Eversolo DMP-10, new release 25 october
Cofra
Still very little information. Looks like a streamer, dac, preamp combo. It would be nice with a review after release.
EverSolo DMP-A10
EverSolo DMP-A10 is the flagship model of a network player, created for the most demanding audio enthusiasts. Designed in the Hi-End class, it offers extraordinary precision and sound purity, combining advanced technology with excellent workmanship.
The most important features:
  • Two – linear power supplies High-class components, including two independent linear power supplies, guarantee exceptional stability and eliminate any interference. Thanks to this, the player offers spotlessly clean sound, free from noise, which is crucial in Hi-End systems.
  • Two outputs on the – subwoofer The DMP-A10 has two subwoofer outputs, which allows you to flexibly expand the system by two subwoofers. It is ideal for people who expect deep, balanced bass in their stereo sets or home cinema.
  • Room correction system - EverSolo Room Correction – The advanced EverSolo Room Correction system automatically adjusts the sound to the room's acoustics, compensating for acoustic imperfections such as reflections and resonances. Thanks to this, the player ensures perfect sound in any space, regardless of its conditions.
  • Adjustable display visualization on the – potentiometer The player offers the option of personalizing the displayed visualization. This allows full control over the appearance of the interface and adaptation of visual elements to your own preferences, which increases the comfort of use and aesthetics of the device.
EverSolo DMP-A10 is a Hi-End network player that combines innovative technologies with the highest sound quality. Dedicated to people who are looking for uncompromising solutions in the audio world, offering unique sound impressions and advanced acoustic correction functions.
Eversolo DMP-A10​
The Eversolo DMP-A10 is a network and DAC player of the highest quality and incredible versatility. As a true centerpiece of a modern Hi-Fi system, it offers a wide range of functions, from local file playback to access to your music library from networked devices or your favorite streaming applications. Its careful design also guarantees the clearest and most accurate sound reproduction possible. The model uses the patented EOS operating system (Eversolo Original Sampling-rate Audio Engine), which supports audio output at any sample rate. In other words, when playing any audio file, you can completely avoid Android's SRC limitation, as it supports audio transfer from third-party applications for perfectly accurate playback.The DMP-A10 supports virtually all available high-resolution file formats, including CD formats (FLAC, WAV, APE), DSD512 (.dsf, .dff, .iso, .dst), and stereo and multi-channel streams.
Hybrid DACs with Divided Sections
Audio decoding of the DMP-A10 is done using two chips: AK4499EX (analog section) and AK4191EQ (digital section). This design minimizes the impact of digital noise on analog output, resulting in a noticeable improvement in signal / noise ratio. The DAC supports high-resolution audio streams of up to 32-bit PCM at 768 kHz and DSD512, as well as decoding of MQA files.
DSP processor
The DMP-A10 also incorporates a powerful AK7739VQ-based DSP processor with DSP volume control, parametric equalizer, FIR filters, HPF / LPF filtering, bass reinforcement, compressor, and delay control.
LCD touch screen
The 6-inch high-definition LCD touch screen, perfectly integrated into the DMP-A10's aluminum housing, guarantees practical and ergonomic use. The user interface should be as intuitive as possible. Thus, it is possible to access all the parameters and information of the player through this beautiful interface.
High speed SSD compatibility
The DMP-A10 is equipped with 4GB of DDR RAM + 64GB of eMMC internal memory, allowing many applications to be used. The slot is compatible with an SSD M.2 NVME 2280 up to 4TB (SSD not included), it is designed to be installed without removing the cover and allows you to store your music locally and access it very quickly. Also, using an SSD instead of a hard drive reduces the temperature and vibrations of the device.
Power supply
To eliminate mutual interference and noise between system circuits and audio circuits, as well as to improve sound clarity, EverSolo has used a dual power supply design on the player power supply. The linear power supply consists of a toroidal transformer specially designed to adapt to the characteristics of analog audio circuits. The high-quality switched power supply is specifically designed for system circuits, greatly reducing ripple and magnetic leak noise, and provides reliable support for high-quality digital audio processing. It also incorporates proprietary smart switching technology for the input voltage of the linear power supply,ensuring compatibility with voltages around the world without the need for manual switching.
Audio components
The audio quality of the analog output of the DMP-A10 is monitor level. Audio circuit elements include German WIMA capacitors, NICHCON special audio capacitors, Murata chip capacitors and Omron relays from Japan, US IT Audio operational amplifiers. and much more. The goal is to offer a more authentic and cleaner sound.
Volume control circuit
A fully balanced analog volume control circuit made up of resistors and precision relays provides precise volume control, effectively suppressing distortion and noise of the analog signal. It also has volume protection, which automatically reduces excessive volume to a designated safe level during startup or switching of the input interface. Activation of the R2R analog volume control ensures that the DAC can operate in an optimal state at all times.
Complete range of inputs and outputs
The DMP-A10 can be used as a digital player, connecting to a wide variety of high-end DACs through I2S HDMI, USB, optical or coaxial outputs. As a DAC, it also has several digital inputs: two coaxial, two optical and USB-B to connect a computer or a smartphone. As a high performance preamplifier, the unit features a balanced XLR input and an unbalanced RCA input. In addition, the DMP-A10 incorporates Bluetooth 5.0 to facilitate wireless connection to a wide range of sources. Finally, the DMP-A10 can be connected directly to active speakers or to a power amplifier through unbalanced RCA and balanced XLR outputs. The package is completed with a trigger output that allows the DMP-A10 to be integrated into an automatic trigger circuit.
XMOS 316 and watch
The DMP-A10 incorporates a third generation XMOS 316 USB interface for seamless USB audio reception and decoding. Supports audio streams of up to PCM 32 bits 768 kHz, DSD to DSD512 and MQA. As for optical ports (coaxial and Toslink), they support DSD 64 (DoP) and PCM 192 24-bit.
Like the updated DMP-A6 Master Edition, the DMP-A10 incorporates two high-precision femtosecond Accusilicon clock oscillators and ultra-low phase noise for the audio decoding circuit (45,1584 MHz and 49,152 MHz), which correspond to the decoding multiplication of 44.1 and This effectively suppresses fluctuations, which novomusica zaragoza enables high-precision conversion and decoding of digital to analog audio signals, providing ultra-high dynamic range and output resolution. Improved OPA1612 operational amplifiers with ultra low noise and low distortion (0.000015% at 1 kHz) further enhance this effect.
MQA decoder
The DMP-A10 includes an MQA (Master Quality Authenticated) decoder, which allows you to play these types of files and enjoy sound quality as close as possible to the original studio recording. Also, MQA transmissions are light enough for streaming.
CD play and copy
The DMP-A10 offers CD playback from an external USB connected drive. The integrated CD Rip application uses a data validation mechanism and an error correction function to save the audio data without loss from the CD. The application algorithm intelligently matches album titles and CD songs (officially released CDs are required), Copy tracks without loss and automatically generate album and artist information.
Bluetooth 5.0.
The DMP-A10 uses a QCC5125 Qualcomm chip for Bluetooth 5.0 reception. It is compatible with SBC, AAC, aptX, aptX LL, aptX HD and LDAC high definition transmission codecs, allowing you to enjoy high-quality audio playback via Bluetooth.
Balanced preamplification circuits
The DMP-A10 incorporates balanced analog circuits from the DAC chip to the XLR and RCA stereo outputs. This limits noise and channel separation provides better signal quality.
Network functions
The DMP-A10 provides access to the most popular music streaming platforms and web radio stations, such as Tidal, Qobuz, Deezer, Amazon Music, Apple Music, HighResAudio and Paradise Radio, allowing you to enjoy music without restrictions. As a streamer, the DMP-A10 supports Tidal Connect and DLNA streaming protocols, as well as many other streaming services. This allows you to play music files directly from a streaming application by transferring them to the DMP-A10 over the local network. In addition, the quality of the novomusic sound is perfectly preserved. It supports a wide range of network protocols, including NFS, SMB v1 / v2 / v3, and UPnP / DLNA, allowing you to explore and play music stored on a NAS or network device connected to the LAN.Even high-resolution audio streams play smoothly.
Small extras that make the difference: filters, volume meters and an aluminum box
The DAC settings of the DMP-A10 include 6 digital filters with different modes to modify the sound reproduction according to your preferences and 4 DSD filters. Multiple displays with audio meters and spectra provide a pleasant and aesthetically pleasing visual experience. The Eversolo DMP-A10 chassis is made of aeronautical quality aluminum, machined by CNC with maximum precision to provide the unit with extra resistance. The matte front panel and anodized chassis form a beautiful Zaragoza novomusica mix of classic and modern. The integrated M.2 NVME SSD slot is accessible from the bottom of the unit, allowing you to quickly and easily install an SSD (available separately) without opening the unit fully. The DMP-A10 supports SSD capabilities of up to 4TB.This means that you can expand your storage capacity with a fast, reliable and quiet system.
Control options
A specific mobile control application for Android and iOS has been developed for the DMP-A10. In addition to basic control of playback and management of local system parameters, the app provides asynchronous access to music library data, system applications, and menus. It also allows access to streaming services directly through its interface. If the user is away from the device, novomusica zaragoza can use the application and its screen duplication function to control the streamer through the family interface. An infrared and Bluetooth remote control is also included. It supports WoL (Wake on LAN), allowing you to remotely turn the device on and off from your network (requires wired network connection).
Characteristics:
Type: network audio player
Transformer type: toroidal
Storage capacity: 64 GB
Central Processing Unit (CPU): XMOS XU316
Built-in DAC: AK4191EQ + AK4499EX
Dynamic range: RCA: > 128dB, XLR: > 125dB
Frequency range_ (n): 20 - 20000 Hz
Harmonic coefficient: RCA: <0.00010%, XLR: <0.00009%.
Display: 6 LCD touch screen
Max speed Bit / sampling 32 bits / 768 kHz, DSD512
Signal / noise ratio: RCA: >125dB, XLR: >128dB
RAM: 4 GB DDR4
Consumption: 16 W
Inputs: 1 x RCA, 1 x XLR, 2 x coaxial, 2 x optics, 1 x HDMI ARC, 1 x LAN, 1 x USB type B
Outputs: 1 x RCA, 1 x XLR, coaxial, optical, HDMI Audio, 1 x USB 3.0 Type A, 1 x USB Audio, 1 x 12V trigger
Interfaces: Ethernet (RJ45), WiFi, Bluetooth, 2 x USB Type A 3.0
Wi-Fi: 2.4 GHz / 5 GHz
Multimedia support: M.2 NVME 3.0 2280 to 4TB
Compatible formats: MP3, WMA, FLAC, ALAC, AAC, OGG, WAV, AIFF, DFF, DSF, DSD512, MQA
Power supply: high quality linear and low noise + digital power supply
Maximum bit rate of audio files: USB: PCM 768 kHz / 32 bits, DSD512, MQA; coaxial / optical: PCM 192 kHz / 32 bits, DSD64, MQA
Control App_0: Yes
Compatibility with streaming services: Air Play, DLNA, Spotify, Tidal Connect, Qobuz Connect
Packaging dimensions: 500 x 370 x 200 mm
Dimensions (AnxAlxAl): 388 x 90 x 248 mm
Color: black / black
Package weight: 7.2 kg
Those are exactly the same as the A8, are you sure this is correct? Looks bigger than an A8 on the pictures.
This was found listed by a retailer, translated, lifted verbatim and posted here for info, so I can't vouch for accuracy, but we should know shortly.
It does seem to be an A8 in a new jacket, except for the fancy volume knob and HDMI Audio out. At first I thought it was maybe a streaming amp, due to the massive heat sink fins either side.
The most noteworthy feature for me, highlighted in an earlier post is the room correction. Hopefully this'll trickle down to the A6 and not just run on the DSP, to compete with the likes of the WiiM Ultra in this regard.
Eversolo DMP-A10​
DSP processor
LCD touch screen
Power supply
Audio components
XMOS 316 and watch
MQA decoder
CD play and copy
Bluetooth 5.0.
Network functions
Control options
Characteristics:
RAM: 4 GB DDR4
Consumption: 16 W
Control App_0: Yes
How is this different from the A8 , besides the styling?
A quick comparison of the specs reveals little differences..
Doubtful there will be any differences in sound quality.
Bk
Interestingly, It supports WoL (Wake on LAN), although so too does the A8..
Analog VC check,plus safeguards against the known glitches,that's an enormous advantage,specially at an active,stereo bass system (the later is another advantage)
Wish that the two heatshinks are attached to some shunt regulators :p (I'm a sucker for Salas shunts)
If the SNR is at the 105-110dB,has a nice THD+N vs level and measures linear from lows to up-high and the EQ/filter implementation is at RME level and not some noise-inducing one down-low,yep,that would do it.
It has the same 6” screen, looks similar
Bk
Two sub outs which presumably you can configure, and auto room correction, and yes no difference in SQ because the A-8/A-6 measure pretty well already.
What will be the purpose of delay control?
I'm wondering if I would be able to use this feature to connect with Kii Three with a digital output and time align the subs with this delay control?
I wonder if the subwoofer out is implemented through a crossover HPF/LPF circuit? Or is it a duplicate of L/R channel as sub-out?
