Sounds like a sweet set-up, really! Be sure to compare LS vs THX single-ended too, the balanced might simply sound much louder (for better or worse..)
I will unbox the LS stack soon as I have put them away for now and try the cans there and maybe I will get same results or something different.
Aeon RT (open) arrived Tuesday evening here in Chicago and the cans have been rolling on THX 789 since that evening around 7pm (only rested for a couple of hours) and still running now 04/01/2021, 6:47 P.M. CST
As I am writing this first impression, not so much of a detailed review the cans are currently plugged in to my Bellari HA540 MK2 hybrid class A tube amp (single ended) and comparison between the 789 balanced down below.
First, I want to address the ear pressure that one of the members have experienced with the closed back, there is non here on my copy (probably only present on the closed back as everything is sealed in tightly when a user puts on the headphones.)
Second, this is coming from a consumer perspective (me), take it how you want as my ears are not yours and vice versa.
Third, I only used one DAC for testing and this is the GRACE SDAC BALANCED, connected are the BELLARI HA540 MK2 and THX 789. The BELLARI is running RCA (no balanced in or out) THX 789 is running balanced cables. PC is powering the DAC and Spotify very high bit is used to listen to music.
PC - DAC - THX 789 - AEON balanced everything = musical, clean, no grain, hitting the target? plausible.
with this setup, I find everything to be fairly neutral, nothing overly extended, no shouty vocals, lows are clearly present, mids are there, highs are good and balanced, nothing overly done. The cans do get loud at about 10 to 11 on the dial, but increasing the volume will not do my ears any good.
PC - DAC - BELLARI - AEON single ended = resolving, louder but clearer, vocal tonality and range have a more presence in range and frequency (AEON RT open literally opened up to maybe it's full potential on this hybrid class A tube amp).
with this setup, volume pot is at 8 on the dot and it's loud enough adding more will not benefit my musical intake. Everything tightens up with the Bellari, bass, mids, highs, vocal presence is outstandingly clear and not mediocre or dull as when listening on the 789. Reverb are present on certain tracks and decay is faster. Instruments, every pluck on an acoustic guitar registers the string vibrations with clarity and precision (HELL TO THE YEAH)!!! Brass horns are brassy and not metallic sounding, high hat splash reverberates and leaves a good amount of sparkle.
Test songs
-Chris Isaak, Wicked Games
-Eric Clapton, Tears in Heaven (acoustic performance)
-Within Temptation, What Have You Done (acoustic performance)
-Gangstagrass, Barnburning
-Hans Zimmer, Discombobulate
-Edmon Colomer, Concierto De Aranjuez Adagio
-Bela Fleck and the Fleckstones, The Sinister Mister
-Notorious B.I.G. & Bonethugs-N-Harmony, Notorious Thugs
-Marvin Gaye, I Heard It Through The Grapevine
-John Coltrane, Naima
-Barry White, You're The First, The Last, My Everything
-Bob Marley and The Wailers, Coming In From The Cold
In conclusion, I will put these cans between the laid back Senn 650 and energetic Bdynamic 990.
Soundstage is not as wide as the Hifiman HE 400i 2020, bigger than the 650, same level as the 990 (990 being a hair wider) with pin point imaging accuracy as the ELEX? These cans have good timbre accuracy as some cans that cost more $$$. I believe that if the Aeon RT have the organic vocal presence of the Senn 6X0 line, these cans will be the $500 king and below to beat. This is merely my opinion and how I like/listen to my music, I understand there will be conflicting arguments said above hence take this with a grain of salt.
