Coaxial Nearfield: Genelec vs Kef vs Kali
abcde
Is Genelec really worth the money over Kali?
Looking for nearfield coaxial monitors to upgrade from Adam T5V, listening distance 1.0-1.2 meter, desktop use directly flanking a 32" monitor, typical SPL <80dB. I specifically want coaxial to optimize response as I move slightly around in my very nearfield listening/seating position.
Rest of system (that I already have) is miniDSP SHD, Dirac, and 2x Rythmik L12 hidden under the desk. I could make modifications to those components if there was a compelling need to, i.e. miniDSP Flex Eight. I entertained the idea of dual Rythmik FM8s on the desk for a while, but I want the setup to be sleek, not cramped.
I'd prefer to be able to crossover as low as possible, around 60-70 hz (48dB/octave), since the subs are under the desk and completely occluded from my ears... which points me to monitors that can competently reproduce 50-60 hz.
I have found available to me:
  • $800..... Kali IN-8 V2
  • $1600... Kef LS50 Meta (+ amplification)
  • $2200... Kef R3 Meta (+ amplification)
  • $4000... Genelec 8331A
  • $6200... Genelec 8341A
Genelec -- I know they're likely the best and that they hold their value. But after playing around with the upper echelon of headphones, I'm well aware of diminishing returns with additional $$$ spent. I worry that the 8331A won't play quite as low as I'd prefer.
Kef -- They occupy a middle ground in pricing. I feel like I'd rather get a good value with Kali, or go cost no object with Genelec. I also really prefer the idea of internally tri-amped and DSP corrected drivers/crossovers.
Kali -- IN8 v2 is a little ugly, I'm getting that 90's wavy cup aesthetic. The price is amazing. And it sort of bothers me that the woofer isn't vertically symmetric like with Genelec. How much performance do they really give up against Genelec coaxial for a super nearfield and low SPL application? I'm 100% percent about measurements and hard data, and after reading the available reviews on this site, it's tough for me to try to justify the nearly eight-fold increase in price. Is there anything I'm missing regarding selection for my application?
Get the Genelecs and be set for life.
Add subs later.
If you move in the horizontal direction only you won't need ciaxial monitors.
Crossing over at 80 Hz is no problem even with the sub under your desk.
If you can ask the question and can afford them? Like the guy says be set for life, but I'd bet $20 they're not 8X better than the regular Kali 6''. And you still need a subwoofer. I'd take the R3 off the list for nearfield.
If I ever spent that kinda cash I'd go with the Neumann KH310, 3-way design 8'' woofers for $5K. Hopefully decent until you save for a sub.
I have 8040b, IN5, Kh120, Kef LSX
Save your money and get the Kali.
Caveat:
1. Unless you can actually hear a difference and prefer one
2. You must have the absolute best
They are all very good speakers. I would recommend a sub and don't set crossover as low as it can. That defeats the purpose of the subwoofer. Having the bass come from one area gives a consistent bass response and placement is very important for bass reproduction in small home sized rooms.
So, you can get a different bass response if the left, right or sub are playing the bass. Or combos of them. So, it is best to place the sun in a good location for a good response and let it handle the bass.
Anyway, we carry all those models where I work and I would rank them as follows. I haven't compared them all side by side so a lot of this is from memory. Listening to them of possible is definitely recommended.
Genelec 8341
Kali SM-5-C
Genelec 8331
Kali IN-8
Kef R3 Meta
Kef LS50 Meta
YMMV.
Caveat:
got the kali myself, best deal i have ever done in audio equipment, changed them only because i did find my dream speakers, but they were good, now they stay in the surround
What are the dream speakers ?
If you are considering Kali for near field, I can enthusiastically recommend the IN-5. I've had mine for a couple months now and they are fantastic in their intended application at my editing workstation. They sounded great out of the box, but went from great to phenomenal after REW/APO correction (set to full range in REW).
Some other members here advised me to go for them instead of the IN-8 V2 because of better linearity and reduced cabinet resonance, at the expense of a bit higher bass distortion. I've been thoroughly happy with them. Speaking of bass, the extension and quality are excellent, and the 8's are just going to get you a bit higher SPL. That probably won't be a factor if you are using them as near fields, and actual measured LF extension between the -5 and 8 V2 is negligible.
Interesting, I had simply assumed the IN-8 V2 would be better than the IN-5 as long as I have the desk space. No replacement for displacement, less driver excursion, lower distortion across the frequency range the woofer was expected to play, etc.
A pertinent video from Kali:
Can you share your referenced threads?
You pay $$$ for the engineering that’s gone into the Genelecs, now whether the performance gain that brings is worth the considerable extra cost to you…
For example, the Kali coax driver has a 1mm protrusion where the tweeter transitions to the midrange: (pic from EAC review)
Erin calculated that this would cause reflections around 8khz, and there was a corresponding dip in the measured FR at that frequency. The Kali coax also looks to have a typical roll surround on the mid driver.
Genelec spent, I’m sure, considerable time and money engineering their coaxial drivers to have completely smooth transitions between each other and the waveguide front of the speaker:
You’re definitely well into the area of diminishing returns spending “The Ones” type money, but squeezing the last bit of performance from a speaker is expensive. :)
Unpopular opinion, but I think in the near field the difference of loudspeaker isn't that great if you use equalisation. When you use a level matched blind test it becomes obvious. Especially if you can't place the monitors that optimal and don't want to listen at louder levels that often the differences are smaller than almost all people think they are.
Psychoacoustics plays a lot of tricks with us have a look e.g. here
www.hifiohr.de
Edit: fist version of my post wasn't that clear so I edited it
Unpopular opinion, but I think in the near field the difference with equalisation, level matching and blind testing isn't that great. Especially if you can't place the monitors that optimal and don't want to listen at louder levels that often.
www.hifiohr.de
There may be some truth to your statement, but I can say that switching the REW-derived EQ in and out on the fly shows very obvious differences at a variety of listening levels, not just when pushed loud.
One can flip around your statement regarding blind testing and say that if you don't do blind a/b comparisons, then you are subject to confirmation bias. Psychoacoustics play heavily there, which is why audio reviewers may actually think they are hearing major differences with expensive cables.
Yes, equalisation is not level dependent, but this isn't my point. With louder levels the differences of loudspeakers become more important since there are typically bigger difference in the behavior of loudspeaker at higher listening levels. At lower levels most decent speakers don't have any major problems with nonlinear distortions.
Yes, your eyes and thoughts also contribute to your perception of sound.
Now I propose the thrilling argument that you need good looking, expansive gear with high reputation, since it also changes what you hear with the help of your eyes and thoughts ;)
Definitely eyes and thoughts matter. Probably even thoughts more.
I have mine out of my line of sight and that has helped me listen with my eyes open however eyes closed is still a rung better.
Thoughts matter including what we read here, where we first heard something, one’s state of mind during that first listen, some of the engineering thoughts. I can’t help having them sometimes because it sounds so good and possibly it feeds on itself like a positive feedback loop.
Now what would be funny is if while blindfolded someone swapped out one model for the other and I still had thoughts about the model I was listening to but when I take out the blindfold I discover it’s the other model playing.
To flesh out an example, I like genelecs partly from what I read here and partly because the 8010 was the only speaker small enough for my use case for a certain period in my life.
I also have LS50w. On hand I found them impressive that they solved the head movement problem on the other they didn’t sound all that impressive in a mid field use. They are not professional near fields but consumer bookshelves. Even though they probably are best used at near field ranges.
Also seeing that midrange move always put thoughts of inter modulation distortion into my head. It just never made sense to me that a waveguide for a tweeter would move so much.
I liked the LSX a lot more even though probably the LS50w is the “better” speaker. I think the reason is that I always used the tiny LSX at near field speakers. Always on a desk and not on a stand. It was just impressive to hear what the LSX could do from such a small box at those small distances.
That intermodulation distortion thought process led me to long for a taste of the Ones. Now it could have been any brand on it. It just happened to be only 3 way coaxial that I knew of which solved the inter modulation distortion problem.
It debatable whether I actually heard the problem or whether it’s just that moving midwoofer that gave me a bad feeling. Also frankly integrating a sub to ls50w with its app wasn’t too appealing as it didn’t offer room correction and the options while sufficient for most people I always felt I would still need to get a mini dsp and dial it in with REW.
I was also at that time using Roon to do my corrections.
I found using REW and putting your corrections into Roon was very tedious and I was always unsure of myself and my corrections. Of course I could have taken post measurements to reassure myself.
I had the idea in my head that Genelec Ones would just kill all birds with one stone.
So there is definitely a mental aspect to this. A peace of mind aspect that professionals use them and that I get a detailed GRADE report in the end. What does disappoint me is that it won’t do a post calibration check measurement.
If you got this far you may have noticed I used the word “probably”, “seems”, “feels”, “thoughts” etc. many times.
I bet a skilled user of REW and mini dsp could make any of those sound pretty amazing.
Now if I have to recommend to people who are not that technical I would have difficulty recommending that path. Some people have very valuable time so to speak and they would be best served by getting something they can unpack, put on stands, install a small piece of software and do a 1 minute calibration and get results like a professional.
Alternatively one might do well to get another option at a lower cost and spend a fraction of the difference on a professional calibrator. However one would be calling them for every movement they make of the configuration. This mostly applies to floor stand use. Most desktop users don’t move the speakers. Just have the professional double sided tape the things to the desk so they don’t move.
Desktop audio is by far the best bargain in audio. Cheaper than most of the fancy headphone setups while absolutely trouncing headphones imho - just read the poll on headphone “soundstage” - most people admit they don’t hear any soundstage to speak of - it sounds like the entire mix is in your head.
It’s when you want to sit further back and get a wider soundstage that you pass the point of diminishing returns and go far beyond it.
Having said that even a full on Genelec setup is nowhere near Wilson audio type stuff. It’s like the last stop on the train of rational audio. After that it gets totally wacky.
