet wide, would the curvature of the LS50 be your starting place, or would it be more flat, ala R/Ref, or more curved, ala Blade? All this assumes passive with free crossover design and a minimum frequency range of the drivers on the face down to perhaps 200~300 Hz.
Now maybe if the rest of us can resist chiming in for just a day or two in hopes of a response from @AOR or anyone else from KEF (and like this post if you want to hear an answer), and then let loose :)
