The Sopra’s crossover is 2.1 kHz so the distortion spike you see at 1 kHz is one octave below.The upper lines look very similar to me.... how can you tell?
While all focal beryllium tweeters look exactly the same, they are all different for each lineup.
Kanta's tweeters are not the same as Sopra's one.
Kanta's one are the latest iteration of their IAL tweeter (IAL3).
Does means nothing about being better or not than previous ones.
Just having different parameters.
I have Kantas 2 and my subjective opinion is their are not harsh at all and way less than my previous speakers (few DBs less in the treble region).
My own measurements seems to validate that point.
When looking over the web for subjective opinions, it seems that there is a lot a people indicating that kanta's are less harsh than other focal lineups.
I can't confirm as I did not had a chance to measure any other beryllium based focals.
What are you using for DSP, the Dirac? Does that require you to have a PC in your listening room?I assume that all kantas shares the same tweeter.
Now, as all models have different parameters (shape, crossover, ....), some difference are to be expected, especially between No1 and No2/No3 ( between these ones, only the low frequency response should change).
Generally speaking, Focal speakers are not "shy" in the trebles.
And the result depends on the room and placement as most of speakers.
That's why, for me, DSP is a must have, especially bright untreated room.
Does not matter if room /speaker have some fixable minor issues (depending on speaker capabilities , directivity, ...).
For example, with Dirac, I lower down a bit trebles using a low slope, not because it is harsh, but because the room is bright.
I never trust online reviewers that review subjectively without backing up claims /opinions with measurements.
Without proof, that's bullshit.
I am using a minidsp Flex.What are you using for DSP, the Dirac? Does that require you to have a PC in your listening room?
Most room correction software in entry-level AVRs have a lot of weaknesses as opposed to strengths. Dirac has gotten into the realm where it's actually very good and suitable for enthusiasts.I don't really like room correction software.... would a EQ tame the highs on focals? I know from my Sonus Faber Lumina II, treble doesn't really help.
