Sokel
- Joined
- Sep 8, 2021
- Messages
- 10,467
- Likes
- 11,329
That's a horror story there,I was not aware of that.Should have known the NAD shill would turn up here!
No, it is not a safe and acceptable means of HT Bypass using the preset feature, not by a long shot. The user Nocko has explained this to you on several occasions in the M66 thread, if the input is changed then the volume remains at home theatre preset level, i.e max! - every time you change away from the HT preset you do not want to have the device left at literally speaker blowing levels.
Tbh it sounds like an easy firmware job really, assign a default volume to each input..... hopefully they will do this, but until then it's not a safe (and more pertinently idiot proof) method.
Nad should know better,WAY better.
Levels and their fail-safes are the utmost critical implementation in an audio device - any audio device.
That's a VERY hard pass for it.
