Eversolo A8 has much better preamplifier section than Marantz. My suggestion is to use preamplifier section of Eversolo and connect it to Marantz bypassing its preamplifier. So that you will be using Marantz as amplifier only. I am not sure if Marantz 8015 allow such connection, but worse to check
I have to take my words back. After a couple of weeks listening to Eversolo A8 as streamer/ DAC /preamp connected directly to my amp Rotel RB-1090, I found myself not really happy with the sound quality.
I was listening to tracks that I know very well, and they sounded very muffled and indistinct—to the point where I actually walked up to the tweeter and put my ear to it! I thought they might have failed. But no, they were working, just with very dirty, muffled, and low-quality sound. I'm not an audiophile, so I don't know how else to describe it, but the system just sounded bad.
Then I went to the Zidoo forum looking for posts about the A8 and found user reports saying that the preamp in the A8 is very poor and doesn’t provide enough output level to the amplifier. I also noticed this in my system. I could turn the volume on the A8 up to -8 dB, which is almost the maximum.
I want to remind you that my amplifier is a Rotel RB-1090, which delivers 380W at 8Ω and 700W at 4Ω. I realized that the Eversolo A8 has issues with preamp output, and it's not just me—I've seen many other reviews reporting the same problem.
I decided to bring back my former preamplifier, the Rotel RC-1572 MK2, and see how the system would sound with it. I connected the Rotel RC-1572 MK2 to the Eversolo A8 using an RCA cable and disabled the preamp mode on the A8 (setting the volume control to 0 dB). In other words, I used the A8 purely as a streamer and DAC.
Then, I played the same tracks again, and from the very first seconds, I heard clean, high-quality, and stunning sound! The difference was massive! Additionally, with the Rotel RC-1572, I set the volume knob to 65 out of 100, which produced the same sound level as the Eversolo A8 at -8 dB. This confirmed to me that the preamp in the Eversolo A8 is of terrible quality.
I’ve never noticed a difference in DACs or amplifiers before, and I always believed that preamps didn’t affect the sound at all. But in this case—sorry, but only a deaf person wouldn’t hear the difference!
But then, I encountered another surprise. I decided to connect the Eversolo A8 to the Rotel RC-1572 via USB to bypass the A8’s built-in DAC and listen to how it would sound using the internal DAC of the Rotel RC-1572. And once again, I was shocked! The sound quality with the Rotel RC-1572’s built-in DAC became even better!
I won’t describe it like an audiophile would—I’ll just say that I started hearing cymbals in the drum tracks that I hadn’t noticed before with the Eversolo A8. And this whole situation left me completely puzzled. I asked myself, how is this possible? The DAC in the Eversolo A8 is technically far superior to the one in the Rotel RC-1572 MK2, yet the A8 sounds terrible. And I don’t understand how this can be when Amir (from ASR) tested it and the measurements were excellent! Why does the A8 sound so bad and muffled???
I don’t know what to think, but I decided to keep the Rotel RC-1572 MK2 and now use the Eversolo A8 solely as a streamer. If I had known that its DAC and preamp were so bad, I would have just bought the cheaper A6 model instead.
