It has a deadline to return so probably in the next two weeks.
Please consider evaluating temperature during “all channels driven” testing (as practical): Possible scenarios to consider: (3X00-6X00 series)- all internal, L/R out + internal, and L/R/C out + internal, and for the 8500- all internal, L/R/C out + internal (full and Eco). Ideally, temperature testing could be incorporated in parallel with your existing testing flow/protocol, and may be relevant to other “hot” receivers.
Heat is the bane of electronic performance and reliability. Watching your Denon testing progress (from 9 ch. at 105/120W ea., to 11 at 140, and (upcoming) 13 at 150), with their “hot” characterizations, only increases my desire to find ways to mitigate it, as I consider purchasing options.
My intent in the 4700 thread, revolved around the idea that adding an external amplifier would/could/should confer benefit, and was an attempt to begin to try to quantify some of that potential benefit.
I believe my rationale is generally applicable to all receivers: heat, dynamic headroom, (potential) distortion, (potential) EMI, and power supply capacity/conservation (for the remaining channels/system) are all areas I would expect to see some level of benefit (both internally and externally) from using an additional 5 channel (3X00/4X00) or 3 channel (6X00/8500) amp.
The 8500 is the only Denon model to allow selective pre-out configuration beyond L/R (without applying the “nuclear” pre-out “all” option). What is not clear is the impact L/C/R “offloading” would have on its system level heat product. After all, it’s a big, tightly packed unit with a lot going on- AKA a modern rxr.
Eco mode (heat reduction) appears to only be a global option. With L/R/C out, it may be possible that Eco mode (8500 Eco level TBD) could be sufficient to drive surround channels. On second thought, is Eco mode even an actual viable operating mode for home theater? Internal and external amps are still driven by the pre-amp- as vol is increased beyond some level, won't the unit globally revert back to full power mode...
BTW, regarding BsdKurt “It feels like the Star Trek episode…” (p.5)- Thank you for ASR. It is an incredible resource.
