Eversolo DMP-A8 Balanced Streamer/DAC Review
Rate this streamer/DAC/Preamp:
    Votes: 9 1.8%
    Votes: 12 2.4%
    Votes: 97 19.8%
    Votes: 372 75.9%
This is a review and detailed measurements of the Eversolo DMP-A8 balanced DAC, Streamer, HDMI ARC, and Analog/digital Preamplifier with DSP support. It was sent to me by the company and costs US $1,980.
The DMP-A8 is stylish and functional in every sense of the words. Running Android with a high-speed processor, navigation is smooth and very rich. I am assuming the same CPU is used for DSP implementation of equalization, delay and compression as it works for all inputs (output must be analog however). The usual App is provided for the control but I was disappointed that a hard remote was not. Back panel shows the very rich connectivity:
Eversolo DMP-A8 streamer Roon Ethernet Balanced DAC HDMI ARC back panel DSP EQ Review.jpg
Really, I can't think of a thing that is missing there. The DMP-A8 can easily be the heart of a modern system with support for legacy analog inputs as well.
Volume control provides excellent channel matching courtesy of stepped relay control.
Beauty extends to the insides:
There are many features available such as per input volume preset.
The unit was sent to me many months ago but I wanted to review it when Roon was implemented and it is now.
If you are not familiar with measurements that are about to follow, please watch my tutorial:
Eversolo DMP-A8 Digital Measurements
I streamed my reference test signal over Ethernet from Roon, capturing balanced output:
This is within shouting distance of state of the art stand-alone DACs:
Surprisingly, there is no hit to using RCA output:
There is a slight difference in dynamic range however:
Eversolo DMP-A8 streamer Roon Ethernet Balanced Dynamic Ranage Measurement.png
Performance gets a bit better if you crank up the volume to max:
Eversolo DMP-A8 streamer Roon Ethernet Balanced XLR THD vs Level Measurement.png
Multitone performance is superb:
Eversolo DMP-A8 streamer Roon Ethernet Balanced XLR Multitone Measurement.png
As is linearity:
Eversolo DMP-A8 streamer Roon Ethernet Balanced XLR Linearity Measurement.png
Jitter is nearly so and is input independent:
IMD vs level shows a slight rise in noise in mid-level but it is inconsequential:
Eversolo DMP-A8 streamer Roon Ethernet Balanced XLR IMD vs Level Measurement.png
Looking at the spectrum (not shown), noise floor moved up just a hair at -37 dB.
Driving an unrealistically low impedance of 600 Ohm doesn't bother the A8 at all:
Nor does it care what frequency you throw at it:
Eversolo DMP-A8 streamer Roon Ethernet Balanced XLR THD+N vs frequency Measurement.png
The DAC in use is AKM and we have the usual set of filters available:
Eversolo DMP-A8 streamer Roon Ethernet Balanced XLR Filter Response Measurement.png
Eversolo DMP-A8 streamer Roon Ethernet Balanced XLR  frequency response Measurement.png
Eversolo DMP-A8 Analog Preamplifier Measurements
I stayed with XLR input and output to keep the measurement set manageable. I selected volume control at 0 dB (it allows excursion well above that):
Wow! I was not expecting this. This is amazing performance. I thought it is digitizing the input but it is not (which sadly means DSP is not available for it either).
Across every measurement, performance is superb:
Eversolo DMP-A8 streamer Roon Analog Input Balanced XLR ferquency response Measurement.png
Reducing level to just 50 mv still provides excellent dynamic range:
Eversolo DMP-A8 streamer Roon Analog Input Balanced XLR SNR 50 mv Measurement.png
That good noise performance translates into IMD vs level as well:
Eversolo DMP-A8 streamer Roon Analog Input Balanced XLR IMD vs level Measurement.png
Making sure nothing bad happens when volume is reduced, here it is at -10 dB:
Eversolo DMP-A8 streamer Roon Analog Input Balanced XLR IMD vs level -10 dB Measurement.png
Crosstalk is superb:
Eversolo DMP-A8 streamer Roon Analog Input Balanced XLR Crosstalk Measurement.png
And no frequency dependency:
Eversolo DMP-A8 streamer Roon Analog Input Balanced XLR THD vs Frequency Measurement.png
In just about every area you look at, the DMP-A8 brings class leading performance combined with functionality that is not available elsewhere. All is put together in an elegant packaging with extensibility and openness of the Android OS. Critical features such as equalization and compression are provided. The only misses are lack of included hard remote and absence of DSP on analog input. The latter does translate into better performance than any digitizing analog preamp.
It is with my absolute pleasure to recommend the Eversolo DMP-A8 streamer and DAC. It is expensive but just doesn't get better than this folks.
Great performance! :)
It's a shame almost nobody make multichannel devices with such features and level of performance at a realistic price. :(
Very nice, but compression? Just what we need with compression in all the recordings already overdone. Ugh. Also lacking balanced digital out, but I can forgive that as it has become uncommon.
Really, I can't think of a thing that is missing there. The DMP-A8 can easily be the hearth of a modern system with support for legacy analog inputs as well.
As is linearity:
Wow! I was not expected this. This is amazing performance I thought it is digitizing the input but it is not (which sadly means DSP is not available for it either).
Shame about the lack of a proper filter at Nyquist, but otherwise a perfect (can I say that?) product.
BTW did you mean "hearth of a modern system" or heart?
And it has those beautiful VU meters to display.
Many thanks, Amir. A few (four) corrections:
Really, I can't think of a thing that is missing there. The DMP-A8 can easily be the hearth heart of a modern system with support for legacy analog inputs as well.
Wow! I was not expected expecting this. This is amazing performance. (FULL STOP ADDED) I thought it is digitizing the input but it is not (which sadly means DSP is not available for it either).
In just about every area you look at, the DMP-A8 brings class leading performance ...
Thanks for the review! Great figures but no room correction (ouch, that breaks the value proposition for me in this kind of device), BT with just SBC/AAC.
Is there any chance we will experience app problems in future because android becomes outdated?
Very good question.
I noticed in specs elsewhere the analog pre has 10 db of gain.
As expected, I started with the A6 and now upgraded to the A8 for analog volume control - it does everything you'd expect.
Regarding the analog volume control measurements, isn't it just a passive stepped attenuator, hence such good results? Otherwise it looks even better, if it's an active stage.
Compression is useful for late night listening (many AVRs also have that option).
I wish someone would post results of double-blind listener testing to show that someone can hear the difference between a system like this with near-perfect measured performance and a DAC with "merely good" performance like the Schiit Modi 2. Can anyone hear the difference in performance? If not, then what's the point of product designers and manufacturers chasing these numbers?
Wow, phenomenal performance!!
Companies like Eversolo/Zidoo and Linkplay/Wiim are really starting to put the proverbial cat among the pigeons.
