Behrelec 37
Muddywaters
Should we wait for them?
I wouldn't hold my breath.
Don’t hold your breath.Muddywaters
I wouldn't hold my breath.![]()
What distance is that measurement, and how far do you listen? There isn't the normal high end roll for far field listening.Hey!
Ive got the 8361A's together with GLM. Its butter. But Im finding the violins and pianos slightly harsh on most recordings when listening to classical music (my music taste is all over the place, and they sound sublime in other genres). Like too skreechy.
Im thinking a simple high shelf filter in GLM should do the trick, but what cut off frequency? I dont want to over do it.
Right now ive got -1.5dB at 5000Hz. But do i need to go lower on the frequency or lower on the Gain, or both?
Any advice?
Speakers 2m apart. My ears are 2m from each speaker.What distance is that measurement, and how far do you listen? There isn't the normal high end roll for far field listening.
Wut?What cables are you using?
A simple shelf might not be sufficient. You probably want a curve that rolls off with more slope. A series of shelf increments would do it.Im thinking a simple high shelf filter in GLM should do the trick, but what cut off frequency? I dont want to over do it.
Instead of shelves try using a HF tilt preset in the Sound Character Profiler.
Unfortunately glm is pretty limited on what filters you can do. $8k speakers dont have enough processing power in 2025 lol.
ok now do a harman house curve in glmWhat are you talking about? GLM allows an almost unlimited number of filters. The two shelves are just the simplified option in the Sound Character Profiler, which applies to the entire system. But for each speaker, GLM allows incredibly fine-grained EQ, if for whatever reason you wish to do that manually.
That can be done in a few different ways, with or without a sub. What the heck?ok now do a harman house curve in glm
yes that.You can't easily get a curve the same way you can with DiracLive or Audyssey. You have only the tilts and custom peq both of which are really annoying because you can't save them. At least the tilt is easy to do the entry.
