There is a 3ch going to Amir soon for reviewDylan, When are you planning to allow Amir to review the Purifi 2ch? thx
Who are these companies and do they build their own and can they back up their products. It would seem using common sense but possibly not common knowledge that a power correction might promote longevity. Does this power correction and the increased voltage matter in final sound?
Is this what we in the industrial world call "power factor correction"? If so, it is accomplished by "active front end" AC to DC converters. It is apparently now well understood (not by me, sorry) technology and minimizes transient loading of the line(s). @Buckeye Amps , are you aware of this, and what power supply providers use it? My experience is with VFD / VSD inverter drives.Power correction ...
I know this ship has sailed but would have liked the bypass option for my Topping Pre90. The Audiophonics 400ET mono has bypass but uses SMPS600A400 and I love that the Buckeye uses the 1200.I know of several people using the Okto dac 8 with a 10V output paired with purifi amps, bypassing the buffer. Can't imagine a 3 way switch is materially more expensive than a 2 way....Would give more flexibility.
At least that's what I thought they were referring to. In the industrial world you also have direct access to three phase AC so there might be additional tricks or methods that make more sense when you're not locked to a single waveform.Is this what we in the industrial world call "power factor correction"? If so, it is accomplished by "active front end" AC to DC converters.
Hello everyone,
On another message forum, I was encouraged to check out Buckeye Amplifiers, since I've been shopping around for a three channel amplifier. I've read through this thread and I am very encouraged to buy the Buckeye three channel amplifier. The only issue seems to be the power supply. Is one provided with the amplifier?
My situation:
-- I listen to high rez (typically DXD 24/352.8 or DSD 64 up to 256) multichannel surround classical music.
-- Music is on a dedicated music server, JRiver Media Center music player, USB to my DAC
-- ExaSound S88 multichannel DAC which goes direct via XLR to my Amplifier
-- Parasound Halo A52+ amplifier driving 5 speakers
-- Front three speakers are Spatial Audio Lab X3 (8 Ohm - 97 dB sensitivity)
-- Rear surround speakers are two SVS Ultra Bookshelves (4 Ohm - 87 dB sensitivity)
I also use my system for home theater. I have two side surround speakers (SVS Ultra Surround) which are currently unused because I don't have enough amplifiers. So, my intention is to use the Buckeye amp for my front three speakers and my current Parasound amp for both the two rear and two side surrounds. I'll be on the lookout for user impressions of the Buckeye amplifier and possibly Amir's review.
Thanks!
Marcus (Las Vegas, NV)
