Genelec 8361A Review (Powered Monitor)
Rate this speaker:
    Votes: 9 1.2%
    Votes: 4 0.5%
    Votes: 35 4.6%
    Votes: 705 93.6%
The spl horizontal and vertical contour is very very similar but the spl horizontal and vertical globe is a slitly better on the 8341a. Maybe this gives some indication?
Doesn't mean they both can't disappear but if you want to be technical.
I mean they both disappear in the audio sense. Sounds do not sound like they are coming from them. At all.
What I meant by disappear is simply the visual impact which does not matter if you listen with eyes closed.
If you have 8341 in your possession and you order a 8361 the day it shows up you will be shocked.
It’s exactly like that.
I don't think anyone is debating the factual size difference or visual appearance, just the stereo imaging.
Fine now that we’re clear on that then I would say there is no perceptible difference as stated by Genelec themselves. Sure the measurement may be slightly different but if anyone can in a double blinded ABX test determine which is which I would be shocked.
The Genelec position on the Ones is that they all sound the same except in SPL capability.
I would just look at their distance/SPL charts and buy the smallest one that meets my needs. However since we are audio enthusiasts we might not have a problem spending 25% more for “just in case”.
I personally went from 8341 to 8361. No difference audibly. I even have them on their sides.
An interesting test would be to compare them at a longer distance and see if the difference became more noticeable. level-matching might be hard tho.
If you played content that didn't go below 100hz and didn't get anywhere near SPL limits, I'm quite confident that you would hear variation in room effects long before you'd hear any fundamental difference between the various sizes of Ones, even if they were placed side by side.
The bass extension and output differences are obviously pretty easy to detect if you try with the right content.
Level matching can be done directly within GLM. It’s just that the bigger ones can go to higher levels. So at some point the 8341 will flash that orange light before the 8361 does.
They will be quite different due to their respective bass response, as their room interaction is pretty much different. Placement of the 8361 will be more challenging.
I'm currently thinking about buying a pair of monitors to put in my large office where I listen to music for my work. I never listen very loudly: the SPL is therefore not a criterion with the strongest coefficient. So what you say there interests me a lot. I would listen at a distance of 2 meters.... And if I follow you, I save money...
One question: can we integrate a box other than a Genelec with GLM or are we forced to buy a box from them?
(Not a Box but a subwoofer)
Yes I would get the GLM box just it’s only $270 and opens up the real point of these monitors. My dealer included them for free anyway just ask.
For playback very simple - usb from a computer to $120 Topping D10s - spdif to BNC cable - Canare BNC to AES. That’s it. Less than $200 all said and done to play music to it.
I would also get the Genelec volume knob. Otherwise you have to use the GLM software to control levels.
Glm is Genelec only.
Not sure it's true but I've been told WiiM Pro Plus could control it's volume too
Anything can and it depends on the interface you like. I like physical volume knob. Otherwise you can control it in your playback software. But that’s risky if you have that at 100% you will get the shock of your life.
Also now GLM 5 seems to start up at -60dB to prevent that sort of thing.
Btw just to clarify. The GLM box does not touch your signal at all. It simply allows calibration and control of the monitors themselves.
IMHO it is a must have with any Genelec DSP monitor.
I expressed myself badly: I meant can we use GLM with a pair of Genelecs and a subwoofer from a brand other than Genelec?
I have an "old" Tact 2.2X digital DAC preamp that has XLR and RCA outputs and digital outputs as well... And it has a physical volume knob... which I also prefer over software volume adjustment...
Ok so the answer to the GLM subwoofer question is that GLM can only integrate Genelec subs. They are very expensive for what they are.
I was going to suggest a Trinnov to integrate other company subs. Can your Tact do this task?
Also i’m not sure you would need a sub for an office situation.
My desk is 4m x 7m...and my listening distance will be around 2m to 2.5m and more if i want.
They are annoying with this obligation to use a subwoofer of their brand with GLM. Because their boxes are too expensive, especially their column-shaped model... Really too expensive: 9000 euros...
Yes, my Tact 2.2 can integrate the subwoofers: it has a high and low pass filter adjustable in frequency and slope (from memory up to 350 Hz and 48 dB)... I kept a laptop running XP and RS 232 serial port to make it work...
Not sure you'll need subs with 8361
