True. I would add that amplifiers for all channels are mostly identical and can handle the same load. It is rather about power supply and cooling. I would expect that it is all ok for music, but amp could have problems to pass sinus test for all channels simultaneously.
Yep, ACD issues are much more related to the power supply, and the thermal design overall. All those talks about 6 ohms, 4 ohms vs 8 ohms used are not helpful but given the long tradition, and standards, there isn't much else manufacturers can do. The only trouble is, it gets the public/consumers confused all the time.
Consider this, all else being equal, compare the following amp A vs amp B:
AVR-X4800H power output specs: 125 W 8 ohms, 0.05% THD+N, 165 W 6 ohms, 0.7% THD+N, Power consumption:
730 710 W
Integrated amp Yamaha A-S801: 100 W 8 ohms, 0.019% THD+N, 120 W 6 ohms, 0.038% THD+N, Power consumption: 270 W
Both have impedance selector and the user is supposed to set it to 4 ohms if 4 ohm nominal speakers are used.
Now for the average users, someone will follow the Audioholics article and many forum talks and ignore the impedance setting, while many others will follow the owner's manual and set it to 4 ohms when using speakers such as the 4 ohm rated reference 3A.
And worse, supposing those (again, on all else being equal basis), say group A who follow the owner's manual instructions never listen to spl louder than 90 dB peak from 8 feet, while those, say group B who left the selector on the 8 ohm setting frequently listen to 80 dB average and 100 dB peak! That would be sad, as Group B would risk damages, and Group A would likely lose performance when listening to music that has great dynamic range. What's the alternative, should there be better standards for manufacturers to follow, when writing their owner's manuals on power output specs with reference to speaker specs instead of just 100 W 8 ohms, 120 W 6 ohms, and set impedance to match the impedance of speakers. And by the way, don't we all know speaker's impedance specs are also cans of worms.
