Which is what I have. Love them!But 100% worth it. And in a few weeks or so, I'll have 3![]()
So $25k for 5.0You can rotate them sideways. It comes with a different stand for that purpose.
I need to take my Oppo 205 and some DVD-A/MCH SACD to @echopraxiaSo $25k for 5.0![]()
That's gonna be an awesome system. Eventually you gotta get the W371s below themBut 100% worth it. And in a few weeks or so, I'll have 3![]()
FWIW, Coincidentally the KH420 weighs in at 77 lbs.I wonder. 70 pounds impossible to move? I'm nearly 70, and a single old man job. Maybe a generational thing.
Maybe you can get quantity discount to $24K.So $25k for 5.0![]()
If they're that close, I wonder if running GLM calibration on the 8361a might give it the edge.I would not but it is a close call. The Salon 2s project a larger image and similar bass capability so not an advantage over them.
Those aspects do not change with EQ.If they're that close, I wonder if running GLM calibration on the 8361a might give it the edge.
I believe in form follows function. Even though I am not a committed Genelec lover, they look fine to me. If anything, it's big sound out of a relatively small box.Yes, their look is polarizing for sure. Nobody can doubt they are excellent performers, but there's no way I could tolerate the style of the Genelecs.
When I was young, my Dad would say children should be seen and not heard- these speakers are the opposite.
A sick new camera, and a few G-Master Sony lenses would be awesome haha.These look incredible, but one starts to wonder what else you could spend $10k on. I could buy 4 pairs of 2k/pair speakers. That's 8 speakers in the room making a killer multichannel setup! Not to take anything away from the 8361a. It's clear what you are getting for $10k, but in terms of the value proposition, we are climbing a steep slope of diminishing returns from $2k-10k.
Hi guy. I am very confused with powered speakers.
If I want to pair the Genelec with my benchmark DAC / Pre / Amp system, can I just connect signal out cables from a preamp to the speakers?
Or the speakers must be fed just a signal from a DAC.
I used to download the manual and read it, but I didn't understand fully. It seems to have a internal DAC inside each speaker. I am not 100% sure how to setup the Genelec system. It is worth exploring though.
Thank you.
Speechless..
Question to Genelec? Can they be painted?
Hi
+ 1 on the underlined part.
I have lived with live instruments in my house. Pianos ( upright and Grand), Violins ( several, Cellos ( several)... What you hear on record is often far from what you hear at concert and again it depends on the seat and venue... Violins for example have much more treble energy than heard in most audio systems. The "massed strings" sweetness that many audiophiles talk about is a construct of rolled off systems or of recordings.
Back to the 8361... Endgame speakers? You bet. These are capable of 118 dB !!!at 1 meter... per speaker! Flat from 30 to 20KHz, Textbook directivity, low distortion. Yeah, Endgame, Drop the Mike, Slam-dunk...
I think that "diminishing returns" start even lower than 2k/pair for near/midfield monitors, but why should the pro audio market be different to any other market? Every market has a basic segment, a "value for money" segment and a "you only live once" segmentThese look incredible, but one starts to wonder what else you could spend $10k on. I could buy 4 pairs of 2k/pair speakers. That's 8 speakers in the room making a killer multichannel setup! Not to take anything away from the 8361a. It's clear what you are getting for $10k, but in terms of the value proposition, we are climbing a steep slope of diminishing returns from $2k-10k.
I have checked some of that options with the much cheaper Genelec 8340 , that also have digital input.Hello,
There are 2 ways to connect to active speakers: analog and digital (on AES).
So in your case, you can
- go from the pre directly into the speakers and do the volume control on your pre.
- go from the DAC directly into the speakers and do the volume control on the speaker (with GLM)
- ´go from a numeric source to the numeric entry of the speaker (you will need a box if input is not AES). volume control can be done at the source level or in the speakers
Good news is: you can sell the stack and you have a significant part of the cost of the speakers already.
P.S.: you still need the pre if you have a turntable. I use a RME box to aggregate various numeric and analog signals and fed the genelec on aes.
The quality of the benchmark stuff is higher than the components inside the Genelec but the difference is not audible.
Often if your box has a SPDIF non optical, it will connect well to the Genelec with a passive adaptor. That’s the same format, just with a difference connector and impedance. Since it is a numeric signal, you have no loss if it works and no signal if not.
In my opinion, the lack of naturalness you hear in classical and acoustic music is due to the fact that in the middle frequencies the third harmonic stands out over the second, giving a spark to the dynamics, but denaturing the timbral. This is the only fault that I see in these speakers. Very good for electronic music, can be improved for classical, acoustic and classical jazz.This is my first post here. I currently have a pair of 8361s set up in my listening room for an in home demo. I have owned and heard many excellent speakers over the years. I have a different perspective from many members here in that I have a soft spot for bbc inspired speakers as well as quad es. I listen mostly to classical music. I agree that 8361s have a remarkable amount of clean, excellent, well integrated bass. astounding really for a speaker of their size. They can play much louder than I would ever care to listen. They certainly appear to have no distortion and to be exceptionally clear at all volumes. The detail presented is amazing. I really can hear things on recordings that I had missed before. I have no doubt that they are everything Amir says and that their designers wanted. Nevertheless, my experience is that the speakers are poorly suited for classical or other acoustic music. I think that strings sound harsh and piano brittle. Depsite the excellent measurements and clear virtues of the speaker, the e string on a violin is artificial sounding to me, harsh, unpleasant and cold. I find myself dreading the high notes. The beauty of live acoustical music is just not conveyed by these speakers In my room. The speakers are incredibly impressive, but do not companionable.
Now, all of this is without equalization. I have a GLS system arriving today, and it may improve things. I understand that I am posting a contrary view here. I do not doubt that these speakers are surely all they are intended to be for non-acoustic music, but they produce a sound, at least without eq, that is little like real acoustic instruments. I also understand that most here will take me to be an out of touch subjectivist ignoring the objective measurements. I do not intend to be anti-scientific or disrespectful in any way, but merely to report my short experience experience listening to the speakers. I hope that eq will fix the problems, for the many virturpes of the speakers are obvious, but I would not call them musical speakers, at least for classical music. Do others here who listen to classical music disagree?
