Any reason why Denon/Marantz does not offer Roon support. Does anyone know if Denon/Marantz has made any mention of this?Internally and software-wise? No difference. Only difference is the aesthetics, and whether that's worth the price premium is up to you. FWIW, I think the C40 is the best looking AVR on the market, especially in silver, and if Integra had not announced Roon support, that's what I would own right now.
Are you sure, my AVR-X4400H does support multichannel DSD but obviously it only supports it in the lowest resolution.Why no support for multichannel dsf files on the Denon X4800h. I find this to be crazy and real head scratcher. I have the Denon but I wonder why a company would make a premium multi-channel receiver, yet not provide full support for all multichannel files, especially dsf which are based on multichannel sacds. Any thoughts?
Do you mean DSD? Never heard of DSF...Why no support for multichannel dsf files on the Denon X4800h. I find this to be crazy and real head scratcher. I have the Denon but I wonder why a company would make a premium multi-channel receiver, yet not provide full support for all multichannel files, especially dsf which are based on multichannel sacds. Any thoughts?
Same thingDo you mean DSD? Never heard of DSF...
My fingers are crossed that when the PAC AVRs are updated for Roon Ready, they will support lossless multi-channel. But we will see...Multichannel DSD is supported over HDMI but not over network or from USB.
Actually does any AVR support multichannel music over network? DSD, FLAC, ac3 or anything?
My theory is that they are trying to push their HEOS crap...Any reason why Denon/Marantz does not offer Roon support. Does anyone know if Denon/Marantz has made any mention of this?
HEOS is terrible. My hope is that is Onkyo is truly Roon Ready, maybe Marantz/Denon will feel they need to stay competitive and offer this.My theory is that they are trying to push their HEOS crap...
I believe you can do this with minimserver. Can anyone confirm?Multichannel DSD is supported over HDMI but not over network or from USB.
I believe this is a sony licencing thing. Unless it is played from the disc, it is only transmittable via HDMIMultichannel DSD is supported over HDMI but not over network or from USB.
Their AVRs are Roon Tested which means Roon sees the AVR but streams using Airplay not Raat.Any reason why Denon/Marantz does not offer Roon support. Does anyone know if Denon/Marantz has made any mention of this?
Airplay is too limiting in terms of sample bit rate and limits the full functionality of Roon. They need to be roon endpoints like Onkyo and NAD does with their receivers.Their AVRs are Roon Tested which means Roon sees the AVR but streams using Airplay not Raat.
Roon Works on my cinema 70 - AirPlay runs everything as 44.1/16 .
Which functionality is limited ? I can use all the DSP, searches, meta data, volume , sleep timer . It’s just the transmission at 44/16 I think …Airplay is too limiting in terms of sample bit rate and limits the full functionality of Roon. They need to be roon endpoints like Onkyo and NAD does with their receivers.
No lossless transmission, no multi-channel audio, no Roon cover-art display, etc. You also lose all of the Roon Signal Path data because there's no 2-way communication as with RAAT. So essentially Roon is just throwing it over the fence as AirPlay and has no idea what happens next. FWIW, if you want better than 44.1/16, then stream via Roon/Chromecast instead. It's just a higher bandwidth protocol which the Denon supports out of the box.Which functionality is limited ? I can use all the DSP, searches, meta data, volume , sleep timer . It’s just the transmission at 44/16 I think …
I do get signal path data up to the point of replay on the Marantz - which is correctly identified on Roon. No issues with cover art on the playback device as I see this on my iPhone. It’s kinda of nice that the TV is not powered on by airplay.No lossless transmission, no multi-channel audio, no Roon cover-art display, etc. You also lose all of the Roon Signal Path data because there's no 2-way communication as with RAAT. So essentially Roon is just throwing it over the fence as AirPlay and has no idea what happens next. FWIW,
It does mention 5.1:When you look at the manual and look at the file support, it only mentions 2 channel dsf and not multichannel.
So it's actually built into the AVR and into Roon. From Roon, if you go to Settings -> Audio and scroll down to "Other network devices", you should see your AVR listed twice, once with "via AirPlay" and again with "via Chromecast streaming". Choosing Chromecast should get you higher resolution.I do get signal path data up to the point of replay on the Marantz - which is correctly identified on Roon. No issues with cover art on the playback device as I see this on my iPhone. It’s kinda of nice that the TV is not powered on by airplay.
44.1/16 is fine for me - I attribute most of the difference I hear in higher resolutions to differences in the mastering not the resolution. Maybe my hearing isnt good enough!
Your point on HEOS is a good one, wonder how HDMI from chrome cast compares to say a wiim pro via coax or a little pi4 based Roon endpoint
