squared80
- Joined
- Oct 1, 2021
- Messages
- 60
- Likes
- 89
Finally got all 3 amps hooked up-5 channels of Purifi 1ET400A amplification and 2 channels of NC252MP.
Thoughts?
Plenty of clean power-no more worries about having enough headroom when watching movies at high volume. Love the auto-sense circuit (only on the new Buckeye amps-the older 252 does need a 12V trigger to turn on/off). No need for triggers or switched power strips.Thoughts?
There is a 1yr "embargo" placed on it by my professor once I am finished and upload it to the electronic database in Ohio.....so I can't yet. But after one year definitely will share it of courseYou should post your dissertation here.
Rick can comment on this more, but I believe the "lower" SINAD is due to the limitation of the test equipmentThanks for sharing your review. I'm not sure what to make of these numbers (ie: how comparable they are to Amir's reviews of other Purifi amps since other equipment was used in your review Rick), but SINAD seems a touch worse than the other Purifi's that Amir has reviewed? That said, still looks amazing and nothing to worry about
That makes sense; I misinterpreted what that line in the review (and corresponding graph below) meant. Thanks!Yes, this is discussed at the start of the measurements thread. I have bolded more to emphasize. The max SINAD for the QA401 I use is 101 dB (in loopback).
With some additional equipment, can get to better SINADs, but want to keep it simpler for me and leave something for Amir too!
Well, you don't know that until you've measured it, do you?Why even publish measurement when one know that the measurement system is less competent than the test object?
In this case I think we knew from pure specifications.Well, you don't know that until you've measured it, do you?
Which I greatly appreciate!In this case, the main reason was to validate the implementation of a custom input board. Yes, the equipment used is not capable of the same degree of noise measurement but is sufficient to demonstrate that the amp functions nominally.
If you are happy with specs, that’s fine. Others had requested some design validation and so, as I had already done for Buckeye, decided to share until Amir can do a more complete review.
